Old 03-26-2015, 10:01 PM   #39721
YOSHIKOUKI
YOSHIKOUKI's Avatar
YOSHIKOUKI is an unknown quantity at this point
Send a message via Yahoo to YOSHIKOUKI
uploadfromtaptalk1427428708123.png power
YOSHIKOUKI is offline   Reply With Quote
Old 03-26-2015, 10:19 PM   #39722
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
I'm not trying to derail this thread so I'll make this quick. Eventually I'll post a proper write-up on wiring HIDs. PM with questions if you have any.
A diode is an electrical check valve. It allows power flow in one direction but not the other.
I've scribbled together a little diagram to illustrate the diode method. Keep in mind, I've never actually used this method. I don't have HIDs on my cars. After studying the FSM, the diode method is the best I've come up with and the one I'll be using in the future.
As you can see, the diode is in place to allow power to come in on the high beam wire, yet does not allow power to backfeed when power is coming in on the low beam side.
This is what would happen without the diode. With the lighting switch set to low beam, power would flow to the HID but would also backfeed onto the high beam wire. Since the high beam wire is also connected to the high beam bulb, it would obviously illuminate. Without the diode, you would have no low beam setting. Both high and low bulbs would be illuminated in either switch setting.
One might argue that a diode should be installed on the low beam wire as well. The other end of the low beam wire won't be connected to anything (except the lighting switch) so the diode shouldn't be necessary.
And my thread contribution.
dbeiler is offline   Reply With Quote
Old 03-27-2015, 08:02 AM   #39723
hpi10
hpi10 is an unknown quantity at this point
Originally Posted by aoshi1 View Post
Damn. So nice. Subtlety isn't played out like that anymore. Good post man ^_^
17 or 18s?
hpi10 is offline   Reply With Quote
Old 03-27-2015, 08:03 AM   #39724
hpi10
Originally Posted by Lukasss View Post
17 or 18 s?
Old 03-27-2015, 10:18 AM   #39725
Zenki525
Zenki525 is an unknown quantity at this point
Originally Posted by hpi10 View Post
17 or 18 s?
18x9.5 +15
Zenki525 is offline   Reply With Quote
Old 03-27-2015, 10:22 PM   #39726
hellaslows13
hellaslows13's Avatar
Trader Rating: (28)
hellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enough
Feedback Score: 28 reviews
wavybert / zenki / build thread
hellaslows13 is offline   Reply With Quote
Old 03-27-2015, 10:30 PM   #39727
mad-ass
mad-ass's Avatar
That's the diagram I came up with in 2013 after a bit of conversation on the lighting thread.
http://zilvia.net/f/showthread.php?t=462293&page=17
I ended up omitting the capacitor because it was simply not needed.
I've been using this setup since then on my Zenki and just got done with another one few month back using same method.(used TRS Mini H1 projector with the bi-xenon setup.)
Old 03-28-2015, 11:14 AM   #39728
dbeiler
dbeiler's Avatar
^^^ Good stuff. I intended to use a diode with a much higher amp rating, but I'll use the one you listed since it's been proven sufficient and has a minimal voltage drop as compared to the larger diodes.
Old 03-28-2015, 02:01 PM   #39729
TMW
TMW's Avatar
TMW is a well-known jackass
throwback
@tannermwilson
TMW is offline   Reply With Quote
Old 03-28-2015, 04:39 PM   #39730
mad-ass
mad-ass's Avatar
I should also note that my low beam HID's are on their own power system with relay and separate fuse, so 1A rating diode was sufficient enough. How ever my friend's light I just got done with is getting powered off of OEM harness with out separate power source, haven't seen any downfall of the system just yet, but how often do you use the damn highbeams?
Old 03-29-2015, 12:38 AM   #39731
Russ
Russ is an unknown quantity at this point
Russ is offline   Reply With Quote
Old 03-29-2015, 01:01 AM   #39732
jerry_beans
jerry_beans is an unknown quantity at this point
This shit right here is bonkers! Well executed!
IG @jerry_beans_
jerry_beans is offline   Reply With Quote
Old 03-29-2015, 01:05 AM   #39733
jerry_beans
Originally Posted by hellaslows13 View Post
Ooof! I'm a sucker for deep equips!
IG @jerry_beans_
Old 03-29-2015, 10:17 AM   #39734
justin240s14
justin240s14 is an unknown quantity at this point
Talking
Worked like a charm thank you very much
justin240s14 is offline   Reply With Quote
Old 03-29-2015, 10:20 AM   #39735
justin240s14
Talking
Worked like a charm bro tyank you very much !!!
Old 03-29-2015, 11:29 AM   #39736
hpi10
are this 18 or 19 wheels? thx guys
Old 03-29-2015, 01:07 PM   #39737
seagrasser
seagrasser is an unknown quantity at this point
18's; 350z anniversary rims
S14 RB25
seagrasser is offline   Reply With Quote
Old 03-29-2015, 01:23 PM   #39738
Corbic
Corbic's Avatar
Originally Posted by Russ View Post
Yes!!
Old 03-29-2015, 03:42 PM   #39739
iHateMySilvia
iHateMySilvia's Avatar
Trader Rating: (30)
iHateMySilvia is an unknown quantity at this point
Feedback Score: 30 reviews
naVanBros
NaVanBrosガレ​​ージLtd,Co.
iHateMySilvia is offline   Reply With Quote
Old 03-29-2015, 11:20 PM   #39740
hpi10
Thanks man, its yours??
Old 03-29-2015, 11:29 PM   #39741
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Got her last week. Started stockpiling parts already
Old 03-30-2015, 06:42 AM   #39742
ExtraGoodness
ExtraGoodness's Avatar
ExtraGoodness is an unknown quantity at this point
ExtraGoodness is offline   Reply With Quote
Old 03-30-2015, 07:57 AM   #39743
yomisiu
yomisiu's Avatar
yomisiu is making a name for him/her selfyomisiu is making a name for him/her selfyomisiu is making a name for him/her self
sp0.0ky ghost in the passenger seat
yomisiu is offline   Reply With Quote
Old 03-30-2015, 08:44 AM   #39744
drumer_boy456
drumer_boy456's Avatar
drumer_boy456 is an unknown quantity at this point
woah just seen that!
drumer_boy456 is offline   Reply With Quote
Old 03-30-2015, 11:47 AM   #39745
do it sideways
do it sideways's Avatar
do it sideways is an unknown quantity at this point
Anyone know where I can get uras type 2 , real or rep bodykit anywhere? I want it so bad!
I found them for kouki but not for zenki.
do it sideways is offline   Reply With Quote
Old 03-30-2015, 12:03 PM   #39746
bigs
bigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of light
http://uras.co.jp/Shop/html/products...roduct_id=1208
bigs is offline   Reply With Quote
Old 03-30-2015, 12:12 PM   #39747
Corbic
Corbic's Avatar
$680 dayummm
Old 03-30-2015, 12:21 PM   #39748
TheRealSy90
TheRealSy90's Avatar
thats cheap!
Such a good signature.
Old 03-30-2015, 02:07 PM   #39749
do it sideways
Noice thanks! what's the best way I can get it shipped to the U.S?
Old 03-30-2015, 02:50 PM   #39750
yomisiu
yomisiu's Avatar
gtr-garage has a shipping container service for big parts
