06-23-2013, 11:57 PM | #1024 |
quick question, my first swap. When making the custom throttle cable bracket for rb20 in s14. how much of the throttle body needs to be open or is it fully closed position ?
06-24-2013, 03:20 AM | #1025 | |
Where ever the butterfly valve sits with no cable connected is where it should be with a cable connected.
06-24-2013, 10:05 AM | #1026 |
07-14-2013, 08:17 PM | #1028 | |
07-18-2013, 09:36 AM | #1029 |
Can the Rb26 damper pulley work on a Rb20? I know the 25 can just need to change the powersteering pump belt from 4 tooth to 3 tooth.
WTB: Dmax Coupe roof spoiler.
07-18-2013, 01:38 PM | #1030 |
Have you tried this personally? Cause apparently dozens of people have used the na 300zx speed sensor with no problems. There could be a chance they keep the rb25 sensor and swap the gears on the ends. I will post back when I finally get the speed sensor. It's kinda last on the list.
07-22-2013, 06:45 PM | #1031 | |
07-22-2013, 08:00 PM | #1032 | |
07-31-2013, 03:21 PM | #1033 |
I have a rb20 trans and I am missing the throw out bearing, clutch fork and throw out bearing collar and the ring that holds the clutch fork onto the collar and on the pivot ball.
Can I use the ka24de one? For all of those? I also need to find an OEM igniter chip for it too. I have an rb25 and z32 one and I know you can repin your harness, but I don't want to do that. I just want to have an oem one. Doesn anyone know where I can get one or have a factory part number? |
08-12-2013, 05:19 PM | #1035 |
OK, I know the RB25DET and the z32 N/A have the same clutch, but exactly what year do you have to go with?
09-05-2013, 09:38 AM | #1036 |
RB20 and KA transmissions are almost the exact same thing, minus the bell housing. I used a KA pilot bushing and throw out bearing on my rb20 swap, so I would imagine that the collar is the same as well.
09-15-2013, 09:25 PM | #1037 |
What Maf adapters is everyone using on there rb20? I've heard of using 300zx MAF adapter but some ads on ebay have 2x3.75" dimensions which is alot smaller then my rb20 MAF?
Any suggestions? thanks |
09-23-2013, 09:26 PM | #1038 |
got a lil problem....just got done doing all the IC piping work on my rb20 swap and i go to start the car it would not start. Before IC piping...it started just by holding/covering the intake j pipe for creating some restriction. But now it do not start. not sure what would cause this problem. i have fuel/spark. Tried adjusting the timing at almost all the different positions still no luck. any suggestions would be appreciated. thanks
09-23-2013, 11:54 PM | #1039 |
Do you have a bov? What's your fuel pressure?
Try to step on the throttle when cranking. Might be flooded. Take out the pump fuse then crank to get rid of the extra fuel. |
09-26-2013, 07:29 AM | #1041 | |
yes I have the stock bov and i dont have a fuel pressure gauge. yesterday I pulled all the spark plugs. I noticed first plug was clean but all other cylindersl plugs were dirty from carbon. so I pulled out the fuel rail and tested if all injectors were firing. no. 1 was ejecting slightly less fuel then others. so I went and replaced with spare injector I had. put it all back together and tried to start it but still wont turn over. also checked each spark in all cylinders. and its good so im stumped. |
09-26-2013, 07:32 AM | #1042 |
my battery ran out of charge I will give it another try adjusting CAS but at this point its timing or I dont what. so any suggestions as for what to look out for?
09-26-2013, 10:19 PM | #1046 |
it started once about a month ago. but I didnt had my ic piping on...now that ive got them hooked up it won't turn on. fuel lines should be on correctly but I will double check them.
it almost wants to fire up but doesn't |
09-26-2013, 11:29 PM | #1047 |
Maybe the ecu has some codes, do you have your CEL wired in? Remove your neg battery cable for 15-30mins, that should clear the ecu. How are your grounds? I know with my maf wiring if I messed with it too much it would run weird for a bit, glad I went to map. Maybe a new set of plugs? How is the fuel pressure?
09-27-2013, 08:54 AM | #1048 | |
Wiring part should be okay as i went with the Brand new Wiring Specialities Harness. I did replace the plugs on it with ngk bcpr6es-11. I dont have a fuel pressure gauge so i am not sure on the fuel pressure. thanks for the help man! |
09-27-2013, 11:34 AM | #1049 |
No problem man, these rb's are bastards sometimes but I wouldnt trade my rb25 for another motor! well maybe an rb30 but thats different haha.Now it's starting to sound like a sensor or your timing is off. Have you checked the timing?
09-28-2013, 10:28 PM | #1050 |
ok so i had the fuel lines wrong. it started and kept dying then i disconnected the MAF and it would start up on couple trys but would idle/rev by itself. Also sometimes it would just not start. and one time it started with MAF connected.
I am suspecting that the MAF and TPS is possibly faulty? |
