![]() Join Date: Mar 2012
Hooking up speedo to SR20 swap?
Okay, there's like 70,000 threads related to this out there but I really can't find any actual information that will help me hook up my speedometer.
I have a 94 240sx, automatic body harnass. I swapped in an SR20DET red top. How do I go about hooking up the speedometer. Which wires need to be spliced where and what additional parts might I need to successfully convert for the new trans. If anyone can explain or has a link to a walk through, that would be excellent. thanks, Matt
94 240SX, 93 Stealth, 92 VR4, 93 RX7 , 88 Yota |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
You need to use your auto lower harness.
Put a multimeter on your batt and see how many volts the batt is getting -- guessing in the 15+ range (if you used the SR 5spd lower harness). Swap the auto one back on and everything will work fine. |
#6 | |
Does anyone have a cheap lower harness so I can just swap it and have everything working?
#8 |
use a KA speed sensor, an SR speed sensor wont read in MPH,
i know a manual KA speed sensor will work, not sure if an auto is the same. and your KA lower harness should plug right into it. if not its just two wires. you can find an FSM and splice it into those two wires if you dont have the chassis plug for the speed sensor.. but you should |
#12 |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
No, you need to use the KA auto lower harness. You can eliminate most of the harness. You just need the alternator/starter wiring, the speed sensor wiring, and the reverse light wires. The M/T harness WILL NOT plug into your chasis harness.
#13 | |
Does anyone have a lower harness I can buy? Or is there a method to directly splice wires. Also I'm having the issue where the car is running 15 volts, why does this occur? (yes I know wrong harness but what is plugged in where that makes the voltage higher?)
