07-11-2008, 10:14 PM | #1 |
Just bought a cheap set of coilovers-question though!
What else do I need to get in order to install them? Any replies will be greatly appreciated. Thankks
07-12-2008, 09:49 AM | #11 |
If it's a true coilover, it will replace your entire spring/ strut assembly. If that's the case it should just bolt on. If it's some kind of ghetto fabulous adjustable lowering spring, it's probably a waste of time, and possibly unsafe to use on your car. But, in that case you'd need to take apart the stock struts, and replace the spring with yours.
07-12-2008, 10:07 AM | #12 |
its not even worth it to put those cheap things on your car. Buy real coilovers or at least a real set of springs.
95 SR Zenki | @ e_form daily - A34 Maxima | A36 Maxima |
07-12-2008, 10:46 AM | #13 |
You don't need a double height adjustable setup if the strut housing has the right dimensions to start with. The only thing I'd be wary of is those cheap ebay collars/perches using very cheap aluminum. I've seen some Chinese knock-offs that started bending in short order where they contacted the spring perch due to the aluminum being soft.
