Old 01-29-2008, 09:31 PM   #1
elemeno
elemeno's Avatar
elemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to allelemeno is a name known to all
S15 headlamps stopped working! (Searched!)
So I have a S14 w/ S15 front, bought it that way. Today the passenger side headlight and highbeam stopped working, only the small running lamp in between them works. I checked the bulbs, they're good, so I'm assuming a connector/connection is bad. but why is the one light working?? It's dark so I can't see the wiring too well, but what I can see looks OK. Is there a common place people splice in the wires? This ever happen to anyone else? Thanks for any help in advance.
elemeno is offline   Reply With Quote
Old 01-29-2008, 09:37 PM   #2
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
my driver side s15 light stoped working sometimes, so i rechecked all the wiring an found rust on the wires (bad connectivity) so i took a steel wool to the major wires and sealed everything tight with electrical tape.
now it always works after i done this.
silnismo is offline   Reply With Quote
Old 01-29-2008, 09:39 PM   #3
k's_silvia2.0
k's_silvia2.0's Avatar
k's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfection
Send a message via AIM to k's_silvia2.0
Check your harness for damage.Might be a ride height issue....you know to low and that harness is gone.
k's_silvia2.0 is offline   Reply With Quote
Old 01-29-2008, 09:48 PM   #4
elemeno
elemeno's Avatar
I am pretty low.... I'll have to check that, but hopefully it IS just a bad connection, thanks!
