03-22-2008, 03:17 PM | #1 |
Drift Alignment Specs, show me!!!!
Hey guys, been playing around with the alignment specs as far as how i want the car to react like, I just thought....maybe i should ask my fellow zilvians to see what the drivers are running front and rear.
My current alignment spec is; Front Caster: Maxed out Front Toe: -.05 Front Camber: -2.0 Rear Caster: Oem Rear Toe: +.05 Rear Camber: -2.0 Give me some advice guys ....i really want an agressive spec alignment for the car to carry through easily in a turn with no fight.
03-22-2008, 04:00 PM | #2 |
My Setup is
Front Caster: 8.0 Front Toe: 0 Front Camber: -3.0 Rear Caster: Oem (Will take off 12mm like dousan was saying to do on ziptied) Rear Toe: 0 Rear Camber: -3.0 I wanna keep everything the same and maybe go -3.5 in front with -1.5-2.0 in the rear but megan ruca's suck. Thats just my personal setup I prefer I'm not telling you how to setup your car just what I like. Your prolly doing hi-speed 4th downshift 3rd gear turns with new tires in back and want more grip. Most tracks around here are lame but fun 2nd gear tracks. I like to be able to throw it and just mash it without to much stress kinda like my GT3 setups |
03-22-2008, 06:15 PM | #3 |
www.SonicMotor.com
Trader Rating: (113)
Feedback Score: 113 reviews
Track with elevation
Front: Camber -2.5 Toe: within factory specs caster: as close to factory as I can, right now its 7.4 or something... Rear: Toe: within factory specs Camber: -2 or -2.2 Flat track/street with no elevation changes: Front: Camber -2.5 Toe: within factory specs caster: as close to factory as I can, right now its 7.4 or something... Rear: Toe: within factory specs Camber: -0 For toe: people keep telling me to keep it within spec with a little toe out biased. I did a a few time. Didnt like how it felt on the freeway. For caster: It all depends on wheel clearance and what you are used to. Camber: obviously, more camber is better for grip Tire pressure and tire grip makes Crazy amount of difference when you drift.
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK ) Last edited by Sonic Motor; 01-06-2009 at 10:23 AM.. |
03-22-2008, 07:29 PM | #4 |
Nice nice....keep em coming.....
See my set up is pretty normal i guess, I have all the arms and links swapped out for full adjustability. My front and rear rims are 17X9.5J +17 offset with 25mm front fenders and 30mm rear quarters. Front wheels have 10mm spacers rear has 15mm spacers. I noticed with the setup i have, the highway drive is scary....but then again, it could be that one side my be slightly off then the other. I believe the passenger side tension rod is stuck, it won't budge one bit. Might be stripped. I have brand new Uras Tension rods going on, brand new Uras Inner tie rods and D-max outers
03-22-2008, 08:27 PM | #5 |
i like grip.
front castor 7.6 camber -2.0ish toe stock rear i dont touch castor camber is -1.0 or 1.1 toe is zero
sddrift.com - smirkis - poweredbymax.net |
03-23-2008, 09:04 AM | #6 |
anyone else might have their drift alignment specs to share with me....I need a few more advice, pretty much everybody so far is running similar to the same set-up.
03-23-2008, 12:55 PM | #7 |
Trader Rating: (44)
Feedback Score: 44 reviews
mine is dd with sum track time i gotta change it soon cuz it
wants to turn by itself fn's 17x9 +15 225/45/17 front rear 17x9+15 235/40/17 front cam.1.5 toe.0 cas.6.5 rear: cam 3.5 toe and cas stock front sus.is tein inner and outter tie rods kazama t/c rods yanack metal rack bushing alumi steering bushing nismo power brace new stock flca bushing megan street coils and tein strut bars
Red Rocket |
03-26-2008, 03:39 PM | #8 | |
so whoever left me neg rep saying "drift spec alignment, learn to read" is a fucking idiot.
03-26-2008, 06:12 PM | #9 |
www.SonicMotor.com
people at the Federal Drift event said...
Its better to have 0 to -1 degree camber in the rear. They said its better. And more air pressure in your tires for more smoke.
Check out our website! ( CLICK ) |
03-27-2008, 09:29 AM | #10 | |
This is giving me great idea's for my next setup....thanks guys, keep em coming...i still want to see more alignment specs!
03-27-2008, 09:38 AM | #11 |
www.SonicMotor.com
actually, from personal experience, like I said, I think for flat surface courses, its better to have more camber for more even wear.
03-27-2008, 09:47 AM | #12 |
completely agree with you.....thats the same thing i said in my post before, no elevation more camber!
04-11-2008, 07:57 PM | #13 |
i run -2.5 camber, 0 toe and 7* of caster in the front.-1.5 camber, 1/8 toe in and i dont know about the caster on the rear.i've got to get a better alignment done. cornor balanced blah,blah...im curious on the takeing out 12mm on the rear caster though. can you post a link to it please? i tryed going to ziptied, but the sites( or my office computer) is messed up.
04-16-2008, 07:27 PM | #14 |
Trader Rating: (81)
Feedback Score: 81 reviews
S13
Steering bushing, Megan street coilovers, all adjustable arms/rods/bars. 17 x 9 +10 225/45/17 front 17 x 10 +10 235/45/17 Front camber -3, Rear -1.5 Caster front is maxed out, rears is near OEM spec. Toe I cant remember but near stock on front and little aggresive on rear. I was getting good grip for about 80mph entries from 4th then downshift to 3rd. I was running Federal 595s. Alot will have to do with the tire you choose to run and like someone was saying before was tire pressure. This definately makes a big difference. If you need more grip in your front just lower the pressure and vice versa. This is pretty self explanatory. Same with rears. if you feel you need more traction, like the rear end is just sliding all crazy and shit drop that pressure like its hot. by the way, i also used to run a crazy camber on highways which was scary...i think like -5ish lol. every bump i hit the car wanted to steer. Looks good but not too fun to drive. Good luck with your future setups...By the way sorry for the long post but try to pick some good tires and stick with them so you can be more consistent. Nino |
05-06-2008, 04:18 PM | #15 |
Sorry, I know this is an old thread but I figure I'd post my alignement here...
I did myself today. Front Driver : 3 mm (toe out) ( 0.365* toe out) -0.21 camber Front Pass : - 3.1 mm (toe in) ( - 0.377* toe in) -0.12* camber Rear Driver : -0.5mm (toe in)(0.058* toe in) -3.92* camber Rear Pass : -1mm (toe in)( 0.121* toe in) -3.67 camber Notes: -Still going to play with my front camber, I just made the mistake of maxing out the coilover bracket outwards, and even with the top plate maxed inwards, i could only get that much negative camber out of it. I did like the way it drove though, super grippy front end. - the +3 / -3 toe in the front is because my wheel's werent straight, so obviously when the car straightens out, that becomes 0 / 0 (or does it? still going to double check it later) - rear camber not even: it's close enough, and the stock arms are a bitch to adjust. Overall, I'd say it's totally worth to take the time and do this yourself. It's a good learning experience, and you know how your car is setup. I'll leave it like this for now, try it out at the track sunday and report back to you guys with what changes have been made. Does anyone here run close to 0 camber in the front?
613DriftWerks.ca |
07-12-2008, 02:24 PM | #19 | |
May I ask why you are running so much Negative Camber in the rear?? How bad is your tire wear? Ive been seeing people run -3.5 camber in the front and between -1.5 -2.0
01-06-2009, 07:25 AM | #20 |
bump for more specs! I have a S13 fastback and want to know as much info as possible before I buy my wheels! I was thinking of going 17x9 (f) 17x9.5 (r) + 20 offset all the way around to be on the safe side. Any opinions???
06-05-2009, 04:29 AM | #21 | |
(i know this is an old post, but i just had to point this one out haha) |
05-18-2017, 09:21 AM | #25 |
Mike Kojima Recommends:
Front: -2 to -5 Camber 1/8-1/4 toe out 7-9 Caster Rear: -0 to -1 camber 1/8 toe in Furthermore: 2.5-3.5" bump travel 1.5-2" droop 28-32 PSI all around, adjust from there Wheel rate slightly stiffer in front than rear sway bar 20-50% stiffer in front than rear |
