Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 05-26-2013, 08:36 PM   #1
s13z28
s13z28 is an unknown quantity at this point
autox 17x7.5 tire size
s13 with 03' z33 wheels f/17x7.5 r/17x8.
needing new tires and want to know if a 235/40 would be to much for the 7.5 wheel. I know it will fit and that it will bulge slightly, and that bulging can cause less contact patch. researched and cant seem to find anything pertaining to how it performed at an actual autox, just people saying they thats all they run on their daily with 7.5. google found couple bmw threads where e36 came factory with 235 on 7.5, but of coarse 240 and m3 arent the same. Would I be better off just going with a 225/45.
side note: this is local autox and dont care about classing.
s13z28 is offline   Reply With Quote
Old 05-26-2013, 09:53 PM   #2
derass
Looking at a tire's spec sheet can be helpful. Here's one for the Direzza ZII: Dunlop Direzza ZII
You will see that 235/40 is not approved for 7.5" wide. Although you could run 235/45 or 245/45. Take a look in the wheel fitment thread, as your offest will dictate how much clearance you have to the coilover/strut and therefore the tire width you can run.
Old 05-26-2013, 10:16 PM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Grassroots Motorsports Magazine did a test on this a few years ago. They ran continuously wider tires on the same size wheels and recorded the results and driver impression. According to their testing wider is faster, PERIOD. Every time they went wider the car went faster. The downside is that the driver commented that it started feeling less responsive. I would say that 225/45 on the 7.5" wheels and 235/40 on the 8" wheels should be ok. I would definitely recommend that you get a set of non-staggered wheels in the long run though. Unless you're pushing big power there is no need for staggered tires.
Old 05-26-2013, 10:48 PM   #4
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
What he said. Learn on a simple balance setup first off.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 05-27-2013, 08:45 AM   #5
s13z28
thanks for replies.
yeah i knew the spec sheets recommended 8" min for 235 was wondering how much of a negative affect it would actually have, and I have the clearance for 235 up front.
Was also wondering if being square or staggered would be better(assumed square would be the answer there) so thanks there too. I didnt plan on autox when i originally bought(plus they were super cheap at that time). going to go with the 235 and ill start looking for a square set up, ill find new wheels long before tires are gone
Old 05-27-2013, 11:19 AM   #6
racepar1
racepar1's Avatar
It will look funny, but it may be beneficial to run the 7.5" wheels in the back w/235's all around. The additional sidewall flex may help keep the rear end in line and the square sidewalls in front will help with steering response. Just something to play around with...
Old 05-27-2013, 01:58 PM   #7
s13z28
ah true i never thought about trying that. either way doing it for fun not really trying to be competitive
Old 05-27-2013, 02:10 PM   #8
lude4life13
lude4life13 is an unknown quantity at this point
So does having a staggered setup "hurt" or is it just that there is no need for it? I am currently running the same wheels (8 rear 7.5 fronts) and I have 245/40 in the rear and 225/45 in the fronts, but I don't have enough seat time to have noticed the differences from previous setup. I may be getting new tires in the next year so i'd like to optimize my choice in size.
lude4life13 is offline   Reply With Quote
Old 05-27-2013, 02:42 PM   #9
racepar1
racepar1's Avatar
Wider tires in the rear means that the rear has more available grip. This makes the car tend to understeer off the throttle. The only reason to run staggered tires is if you have enough HP that you have trouble keeping the rear end in line on the throttle.
I would suggest a 225/45 front 235/40 rear setup. Since the 225/45's are a little taller the contact patch will be a little longer. With the shorter 235/40's in the rear this should have a pretty balanced feel without looking funny or promoting too much off-throttle understeer.
