11-28-2007, 11:03 PM | #1 |
trans wiring / ground help please
im doing an SR20DET swap and im in the process of doing my trans,alternator,starter wiring..i got the starter all wired up and the alternator..but a few of my clips that go to my tranny are cut, does anyone know where i can find a diagram or a color code to match up some of the clips
and just checking...how many grounds should i have on my motor? what are all the things i should ground? |
11-28-2007, 11:17 PM | #4 |
Should be matching colors then because you dont switch the clips on the harness you switch them on the tranny. If its pulled out of the clips with no access wire look at it in the FSM.
11-29-2007, 09:23 AM | #6 |
Yeah look in the Factory sercive manual should have what wire goes where. Wiring is a bitch unless you have rewired a 240sx before gonna have to do research or get a new lower harness. FYI best bet would prolly be a junk yard.
