Old 06-08-2005, 12:00 AM   #1
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
whats a good substitute for eccentric bolts
Yeah thats right you know they slip...
I been through a bunch of alignments allready and want to make the next one the last one for a while including cornerweighting. I have coilovers and all adjustable arms other than lower control arms. What can I use instead of the eccentric bolts for the toe arms and rucas?
TokyoNights is offline   Reply With Quote
Old 06-08-2005, 12:13 AM   #2
Dousan_PG
Dousan_PG's Avatar
weld washers
run regular bolts.
Aaron
Pink GodziRa
Old 06-08-2005, 09:27 AM   #3
TokyoNights
weld washers to the subframe,,,,,good idea.
were you able to weld all the points with the subframe/suspension still on the car ?
Old 06-08-2005, 09:57 AM   #4
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
Originally Posted by Dousan_PG
weld washers
run regular bolts.
Aaron you're such a winner. i'm gonna do that when i find the time.
Hi
Var is offline   Reply With Quote
Old 06-08-2005, 10:05 AM   #5
Dousan_PG
Dousan_PG's Avatar
no i wont waste my time on such
dont realy care
never had problems w/ the eccentric bolts..ever.
new subby goes on, just powder coated, no solid bushings this time i like spacers
Aaron
Pink GodziRa
Old 06-08-2005, 10:21 AM   #6
Var
Var's Avatar
heh..i just pressed in my solid bushings...rides better on the freeway. shocks doing their job instead of waiting for rubber to compress.
You're the only person i've ever heard not having a problem with the bolts backing out. I suppose i could use thread locker . Are you suppose to?
Hi
Old 06-08-2005, 11:06 AM   #7
Dousan_PG
Dousan_PG's Avatar
no im not
i just tighten the hell out of them
no air tools
muscle baby muscle!
and how do i know its ok?
because ill get an alignment front adn rear
then do a few events and daily driven ...about 3 months
get another alignment
rear still same, SLIGHTLY out of spec but nothing like a bolt slipped/turned
Aaron
Pink GodziRa
Old 06-08-2005, 11:57 AM   #8
projectRDM
projectRDM's Avatar
Or just use a fender washer, a little less work than welding one on.
I've only had problems with monkeys overtightening them which spins the washer and locks it into the bolt. Then you have to drop the subframe just to hammer the bastard out.
FORMERLY R240NA
Old 06-08-2005, 07:08 PM   #9
TokyoNights
fender washer?
Had that happen before
Got them out withough dropping the frame though
