Old 12-29-2013, 09:44 AM   #2791
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
Originally Posted by InsTanCeZ View Post
This is actually very common in drifting because a wide front track is needed for more steering angle.
specs here are 17x9-35 (-10 w/ 25mm extended FLCAs) front and 17x9+15 rear I believe. lol
lolll
wider front track is for stability and turn in
the added camber is beneficial when you're at full lock.
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 12-29-2013, 12:22 PM   #2792
Mrjbrown07
Mrjbrown07 is an unknown quantity at this point
Hey guys. I'm trying to fit wheels that are 17x9.75 +25 on my s13 hatch. Any suggestions on what size spacers I should use?
Mrjbrown07 is offline   Reply With Quote
Old 12-29-2013, 12:57 PM   #2793
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
They might fit without it. If not, 5mm should be more than enough to clear suspension.
CLICK HERE!!!
Old 12-29-2013, 01:50 PM   #2794
VegasDrifterS13
VegasDrifterS13 is an unknown quantity at this point
Rears will be Damn Close to suspension if not touching, possible 5mm slip on spacer.
Fronts will be close, depending on your brakes you might need a spacer regardless and they will rub if you have any angle mods.
Sent from my SGH-T989 using Tapatalk 2
VegasDrifterS13 is offline   Reply With Quote
Old 12-29-2013, 01:50 PM   #2795
jamg
depends on the type of coils and how low you are.
i had to run a 20mm because i'm super low. the tires would hit the coils.
Old 12-29-2013, 02:55 PM   #2796
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
Originally Posted by ILoveJDM View Post
lolll
True but it's mostly for inner fender/tension rod/FLCA clearance.
ACE マジック HEART
InsTanCeZ is offline   Reply With Quote
Old 12-29-2013, 02:59 PM   #2797
InsTanCeZ
InsTanCeZ's Avatar
Originally Posted by VegasDrifterS13 View Post
Lol. Why do you think extending your LCA gives your wheel a different offset measurement. It Doesnt. Your still 17x9 -10 with a 25mm extended LCA. **NOT 17x9 -35 because of the LCA.** The offset is purely measured by the relation of where it mounts, it has nothing to do with suspension parts. FYI.
Dont need more noobs reading this believing your wrong info and then posting more ignorance thinking theyve learned something.
Of course it doesn't change your actual offset, I assumed that was common sense. It moves your wheel out 25mm more, which would be the same thing as having -35 offset for fitment purposes. I don't see why that information is relevant. We don't need noobs reading your comment and thinking extended FLCAs won't push their wheels out 25mm just like offset.
Originally Posted by fliprayzin240sx View Post
Umm...how would pushing the wheels further out big you more steering angle? If it anything, shit will be worst since you'll rub in anything and everything.
lolwut? More inner clearance = more steering angle and less rubbing. Pretty simple concept.
ACE マジック HEART
Old 12-29-2013, 08:17 PM   #2798
VegasDrifterS13
LMAO^^^ . It pushes the bottom out Giving it Permanent Camber. AGAIN THIS IS NOT THE SAME AS A SPACER CAUSING AN EFFECTIVE OFFSET OF -35. SOMEONE RETAINING STOCK LCA's USING A 25MM SPACER AND BOLTING ON YOUR WHEEL WILL FIT NOTHING LIKE IT DOES ON YOUR CAR.
AY YI YI. NOOB CITY. PLEASE READ UP ON WHEEL OFFSETS, SPACERS, EFFECTIVE OFFSETS, AND SUSPENSION PARTS. PLEASE EVEN POST THIS EXACT STATEMENT YOUR CLAIMING IN A THREAD OF ITS OWN. ID LOVE TO SEE WHAT IS SAID....
AT LEAST YOU KNOW HALF THE REASON WHY YOUR LCA WAS EXTENDED. THE OTHER HALF IS FOR THE CAMBER GAIN TO OBTAIN MORE GRIP THRU THE TURN AND ESPECIALLY AT FULL LOCK.
Old 12-29-2013, 08:24 PM   #2799
InsTanCeZ
InsTanCeZ's Avatar
Okay I know that. lol I'm studying mechanical engineering for motorsports right now. And yes it's still the same fitment as having -35 offset. If you put on spacers and added the same amount of camber by slotting your coilover mounts it would fit the same. (Your scrub radius would be different though most likely). IDK why you are trying to argue about this. Now we're clogging up the fitment thread!
ACE マジック HEART
Old 12-29-2013, 08:43 PM   #2800
S13ClassyBroad
S13ClassyBroad's Avatar
S13ClassyBroad is an unknown quantity at this point
Tire size suggestions please!
I have work xt7s, 17x9 +17s all around. Lowered right now on stance GR+ Suspension. I wanna be flush but I don't like the stretched look too much (No offense, just personal preference.) I hope I don't sound like too much of an idiot. Tire size has been driving be crazy bc jut trying to find a happy medium. Any suggestions please?
S13ClassyBroad is offline   Reply With Quote
Old 12-29-2013, 08:46 PM   #2801
ijarrold
ijarrold is an unknown quantity at this point
I had 17x10 +15 on the rear of my last S14. It stuck out about 20-25mm. So it will probably stick out about 15-20mm in the rear, and fronts will stick out super far with 25mm spacers.
The rear would look ok, a little camber and stretch and it would sit flush-ish. The front is way too wide. Were talkin 50mm sticking out, even with 30mm overs up front, it will be 20mm outside those.
If youre trying to get that Stretched Tire Huge LIP Look, then youre on the right track.
I'm trying to get that look. What is the smallest spacer i could run? I have megan tracks. What tire size should i run to get a decent, but not over the top, stetch?
ijarrold is offline   Reply With Quote
Old 12-29-2013, 08:58 PM   #2802
InsTanCeZ
InsTanCeZ's Avatar
Try 235/40 front and anywhere from 235/40 to 255/40 rear that should fit right with minimal stretch while still looking nice.
ACE マジック HEART
Old 12-29-2013, 09:08 PM   #2803
jameswouldgo
jameswouldgo's Avatar
jameswouldgo is an unknown quantity at this point
I am wondering if I can fit SSR SP1's 17x9.5 +0 & 18x11 -1 on my s14 that is sitting on coils. What size tires do you recommend? Also would I have to do any mods such as rolling/pulling fenders, spacers, etc? Thanks!
jameswouldgo is offline   Reply With Quote
Old 12-29-2013, 09:17 PM   #2804
Cubantunr
Cubantunr's Avatar
Cubantunr is an unknown quantity at this point
I have a s13 coupe im thinking 18x9.5 +12 or +15. all around clear coils.
I want all four same size.
maybe roll the fenders and thats it no widebody maybe slight pull.
what would you suggest i have s13 silvia front.
this exact look to where the wheel goes in the well just on a coupe.
Cubantunr is offline   Reply With Quote
Old 12-29-2013, 10:14 PM   #2805
fliprayzin240sx
You dont get it, you push the wheels further out with spacers or too low of an offset, you'd scrub anything and everything at full lock. Over fenders wont save you when your damn tires are touching your inner wheel bad enough that it locks the wheel while drifting, fastest way to spin your ass out.
CLICK HERE!!!
Old 12-29-2013, 10:25 PM   #2806
ILoveJDM
its a 3mm difference, it won't matter. Your camber and tire size matter more than the difference between +12 or +15
DODOlogic.ca
Old 12-29-2013, 10:38 PM   #2807
Cubantunr
Cubantunr's Avatar
I guess I was just asking what other rim sizes fit flush on coupe like the 18x9.5+12
I found nice varrstoens but they're 18x9.5+30 and that seems horrible fitment for front
Sent from my SCH-I545 using Tapatalk
Old 12-29-2013, 10:53 PM   #2808
ILoveJDM
google wheel offset calculator and play around with different specs.
also see : rimtuck.com
DODOlogic.ca
Old 12-29-2013, 10:54 PM   #2809
InsTanCeZ
InsTanCeZ's Avatar
1010TIRES.COM - Wheel Offset Calculator and Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit seem to be the best resources. That's what I use sometimes.
ACE マジック HEART
Old 12-29-2013, 10:56 PM   #2810
Cubantunr
Cubantunr's Avatar
I've tried rimtuck.com I'll try the others thanks
Old 12-29-2013, 11:22 PM   #2811
S13ClassyBroad
I just needed that second opinion. I was looking at the falken azenis rt615ks in 235/40. A little pricy but I am ridiculously picky. Thanks again.
Azenis RT615K | Falken Tire
Old 12-30-2013, 12:07 PM   #2812
fliprayzin240sx
18x9.5 +30 will rub the strut up front. 18x9 +30(common sizing since R34 GTR wheels is this spec) is pretty much hit or miss as it is. Sometimes they'd clear, sometimes it wont.
CLICK HERE!!!
Old 12-30-2013, 09:22 PM   #2813
UGLYLOWLIFE
UGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymore
easy stuff.
1. roll fenders all around
2. fronts: 215-35-17 on 17x9.5 with some negative camber (no pull)
3. rears: 235-35-18 on 18x11 with a lot of negative camber or pull+less negative camber
4. slam that shit
UGLYLOWLIFE is offline   Reply With Quote
Old 12-30-2013, 09:35 PM   #2814
InsTanCeZ
InsTanCeZ's Avatar
^^^ What he said, except no one makes those tire sizes. I would go with 205/40-17 or 215/40-17 fronts and 235/40-18 rears and maybe look into rear over fenders unless you're set on keeping metal.
ACE マジック HEART
Old 12-31-2013, 01:32 PM   #2815
Cubantunr
Cubantunr's Avatar
18x9+22f and 18x10+15r on an s13 coupe. With minimal rolling no pull. Will this clear?
Old 12-31-2013, 01:45 PM   #2816
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
Wheel Fitment Question Thread
Yes, it will, with camber and rolled/pulled fenders all around.
Mine is 9.5 +12 front and 10.5 +15 rear with some room to spare. All with adjustable arms all around though.
Edited****
Added Pic so you'll get the idea....
Old 12-31-2013, 01:48 PM   #2817
Cubantunr
Cubantunr's Avatar
I don't mind a roll but I really wanna keep my s13 quarters and silvia fenders from pulling. Any pictures of your fitment and thanks for reply.
Old 12-31-2013, 02:07 PM   #2818
1gr8bar10der
Trader Rating: (77)
My bad, I'll take the rolled/pulled all around back. No need to pull in the front, only roll. But did both in the rear.
Need to find more fitment pics though.
Old 12-31-2013, 02:09 PM   #2819
Cubantunr
Cubantunr's Avatar
Clean car! Thanks for help
Old 12-31-2013, 10:37 PM   #2820
shift_down
shift_down is an unknown quantity at this point
225 or 235 fronts on a 9" wheel. 255 rears on a 10" wheel. Those will both fit just right. 228.6mm = 9in. 254mm =10in.
Offset really depends where your definition of "flush" is , your ride height and how much camber your running with your setup. You could be "flush" with about 20-25mm of window in offset depending on the above stated settings.
Dont do this. 255s look like silly on a 9"wheel. All huge, squeezed, and round. Let alone trying to turn the car after that. Rubbbbb City!
Okay so Ive decided 235s in front and 255s in back
With a 9 inch wheel in front and 30mm overs, am I safe to get a 0 offset adjust the flushness with spacers? Or will it be sticking out of the fender well. I am planning on using 0* of camber
And should I go with a -10 offset for my 10 inch wheels in the back to achieve the same goals? Again, I am going to run 0* of camber, and maybe adjust as necessary.
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane
shift_down is offline   Reply With Quote
