Old 08-01-2013, 08:31 PM   #1
udall24
udall24 is an unknown quantity at this point
Rear end lights
So my problem is that the night running lights in the rear aren't running but the brakes are I checked fuses light bulbs could I be the switch on the column and if so how would you go about replacing it
udall24 is offline   Reply With Quote
Old 08-01-2013, 08:52 PM   #2
silviaks2nr
silviaks2nr's Avatar
Check continuity at the switch and if it's bad replace it.
Old 08-02-2013, 06:18 AM   #3
Mikester
Mikester's Avatar
You unscrew the shroud around the column, unscrew the turn signal/headlight switch, disconnect the connector... and put the new one in the same way you got the old out; but in reverse
Old 08-02-2013, 12:36 PM   #4
cotbu
cotbu's Avatar
Whoa whoa whoa!
Did we eliminate anything? looking at the bulbs isn't a verification. Are any of the other running light circuits functioning? side markers, dash illumination? If they don't work go ahead but damn just ripping shit apart wouldn't be my third step, XD!
