03-18-2009, 08:23 PM | #872 | |
You won't need a spacer in the rear, and even 275s look stretched on a 17x10.5 wheel
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
03-18-2009, 08:24 PM | #873 |
Dude you've got the sexiest car!!
Its pretty much the exact car I pictured in my head as perfection.
DD: '05 Saabaru with full JDM STi 6spd swap Project: '91 S13 Hatch SR20 |
03-18-2009, 09:09 PM | #874 | |
Just something to keep in mind....all factors need to be considered before running out and buying a set of wheels (camber, tire width, etc.) What this thread really needs is more people posting up detailed specs (camber, tire sizes, what calipers, spacers?, how much of a roll, etc.), with detailed pictures of the inside and outside fitment and measurements of how much space is left. So far, you've probably contributed the most help (to me at least), but we need people with good setups to help out and get more visual evidence. I'll snap some pics of what's on the car now, but I'm still struggling with what sizes and widths to order from CCW.
11.0 @ 131 | LS1 | T56 Magnum |
03-19-2009, 01:33 AM | #875 |
My set up with the fat ohlins shock bodies in the rear would make contact at 187mm of true backspace. I'm sticking to the below quote from my build thread on the ultimate stock fendered s14 wheel:
"So lets call it a max frontspace of 115mm and a max backspace (only to the outertire edge, aka not true backspace) of 170mm would yield a wheel 285mm (11.22") wide. If you go any bigger you're going to have to do something drastic to your fenders. Also, to pull this off, your coils will probably have to sit higher than the tire. I would really like to own the redline time-attack street class some day. The current rules only allow tires upto 285s, and forbid inboard/cantilevered dampers. I think that a 11.22" wheel would be perfect for 285/30/18 tires. Personally I'd order up four of them all with the same <7.362" backspace and just use whatever spacer and fenders are necessary in the front. 11.22" wheel would also be just fine for 315s"
03-19-2009, 07:58 AM | #876 |
thanks for the help, so would 255's for the front be a better choice or would i need wider front fenders as well? for the rears what tire size would you recommend me to go with untill i get rear overfenders installed?
1991 240 5.3l 4l80e, s366 turbo in the works. |
03-19-2009, 11:05 AM | #877 | |
In the front 255s fit, but will of course require a little more fender pulling. I have 255 falken 615s on the front, mounted on my 17x9s, and I hate to admit this in the maximum tire thread, but they look a little goofy with their bulge compared to my rears. I almost wish I had gone 245s. In the falkens, the 245s are easier to get, and also have the reinforced side walls unlike the 255s. The reason I went with the 255s originally was of course for MAX RUBBER!!!, but also because they are 40 series, while the 245s only come in 45 series. And while wider the 255s are actually a little shorter, which is good. These are two of my favorite street tires right now. If you go with the R1R they actually make a 40 series 255! But they'll set you back at least $250 bucks more/set of 4 than the rt615s. 615:Falken Tire R1R:http://marktg.toyotires.com/file/30251.pdf And if we were all serious, you can see that toyo says their 275/40/17 will even fit on a 17x9! Now that is MAXIMUM rubber. Sorry there really is no clear cut answer for the front. 235-275 will fit on your 17x9 wheel. Now it's just a matter of what brand tire you want, and how much new front fender/R+P/spacer you're willing to do. If you want to just keep it simple get the 245s, and when you wear them out in less than a year re-evaluate how much room you weren't using to upsize, then post back here for the benefit of all. I'd stay with the 275s in the rear. If for no other reason than cost. It seams the second you go bigger than 275 the price of tires doubles.
03-19-2009, 11:41 AM | #878 |
apreciate the help! I thought the 275's wouldnt fit under just a rolled\pulled rear fender? ill check those r1r's out as well.
03-19-2009, 11:44 AM | #879 |
They will in the rear, I have no idea in the front of an s13.
03-20-2009, 01:03 PM | #882 |
i'm running 265/35/18's contisportcontact3 on the rear of my s14 on 18*10+15. im in the process of rolling and doing a lil pull. the question is, camber or no camber???...cuz tires are pretty expensive. anyone have pics that they wanna post with similar sizes and NO camber?
03-25-2009, 03:50 PM | #884 |
S14 currently on KYB AGX + Tein Springs.
Planning to switch to KYB AGX + PDM springs (1.8" drop all around) Wheels will be Work Emotion CR Kai 17x9 +17 front 18x9.5 +12 rear Not planning to run spacers, just a fender roll + some neg camber, no pull (if unnecessary) Will I have any tire rubbing issues/hitting the shock/fitment trouble if I run these size tires? 235/45/17 front 245/40/18 rear Let me know. Thanks a lot in advance
268generation.com -United for His Renown- |
03-25-2009, 04:35 PM | #885 | |
03-25-2009, 05:38 PM | #886 |
Im going to have to run 15mm spacers in the front to clear my brakes. Will this affect my handling alot? Or do I need to run 15mm spacers all around?
Wheel Specs currently are: 18 x 9.5 +24 all around Tire Specs are: F: 245/40/18 R: 275/35/18 |
03-25-2009, 06:32 PM | #887 | |
I went to the link for tire sizes/wheel sizes, but I'm not sure of my current offset. I'm on the OEM S14 5 spoke 5-lug wheels right now 16x6.5 unknown offset 225/50/16 tires If I guesstimate offset to 30, then I have 125mm of backspace I have approx 0.75"-1" of frontspace on the front I have approx 1"-1.5" of frontspace on the rear
268generation.com -United for His Renown- Last edited by EndLeSS8; 03-25-2009 at 06:51 PM.. Reason: frontspace |
03-25-2009, 06:50 PM | #888 |
I believe the stock wheels are actually +40.
03-26-2009, 01:29 AM | #889 |
Ok, with +40 I have 135mm (5.3") of backspace
235/45/17 front on 17x9 +17 245/40/18 rear on 18x9.5 +12 Backspace, I can fit, but frontspace is tight. Any ideas if it will fit?
03-26-2009, 05:56 AM | #890 |
those sizes are hardly pushing it. if you're willing to roll, you should be able to work them in there. just a tip, when someone criticizes you for wasting the time of other members on this board, it's probably not a good idea to come back with more questions that you could have answered yourself. and why are you calculating backspace for stock wheels?
suicidns13, wider track width generally leads to more grip at that end. if anything, just front spacers will reduce understeer. you could try just front spacers and see how it works and add rears later if needed. you'll probably notice the difference more visually than in handling though.
03-26-2009, 09:46 AM | #891 |
The reason why I was asking is because most people on Zilvia are running on coils, which leave more room than springs/shocks. I'm on springs/shocks and I plan on staying with them. I wasn't sure if it was going to fit. I couldn't of answered it myself. I'm calculating backspace for stock wheels because I'm currently on stock wheels.
03-26-2009, 10:19 AM | #892 | |
03-26-2009, 06:10 PM | #894 |
Ok... I've pored all over this thread and I think I've come up with my ideal wheel/tire setup. Let me know what you guys think! This would be for an s13 with stock fenders.
17x9+22 255/40/17 17x10+18 275/40/17 I'd like to go with brands known to run small, btw. Got any suggestions? Comments on the proposed setup? Will I be able to avoid massive rolling/pulling? |
03-26-2009, 08:55 PM | #895 |
are you going to run RPF1's? im guessing because of the +18. but you can get away with running a much higher offset in the back, like a +30 or +40, then you wont have to pull as much.
03-26-2009, 10:04 PM | #896 | |
03-27-2009, 08:04 PM | #898 | |
JRas, I would also love to run the 17x9.5+18 up front with 255 tires, but on an s13, I don't see how it could fit without destroying my pretty fenders trying to pull the hell out of them or ditching them for overfenders... |
03-27-2009, 08:45 PM | #900 |
That is so perfect.
