Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 11-14-2011, 03:34 PM   #1
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Exclamation Godspeed Project S13 / S14 Massive Angle Steering Kit
These are going for $320 picked up or $350 Shipped to lower 48 states (California customers add 9.25% to shipped price.)
The Godspeed Project massive angle kit is a direct fit kit without any modification to your stock oem knuckle piece. This massive angle kit is a ONE PIECE MADE kit, unlike most kits out there that are cut and weld with the oem steering knuckle. This is made by an oem manufacturer with oem quality material. Godspeed Project massive angle kit will give you more extreme angle on your S13, S14, or S15 without modifying the front lower control arm. The Massive angle steering kit will stop at exactly 55 degrees , if you modify the lower control arm bump stop this angle kit will give you additional 5 to 10 more degree (Depending on how you modified your bump stop)
We are confident in our product that we are offering a limited
LIFETIME WARRANTY.
OEM knuckle vs. Godspeed Knuckle
Leading wheel: OEM is 38 degrees vs. Godspeed is 56 degrees
Trailing wheel:
OEM is 30 degrees vs. Godspeed is 46 degrees
Turning circle (curb-to-curb):
OEM is 30.1 feet vs. Godspeed is 23 feet
Lock-to-Lock:
OEM is 3 turns vs. Godspeed is 2.6 turns
***Note: For S13 240sx customers this must be use with a s14 240sx wheel hub.
Also included is (2) 7mm spacers to go into the inner tie rod to be used with this kit****
Godspeed Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988
W:godspeedproject.com
www.facebook.com/godspeedproject
Fatboy Garage is offline   Reply With Quote
Old 11-14-2011, 04:28 PM   #2
BloodBath240
BloodBath240's Avatar
BloodBath240 is an unknown quantity at this point
I dig them...they would go nicely with my already Godspeed Coils and Arms.
BloodBath240 is offline   Reply With Quote
Old 11-14-2011, 06:54 PM   #3
7jpat
7jpat is an unknown quantity at this point
dose it have to be s14 hub what about Ichiba hubs
7jpat is offline   Reply With Quote
Old 11-14-2011, 07:21 PM   #4
k0013
k0013's Avatar
k0013 is an unknown quantity at this point
the diameter of the axle stub is different between the 13 and 14 hubs and they seam to have gone with the s14 hub for a core for these.
k0013 is offline   Reply With Quote
Old 11-14-2011, 07:56 PM   #5
DoobieS13
DoobieS13's Avatar
DoobieS13 is an unknown quantity at this point
$380 on here. $450 on your site???
DoobieS13 is offline   Reply With Quote
Old 11-14-2011, 08:03 PM   #6
JDM_Tuner
JDM_Tuner's Avatar
JDM_Tuner is an unknown quantity at this point
Do they fit both s13 and s14 lower ball joints? Isnt the s14 ballpoint thinner, hence you'd need different knuckles for each model?
Anyways they Look good and the lifetime warranty helps the rep of These even tho it is Godspeed stuff.
JDM_Tuner is offline   Reply With Quote
Old 11-14-2011, 10:21 PM   #7
chiboy002
chiboy002 is an unknown quantity at this point
zilvia pricing dude
Old 11-14-2011, 10:23 PM   #8
iLagX
Trader Rating: (40)
iLagX is an unknown quantity at this point
Feedback Score: 40 reviews
Send a message via AIM to iLagX
any pictures installed? and actual product?
PARTING OUT S13/S14 NEED PARTS PM ME!
iLagX is offline   Reply With Quote
Old 11-14-2011, 10:56 PM   #9
sharpe_corners
sharpe_corners's Avatar
Trader Rating: (29)
sharpe_corners is an unknown quantity at this point
Feedback Score: 29 reviews
pics plz.......
sharpe_corners is offline   Reply With Quote
Old 11-15-2011, 10:21 AM   #10
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
Same question
Would you recommend just switching to an S14 FLCA with the added benefit of moar camberz?
96Turbo is offline   Reply With Quote
Old 11-15-2011, 02:25 PM   #11
Fatboy Garage
As far pictures go, there are more pictures on our website;
NISSAN 240SX S13 S14 89-94 95-98 MASSIVE ANGLE STEERING KIT [SK-001] - $450.00 : GodSpeed Project, The Art of Performance
Originally Posted by 96Turbo View Post
Same question
You can switch to a S14 FLCA but its not necessary. On the knuckle itself you can actually bore out the hole just a tad bit to fit an S13 FLCA the size difference is not that big.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-15-2011, 06:37 PM   #12
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
Yay, cant wait to try them!
PeaceOnesxWai is offline   Reply With Quote
Old 11-16-2011, 01:14 AM   #13
travypoo
travypoo is an unknown quantity at this point
Send a message via MSN to travypoo
s14 ball joint taper is different. if you get s14 knuckles on a s13 you need s14 balljoints in your lcas or s14 lcas. and the coilover bolts are 14mm on s14 vs 12mm on s13. you will need to either drill out your coilover holes to bolt up the knuckle or get these:
Agency Power AP240-500 5 Lug Shock Mount Spacers 240SX S13 S14
travypoo is offline   Reply With Quote
Old 11-16-2011, 08:44 PM   #14
Chris28
Chris28 is an unknown quantity at this point
No roll center correction and I'd have to get s14 hubs, ball joints, and coilover bolt spacers?
No thanks, I'll still order from PSM.
Chris28 is offline   Reply With Quote
Old 11-17-2011, 01:48 PM   #15
Fatboy Garage
In stock ready to ship!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-18-2011, 11:45 AM   #16
Fatboy Garage
This is still available.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-21-2011, 11:46 AM   #17
Fatboy Garage
still in stock!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-23-2011, 11:47 AM   #18
Fatboy Garage
These are still available!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-28-2011, 06:56 PM   #19
Fatboy Garage
50% off sale going on today, last day.
http://zilvia.net/f/advertiser-announcements-feedback/420917-godspeed-project-black-friday-special-50-off-msrp.html
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-29-2011, 12:25 PM   #20
Fatboy Garage
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 11-29-2011, 05:16 PM   #21
7jpat
wish it was still 50% off and the suspension deal to
Old 11-30-2011, 10:58 AM   #22
Fatboy Garage
Still have a few of these available!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-01-2011, 10:50 AM   #23
Fatboy Garage
Still have a few sets left.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-02-2011, 02:46 PM   #24
Fatboy Garage
Still have these available!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-05-2011, 03:41 PM   #25
Fatboy Garage
In stock ready to ship out!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-05-2011, 03:41 PM   #26
Fatboy Garage
Still in stock ready to ship out!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-06-2011, 11:46 AM   #27
Fatboy Garage
in stock ready to go!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-09-2011, 11:16 AM   #28
Fatboy Garage
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-12-2011, 01:24 PM   #29
Fatboy Garage
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 12-13-2011, 01:51 PM   #30
Fatboy Garage
Godspeed Project
El Monte CA 91733
P: 626-442-3988
