11-27-2007, 09:19 PM | #1 |
Gas in Oil..
Ya.. so, I was hearing some odd grinding noises coming from my turbo ( I thought). So, I pulled off inlet pipe, checked turbo (it is fine), no oil in intercooler pipes, no noises when I was spinning it.
Put it back together.. And randomly decided to check the oil. It smelled like gas REALLLLLLLY bad. And I noticed the exhaust has been smelling like gas real bad the last few days. So, I know fried onion rings and bad valve seals can cause that, but what else? I checked the plugs, all 4 were dry w/ no build up etc.. I know I should do a compression check again (1st time was ~175 across). But Ill have to go rent 1, cause I dont have one And btw, I was running stock boost (7-8psi) until about a week ago when I turned it up to 10. Any help will be appreciated. I have no idea what could be causing this.. |
11-27-2007, 09:22 PM | #2 |
First thing: Compression test the damned thing. Then go from there.
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
11-27-2007, 10:38 PM | #4 | |
Fried Onion Rings??? hahahahah |
11-27-2007, 11:11 PM | #5 | |
11-28-2007, 10:36 AM | #6 |
ya.. lol. it always makes me laugh too. Except when I am talking about muh car..
Ill see about getting a compression tester after schoolzors. Anyone else have ideas? |
11-28-2007, 10:48 AM | #7 |
dump your oil and look if there IS gas in the oil. if there is gas in oil, and you didnt/or someone else didnt put it there on purpose. The gas is coming down pass your rings. good chance you have a leaky injector.
11-28-2007, 07:43 PM | #10 |
yes.. there is deff. gas in the oil
I was told by a tech today that it could be the cold start sensor. And I think that is a real good possibility b/c my car has trouble starting if its colder then like 65F. And it would explain the excess of gas also. Opinions? I wont be able to do a compression test until like sat. work/school tomorrow and friday. |
11-28-2007, 07:49 PM | #11 |
why would you rent a compression tester?
you can purchase one from any auto parts store for less than $40. you're probably thinking about a leak down tester which would probably h ave to be rented. i lost it when i saw fried onion rings lol.. and i didn't realize these engines had cold start sensors? but i guess you learn something new every day.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving |
11-28-2007, 08:01 PM | #13 | |
11-28-2007, 08:03 PM | #14 |
oh well in that case, R240NA we summon thee.
cold start sensor? yay or nay?
11-28-2007, 08:11 PM | #15 |
there is no cold start sensor, just a coolant temp sensor which is used to control fuel during startup based on temp
97 240sx esaarr | Current Status: SOLD |
11-28-2007, 08:25 PM | #17 |
no... dont just spend money. there is probably some people on here in dallas that could help you figure it out. More then likely you just have leaky injector or need new injector orings.
something would have to be pretty messed screwed up for that to happen. The gas is more then likely getting into your oil when its not running.
11-28-2007, 08:28 PM | #18 | |
11-28-2007, 08:34 PM | #19 | |
edit: you bitches should invest in a consult adapter
11-28-2007, 08:47 PM | #21 |
hooks up to the factory consult port on nissans from ~89-99, its a diagnostics port
http://www.plmsdevelopments.com/consult_if.shtml
11-28-2007, 08:51 PM | #22 | |
Same as everyone else said. Do a compression test, check your injectors, and if you have a few bucks put a new temp sensor on it. Do not fall for the $80 SR ones since the KA uses the same one, and it cost like $15-$25 at any auto part store. Is the exhaust black? How long have you been running the engine? (If it's a recent swap you could have bought a defective ECU etc.)
11-28-2007, 08:59 PM | #23 | |
And the exhaust, when I or anyone else sees smoke, is white. It hardly ever smokes. |
11-28-2007, 09:36 PM | #25 | |
^^^ Very possible. My old sr would have a little bit of white smoke coming out of the tail pipe and wreaked of raw gas, when it was running rich.
11-29-2007, 03:04 PM | #26 | |
so, compression check, check injectors, and replace the temp. sensor. |
