Old 06-17-2012, 05:31 AM   #391
Breitling
Breitling is an unknown quantity at this point
Originally Posted by lillit86 View Post
Is it possible to widen/relip a set of Nismo LMGT2s?
I believe that is quite easy.
On the easy side, the lmgt2 appear to be multipiece so it may be as easy as dissassembly and reassembly with a wider barrel.
On the medium easy side, they are 3 piece welded and can be cut apart, grinded down, and rebarrelled. Thats what i had done to my Fabulous wheels.
On the tougher side, they are a 2 piece wheel where they can cut the center out of the OEM welds and make the center singular so it can be used and made into a 3 piece wheel. My local guy does this also.
and, on the very tough side (not the case of the LMGT2) My local shop wheel Medic cuts and widens one piece wheels wheels regularly. so yes. anything is possible as logn as you have the money to do it.
EDIT - I do not work for Wheel Medic, I am just a VERY satisfied customer.
Ls460, 240sx, Super Avenger, Chronofighter, Navitimer
Breitling is offline   Reply With Quote
Old 06-17-2012, 05:35 AM   #392
Breitling
Originally Posted by MarcD View Post
Anyone know if Minerva's are welded?
Disclaimer, i dont know the answer.
I dont know if they are or aren't. i do know that you shouldnt worry, becayse... many people can cut the welded 3 piece wheels with zero issues and then re-lip them. Buy em!!
Old 06-17-2012, 05:57 AM   #393
MarcD
MarcD's Avatar
MarcD is an unknown quantity at this point
Many people in the U.S can cut and weld them, the U.K is, as always about a decade behind the current trend.
Instagram:@marcjzx
MarcD is offline   Reply With Quote
Old 06-17-2012, 06:06 AM   #394
Breitling
They did mine on a metal lathe. Do youi have access to a metal lathe?
Old 06-17-2012, 06:28 AM   #395
MarcD
MarcD's Avatar
Not one big enough for a 19" rim.
Instagram:@marcjzx
Old 06-17-2012, 07:00 AM   #396
Breitling
read post 11....
then read post 12....
Disassembling SSR Wheels - ClubRoadster.net
I would contact SSR and ask specifically about the Minera in that size. My Fabulous Profounds were welded. If you refer to post 12 in the link i sent you may see contradicting terms. That might be because someone once had the non-wleded ones rebarreled.
EDIT- then i found this...
Rebuilding SSR Professors - StanceWorks
I bet they are welded.
Send them to me, my hookup will cut them for 25 per wheel.
Old 06-17-2012, 07:09 AM   #397
MarcD
MarcD's Avatar
Thanks man.
I might pick them up anyway and find out, they're only cheap. I'm sure there must be some one close to me with a big lathe, it's just finding one that'll do it.
Instagram:@marcjzx
Old 06-25-2012, 10:41 AM   #398
JN1AS44
JN1AS44's Avatar
JN1AS44 is an unknown quantity at this point
Originally Posted by Breitling View Post
here's what I did. 18x9 +36 to 18x11.5 +4 (im running the 18x10 rears in the front)
Wheel medic did a great job. local, no shipping costs, fast turnaround, good prices.
What Size Lips did you end up ordering for your 18x9+36 Setup? Also what did they charge? Thanks Man
JN1AS44 is offline   Reply With Quote
Old 06-25-2012, 10:53 AM   #399
Breitling
I took the 18x9 +36 and put on an 18x6 lip thus making it 18x11.5 +4 (that's a 18x5.5 inner and 18x6 outer).
The whole job was 617.00 out the door including disassembly, cutting the welds, new/better wheel hardware, reassembly and a mount and balance of new tires.
I have a spare set of 18x5 outer lips if you want... but he can get 18x6 if you want those too.
Old 06-26-2012, 09:53 AM   #400
JN1AS44
JN1AS44's Avatar
Thats not bad... I want to do the Work myself since i have access to a lathe and other machining Equipment, My Wheels Are SSR Vienna Courage, Im Sure the Lips are different from yours. I'll call them and see if they would sell me just the lips. My Inner is Exactly the same as yours and your wheel size is what im looking for. Thanks For the info man!
Old 06-26-2012, 10:09 AM   #401
BoostinEuros
BoostinEuros is an unknown quantity at this point
18x10 et17
To 18x11.5 et-2
6.75" barrels, 4.75" lips.
Thanks to Enha.eu!
BoostinEuros is offline   Reply With Quote
Old 06-26-2012, 10:35 AM   #402
Breitling
40 hole lips are fairly universal. Ask for Bruce when you call. Tell him bob with the 240sx sent you. He will hook you up if you mention me
Old 06-26-2012, 10:46 AM   #403
JN1AS44
JN1AS44's Avatar
Your The Man! Thanks!
Old 06-26-2012, 11:47 AM   #404
Highway Riding
Highway Riding is an unknown quantity at this point
Considering this on a set of PIAA Rozza's 19X8.5 19X9.5 (high offsets and not known yet) to 19X9.5 for front and 19X10.5 or 11 for the rears.....
The Sun Rises in the East!
Highway Riding is offline   Reply With Quote
Old 06-26-2012, 12:27 PM   #405
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
why dont you just use the rears for the front lol so u dont have to rebarrel both just run a spacer if the offset is to high. No point on wasting that much on those rims
Old 06-26-2012, 12:34 PM   #406
Highway Riding
Dude didn't even think of that as I'm considering the set.. Ya know this is why I love the forums... That was easy (inserts stupid staples sound)! Sometimes the easiest routes
Thanks from a another NJ bro
Old 06-26-2012, 01:00 PM   #407
Breitling
BTW, if anyone is selling 18x5 or 18x5.5 inners... i need a pair used. ihave 18c6 for trade or i cna just buy outright
Old 06-27-2012, 12:38 AM   #408
kriss
kriss's Avatar
kriss is an unknown quantity at this point
were 9 +38, now with new front lips to make them 11 +13
kriss is offline   Reply With Quote
Old 06-27-2012, 04:26 AM   #409
Breitling
50mm overfenders and you are golden
Old 06-27-2012, 01:45 PM   #410
mattheripper
mattheripper's Avatar
mattheripper is an unknown quantity at this point
I have some Veilside Andrews that I'm pretty sure are 40 hole, but there is only 39 actual holes and the valve stem comes out right where the 40th hole would be. They're 18x9 +5 iirc, that I want to make 10.5, so adding 1.5" to the front lip which would make them -17,18 or something.
If they are 40 hole, how do I get these fairly universal lips 1.5" bigger? Thanks in advance man. I did keep up with like the first 5 or 6 pages but lost track and just want to get this question out there, while I'm catching up lol.
P.S. Kriss I love your six spoke, what are they? I'd like to get some to make an awesome mismatch for my Andrews.
mattheripper is offline   Reply With Quote
Old 06-27-2012, 10:18 PM   #411
kriss
kriss's Avatar
going 1.5" bigger lip will make them 10.5 -13 i believe
the wheels i posted are old Weds, no idea on model
Old 06-28-2012, 02:08 PM   #412
mattheripper
-13 would be good too. Where did you get the weds?
Old 06-30-2012, 10:19 AM   #413
williamb82
williamb82 is an unknown quantity at this point
picked them up today. need to find at least 2 more.
4 on the right are type b. 2 on the left are type c. idk what the difference between type b and c are. i can see no difference and measured everything i could. the centers are exactly the same. they clear the wilwood bbk. even the rear mounted valve stem clears the caliper. way more clearance than my 16in enkie 92's have.(ignore the dirty/rusty rotors, i have cadium plated ones to replace them with when im done with the car)
now to find at least 2 more, and then save the cash for all the new barrels and lips to make them 17x8 +12 and 17x9.5 +12
williamb82 is offline   Reply With Quote
Old 06-30-2012, 10:57 AM   #414
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Why do you need so many? Camryonbronze had twelve sets of his blitz 03s. I dont understand why you need so many for a re-lip?
Old 06-30-2012, 11:32 AM   #415
williamb82
i have 3 mk2 supras. i just bought another pair of 16's about 20min ago so have 2 full sets of 16in full reverse mesh now. 1 set ill have the outer lips widened 1in in front and 2in in rear which will make them 16x8 +12 and 16x9 0 for my 86 mk2 which is getting a built motor with side draft webers, hks cams, etc...
the other set is going to be redone to 17x8 and 17x9.5 +12 all around for my 84 supra which is getting the 2jzgte and lt1 t56 etc.. both have tilton twin plate clutches, 1 piece driveshafts, etc.., though the 84 has wilwood big brakes front and rear, the 85 will have z32 calipers front and stock rears (wont be anywhere near as fast as my 84 so doesnt need as much stopping power).
i also have an 85 mk2 which will get the 17x7.5/17x8.5 +4 all around staggered set of rota rb's i bought a couple years ago. then i have some 16x7 enkie 92's with 0 offset and some 15x7 american racing mesh with 0 offset. keeping those as id like to find a 77 celica liftback to build and maybe a 85 celica gts coupe as well.
Old 06-30-2012, 12:01 PM   #416
future
future's Avatar
Trader Rating: (42)
WTF? ^^^^
Ahshhseb
Old 06-30-2012, 01:42 PM   #417
williamb82
Originally Posted by future View Post
WTF? ^^^^
Ahshhseb
what part are you unable to comprehend?
Old 06-30-2012, 01:47 PM   #418
dazed
Trader Rating: (37)
dazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the rough
Feedback Score: 37 reviews
Why you are incapable of using the "enter" key.
Anyone have anymore pics of forged wheels that have had the faces cut ad put into a new barrel? Like the CE28's a couple pages back.
dazed is offline   Reply With Quote
Old 06-30-2012, 01:57 PM   #419
chuki.s13.coupe.
chuki.s13.coupe.'s Avatar
chuki.s13.coupe. is an unknown quantity at this point
Never mind..
chuki.s13.coupe. is offline   Reply With Quote
Old 06-30-2012, 01:58 PM   #420
chuki.s13.coupe.
never mind..
