Old 09-25-2006, 04:04 PM   #2401
Nan Desu Ka?!
Nan Desu Ka?!'s Avatar
Nan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to all
Send a message via AIM to Nan Desu Ka?!
I still hate all you vicroy pricks but god damnit i love and respect you at the same time. >.> <3
*notsosubtleanchormanreference*
Norcal-240sx.net
Nan Desu Ka?! is offline
Old 09-25-2006, 04:14 PM   #2402
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
Originally Posted by 240trainee
Hey, he's moving in the right direction.
If by that you mean outer space...then yes
That wing belongs on on a top fuel drag car
or the back of optimus prime's head
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline
Old 09-25-2006, 04:36 PM   #2403
TheSquidd
TheSquidd's Avatar
kekemessagelengthkeke
TheSquidd is offline
Old 09-25-2006, 09:13 PM   #2404
-=RS13=-
-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of
What is with all of the Hard Parking
And the bank i bent a tie rod on.
Thanks to Matt Haase for the pics.
I have about 1/8 of an inch left on my megan coils before i have to remove collars, Already pre-loaded 1.25 of an inch.
EDIT: Decimal point, Should be .125 or about 3 turns
Built by myself, Not by a shop and defintaly not bought. FTUW
-=RS13=- is offline
Old 09-25-2006, 09:20 PM   #2405
chmercer
chmercer's Avatar
why would you preload your coilovers 1.25 inch and brag about how much room you have left to go. preload raises your car. that makes no sense.
chmercer is offline
Old 09-25-2006, 09:41 PM   #2406
staygold24
staygold24's Avatar
staygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enough
chmercer, did you really paint the aero on your car with spray paint or was that just a joke? I noticed there was some pretty good looking roller paint jobs on cars but yours looked really good. clean ass group of cars too, im loving the paint on the kouki with the gold emo's
staygold24 is offline
Old 09-25-2006, 10:07 PM   #2407
naed240sx
naed240sx's Avatar
naed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the rough
Holy shit, 1.25 inches of preload? May I ask why? If you preload 1.25 inches, you loose 1.25 inches of rebound travel, because you change the position of the damper by 1.25 inches. Do you even have any rebound travel left? An s13 should compress a non preloaded 8kg/mm spring by right around 1.25 inches at static, assuming that the spring rate is 100% linear.
naed240sx is offline
Old 09-25-2006, 10:29 PM   #2408
chmercer
chmercer's Avatar
i sprayed it in my back yard
ppg paint
roller is for circus clowns
that joke pic, i was spraying some paint i had lying around out of an aerosol can, reduced with paint thinner lol (DO NOT REDUCE AUTOMOTIVE PAINT WITH PAINT THINNER)
chmercer is offline
Old 09-25-2006, 10:33 PM   #2409
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
I think there is some misunderstanding going on. From what ive gathered:
Spring preload = supposedly raises the car.(tighten spring, move spring collars up)
Shock preload(droop spring) = lowers the car.(loosening spring, moves spring collars down, pushing shock piston into the body. Usually used in the rear when running out of adjustability when lowering with dual height adjustable coilovers from lower bracket.)
Nizzan4u2nv is offline
Old 09-25-2006, 10:40 PM   #2410
McRussellPants
shock preload on the front is equally worthless for lowering a car.
The only way preload would help lowering an Schassis, is that if you loaded it so much that the spring was bound so that you could put the tire 1mm from the frame and it wouldn't matter since he suspension doesn't move.
I I preload the front of my car about 5 turns. The Rear is drooping about an inch now.
McRussellPants is offline
Old 09-25-2006, 10:46 PM   #2411
naed240sx
naed240sx's Avatar
I don't think that anybody is missunderstanding. The op said "preload", and he meant it. I have never heard of anybody drooping spring for the front, and it certainly would not be done without first removing collars.
Old 09-25-2006, 11:00 PM   #2412
-=RS13=-
Decial point mistake.
.125. About 3 turns. Digital calipers for all of the measurements
opps
-=RS13=- is offline
Old 09-25-2006, 11:02 PM   #2413
Nizzan4u2nv
Ok, that makes more sense.
And to contribute:
Old 09-25-2006, 11:09 PM   #2414
hybrid_eg
hybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the rough
I just had to ask.. is that FC running M3 optional 19's? I could swear mine looked just like that? if i still remember correctly the bolt pattern was different.. 5x120?
Originally Posted by Johny5
hybrid_eg is offline
Old 09-25-2006, 11:15 PM   #2415
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
the power steering cooler was chilling on the ground in that pic
Ahh...I was thinking it was a bumper support.
Rayne is offline
Old 09-25-2006, 11:18 PM   #2416
chmercer
chmercer's Avatar
no not m3 wheels, 5x4.5 bolt, 18"
chmercer is offline
Old 09-25-2006, 11:21 PM   #2417
Ian
Racing Sparco wheels, they were really cheap from Discount Tire a while back for like 18x __ good sizes a while back...like 110 a wheel
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
No it isn't
Ian is offline
Old 09-25-2006, 11:31 PM   #2418
Nizzan4u2nv
Sparco NS6
Old 09-26-2006, 08:52 AM   #2419
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
viceroy pics
thats awesomness
TokyoNights is offline
Old 09-26-2006, 10:13 AM   #2420
Team Rootbeer
Team Rootbeer's Avatar
Team Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really nice
Send a message via AIM to Team Rootbeer
polished my wheels. got new mirrors. yAy.
Originally Posted by hotrodv
90% of the cars posted here are stock or with original rims painted black
I'm not an asshole but is the true..
Team Rootbeer is offline
Old 09-26-2006, 06:03 PM   #2421
staygold24
staygold24's Avatar
wow thats some nice paint. I thought you were trying to sell it. Cant let go of it?
Old 09-26-2006, 06:05 PM   #2422
Nizzan4u2nv
Looks good man. I was seriously considering polishing my FN, but powdercoating was cheaper and easier. You do it yourself?
Old 09-26-2006, 09:38 PM   #2423
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
from top drift
where i got 18th, top 17 advanced fuck lol
then i got yelled at for trying to help out some people on the side of the road. sweet.
driftparty.com
hitman is offline
Old 09-26-2006, 11:10 PM   #2424
Team Rootbeer
yep, did it in 1 day, not bad at all.
and no, i cant let go of it......trying to sell just made me want it even MORE, so i spent lots more money on it! yay for new, higher paying job.
Old 09-26-2006, 11:26 PM   #2425
Ian
What did you use to strip/polish?
I started doin it on one of my wheels and honestly...i didn't even finish one after a couple hours
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
No it isn't
Ian is offline
Old 09-27-2006, 12:15 AM   #2426
Team Rootbeer
aircraft stripper, plastic filler spreader (for scraping purposes) and my right arm that hurts real bad now, then shined em up with blue magic polish on a power ball buffer thingy.
FNs are almost already polished when you stip them. didnt have to do much work.
Old 09-27-2006, 12:19 AM   #2427
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Heres my contribution...had to get some fresh pix so i can try to push to sell her again.
Could go lower with more camber or less spacer in the rear but i like the stance right now...
CLICK HERE!!!
fliprayzin240sx is offline
Old 09-27-2006, 12:20 AM   #2428
Nizzan4u2nv
yea, the finish on the FNs seem to come off quite easily. My powdercoated should me exactly how easy it was. Ive also seen it come right off with a shot of brake cleaner.
Old 09-27-2006, 12:35 AM   #2429
fliprayzin240sx
Ive thought bout stripping them...actually bought 2 cans of aircraft stripper. Then I chickend out the last minute. I heard the finish undeneat the paint is smooth enough that you wont have to buff it if you choose not to.
CLICK HERE!!!
Old 09-27-2006, 12:50 AM   #2430
HerbReal
HerbReal's Avatar
HerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond reputeHerbReal has a reputation beyond repute
Send a message via AIM to HerbReal
HerbReal is offline
