11-15-2010, 06:38 PM | #1 |
HELP, SR wont start
ok first off probably gonna get bitched and wined at with people sayin u didnt search but too damn bad. anways liek the title says my car refuses to start, a few weeks ago i got in it and it started right up i drove about 3 minutes and parked ran insaid my house for 10 minutes or so came back out and it has refused to start since. we just got it moved to somewhere where i can work on it with out laying in the middle of a very busy two lane road, hence the help my sorry ass thread.
things i know to try and help narrow it down for the nissan knowledge gods. good -brand new battery -fuel pump is working for sure bad -wont even try to crank, at all -cant clutch/roll/push start it -tried tappin the hell out of the starter and still nothin probably missin somethin, any help would be awesome and thanks ahead of time |
11-15-2010, 06:42 PM | #2 |
check all your fuses and relays. does the car gauges lights etc turn on?
Hitting the started doesnt necessarily mean it will jump back to life and start. A really bad started wont do shit even if you hit it with a hammer. Get that starter out and check at your local auto parts place who is capable of doing so. Re-check all wires and harness going to it and from it.
@dangerdamian |
11-15-2010, 06:45 PM | #3 |
OOPs
I see you tried to push start it and such. It should start even if it has a bad starter. Might be wiring. If it doesnt crank at all, or even try to start after being push. Then your culprit could be fuse/relay or loose wiring.
@dangerdamian |
11-15-2010, 06:53 PM | #4 |
see i knew id forget something, yes i have all electrical power inside, top of the engine, headlights, emergency flashers, brake lights(basically the whole 9 yards) and tomorrow were gonna check all fuses and such. is it a possibility its an issue in the lower harness?
11-15-2010, 07:16 PM | #6 |
Is your car lowered? or slammed i should say. If everything checks out, it could be your engine harness located directly under your wheel well. it couldve taken a toll on the wires.
relays, check everything that has to do with fuel and spark.
@dangerdamian |
11-21-2010, 01:12 PM | #9 |
Some issues I've had with mine in the past as far as starting issues were 3 really. If your sure your fuel pump is mint then I'd rule that out. The another one I had was my ignition. It's still botched after a year and a half but I figured it out. When you turn the key with the clutch in it wont do anything at all, UNLESS you turn the key a specific way. I have to put pressure on my key in a downward motion as I turn it to make it start lol. So if it aint cranking you may wanna try to fidget with your key. Another issue could be your Cam Angle Sensor. I swapped one out in my SR a few months back and didnt set the notches correctly and it would crank but not fire at all. So reguarding this, If your C.A.S. is bad or simply out of whack, that could result in a non turning over issue. Also check your battery grounds and engine grounds ect, ect. A single ground could cease your car from turning. Hope this helps some.
11-25-2010, 03:34 PM | #10 |
havent had the spare time to check out frounds, fuses, relays and such but could my turbo timer prevent my car from starting? it has never worked the way its supposed to since i bought the car, guy i bought it off of installed it. at times it would randomly lock me out for 30 seconds when i tried to start it and i would have to wait till it counted down before it would let me start. whenever i try to start now it flashes and begins counting down?
11-25-2010, 04:49 PM | #11 |
Trader Rating: (50)
Feedback Score: 50 reviews
I had a very similar problem. Try thr ground that connects to ur starter. Mine was loose and then it didn't want to start. Check fr corrosion as well on the ground plugs.
Could be electrical problems.
"get that nacho out of my face" |
03-03-2011, 12:38 PM | #12 |
resurrected from the dead, the culprit was a bad slave cylinder, so 4 months, countless headaches and cussing fits, and 20 bucks later she lives again. Thanks everyone for ur help
