03-18-2016, 11:29 AM | #1 |
Trader Rating: (29)
Feedback Score: 29 reviews
Enjuku Racing - Wiring Specialties VH45DE Wiring Harness
Wiring Specialties VH45DE Wiring Harness for Nissan 240SX S13 - PRO SERIES Starting at $649.00 This Wiring Specialties Pro Series Wiring Harness includes the engine and transmission harnesses for a Nissan 240sx S13 with a VH45DE engine swap. It was developed in house on an actual VH45DE engine and comes tucked for a clean finish. The harnesses is designed as a one-piece unit with integrated OEM COIL, Injector and transmission harnesses for clean install. Engine: Infiniti Q45 VH45 Any VH45 from 1990-1995 Infiniti Q45 WILL work on 1996 model with adjustments Chassis: S13 240SX Any S13 240sx manufactured in 1989-1994 (Including the Convertible and ABS cars) PRO-SERIES HARNESS FEATURES Plug and Play Significantly lighter than a factory harness NO CORE HARNESS or additional wiring required REQUIRES use of NEW style Ignitor Chips REQUIRES use of OEM Coils Available with New or Early style injector connectors Available with New or Early style CAS and TPS connections Constructed using OEM connectors and seals Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing Wrapped in lightweight nylon loom with -94C to +257C operating temperature Includes a charge harness and improved grounds Fully tested after production for an easy plug-and-play replacement Turn Key ENGINE START Guarantee Tech support for our customers 7 days a week. PRO-SERIES HARNESS INCLUDES One-piece design with integrated Coil, Injector and transmission connectors Alternator charge cable. Nissan Diagnostics connector. Power and dash interface connectors. Retains factory A/C,speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers. Our Pro-Series is ideal for those looking for the best aesthetics, weight savings and reliability. Completely replace your old harness and forget about electrical gremlins
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] |
