Old 09-03-2014, 09:04 AM   #4381
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
Originally Posted by SinCityS14 View Post
Sky80 what did you do for wiring? You did it yourself?
Tweak'd did my harness and highly recommend them if you are looking for a place to get it done.
If you are doing it yourself contact rswails on here, he was working on a how to guide I believe.
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 09-03-2014, 10:06 AM   #4382
ehp
ehp is an unknown quantity at this point
tweakd also did my harness as well. its a bit expensive bit worth the price imo
follow my build on instagram: s14project
ehp is offline   Reply With Quote
Old 09-03-2014, 01:56 PM   #4383
SinCityS14
SinCityS14's Avatar
SinCityS14 is an unknown quantity at this point
Ehp following you on IG good stuff.....im ThatTrdS14
G37s - Dropped on DPE 20's - $old
S14 - Bone stock
SinCityS14 is offline   Reply With Quote
Old 09-04-2014, 12:47 AM   #4384
jackal264
jackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud of
i need help.
my car won't fire. i already know it's the injectors not firing.
fuel is getting to the rail
i'm running bosch 750cc high imp
the injectors fire if i use a 9v battery to test the solenoid. so they are not stuck.
the harness is all custom.
i have deleted the stock resistor box. i run a direct 12v line from ignition to the injectors and then from the injectors directly to the ecu.
with ign on i get 12v at the injector plugs.
my multimeter isn't able to see the ecu pulse but i'm getting my hands on a noid set tomorrow.
ecu is an aem v2 and i have used the wizard to select the correct injectors
ideas?
jackal264 is offline   Reply With Quote
Old 09-04-2014, 08:40 AM   #4385
supercompact
supercompact is an unknown quantity at this point
Originally Posted by jackal264 View Post
i need help.
ideas?
You might check your cam and or crank angle sensors. I believe the injector pulse is based on one of those sensors.
supercompact is offline   Reply With Quote
Old 09-04-2014, 08:44 AM   #4386
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Had the same issue with mine. Turned out to be a setting in the V2 that was off. I'm running FIC 775cc high imp and AEM V2. Have someone knowledgeable With the v2 look at it
BiG MiKE86 is offline   Reply With Quote
Old 09-04-2014, 04:41 PM   #4387
jackal264
they are based off the crank sensor and i've cheched the log files and the sensor is working fine. it counts all 24 teeth.
Old 09-04-2014, 06:18 PM   #4388
Sky80
Sky80's Avatar
You said the harness was custom, did you check every connection back to the ECU with a multimeter?
Old 09-04-2014, 09:34 PM   #4389
jackal264
yes. everything seems in order.
trying to get some help with the aem as per big mikes suggestion
Old 09-05-2014, 02:32 PM   #4390
Johnphen
Johnphen is an unknown quantity at this point
Try these links :
2JZ wiring - http://tinyurl.com/lo7j7ry
2JZ wiring in s14 - http://tinyurl.com/n2ude5j
Johnphen is offline   Reply With Quote
Old 09-06-2014, 04:35 PM   #4391
Sky80
Sky80's Avatar
Originally Posted by Johnphen View Post
Try these links :
I'm sure the s13/14 side of the wiring from those links would come in handy but he was asking about a 2j VVTi which is a wiring nightmare compared to the non VVTi.
Old 09-08-2014, 01:04 AM   #4392
SinCityS14
SinCityS14's Avatar
thanks guys looks like all signs point to tweak'd performance
S14 - Bone stock
Old 09-10-2014, 05:28 PM   #4393
bpat
bpat's Avatar
bpat is an unknown quantity at this point
how bad is this?
bpat is offline   Reply With Quote
Old 09-10-2014, 05:31 PM   #4394
ThanatosG
ThanatosG is an unknown quantity at this point
Wow hard to tell. Did this sit for awhile?
I'm sure it can be bored out. maybe even just honed. Hard to tell in the picture.
ThanatosG is offline   Reply With Quote
Old 09-10-2014, 06:03 PM   #4395
erics240sx
erics240sx is an unknown quantity at this point
Originally Posted by bpat View Post
how bad is this?
Rub your finger over it. If it feels smooth you'll be fine. Keep it oiled as much as possible.
Looks like it was honed recently. It Dosnt look bad at all.
erics240sx is offline   Reply With Quote
Old 09-10-2014, 06:38 PM   #4396
bpat
bpat's Avatar
I'm guessing it sat for awhile since it came from japan. Hopefully getting honed out will do the trick.
Old 09-10-2014, 06:44 PM   #4397
ThanatosG
Wonder if it sat with plugs out? Did it have plugs when you got it? Mines a jdm motor, but there were no marks like that. I'm in the process of rebuilding mine.
Old 09-11-2014, 07:15 AM   #4398
bpat
bpat's Avatar
plugs were out when I got it but that was from someone local, not sure about when he got it from the importer. Had to rebuild my head already and now I get this problem from the block project cars suck
Old 09-11-2014, 07:32 AM   #4399
ThanatosG
Ya my motor was in good shape. But I could tell the valve seals were worn in a couple cylinders. But I'm an overkill kind of guy. So I'm doing a full build. I need to start a build thread. Ha
Old 09-12-2014, 02:12 PM   #4400
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
So over the past few weeks i've noticed some poor connections on the wiring to the connectors due to the OEM 20 year old terminals going bad, Anyone know a place i can get a bunch of terminals for wiring for a decent price other than Elmhurst Toyota?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 09-12-2014, 04:04 PM   #4401
turbo-2ns
turbo-2ns is an unknown quantity at this point
Each plug has a number on it you can Google the numbers and find the plugs, think I paid about $130 for every plug on the harness with pins and little rubber insulator things
turbo-2ns is offline   Reply With Quote
Old 09-12-2014, 04:08 PM   #4402
supercompact
Tweak'd performance has most of the plugs on their site.
Old 09-12-2014, 06:08 PM   #4403
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
why are you saying the vvti is a wiring nightmare?
JohanM is offline   Reply With Quote
Old 09-13-2014, 09:51 AM   #4404
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Im pretty sure Wiring Specialties can get you all brand new plugs, you should hit them up.
Old 09-15-2014, 08:14 AM   #4405
JohanM
JohanM's Avatar
did a rear mount rad, car runs great and cools down fast, but what a pita it was to bleed lol
Old 09-16-2014, 11:14 AM   #4406
Sky80
Sky80's Avatar
2JZGTE Swapped S-Chassis thread
Have you compared to a non VVTi? Not saying it's impossible but it's no walk in the park 9 wires like the non VVTi
Old 09-16-2014, 11:29 AM   #4407
jamg
selling some of these.
anyone interested?
black ice smell
Old 09-16-2014, 01:38 PM   #4408
BiG MiKE86
BiG MiKE86's Avatar
Having trouble with my Dakota Digital SGI-8 (Tach Signal Converter) I plugged in into my wiring specialties harness that had the leads for it and Im getting no movement to my tach. The box lights up (flashes). Im running AEM V2, wiring specialties harness, Non-vvti 2JZ-GTE, JDM Cluster, S13. Any ideas? Anyone have the settings for the DD box?
Thanks
Old 09-16-2014, 03:36 PM   #4409
JohanM
JohanM's Avatar
i have compared it to a none vvti and it was only 2 additional wires.
Old 09-17-2014, 02:52 PM   #4410
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
How is you brake booster ran? My 2j has the port on top of the intake plenum but we just picked up my wife's 2j and it doesn't have the port
Follow me on Ig- Andydennington
91ka24 is offline   Reply With Quote
