10-24-2011, 11:56 AM | #1 |
Best Cooling Modifications?
OK OK...I did use the good ole search button, but this is a pretty broad request and I get ALOT of unrelated threads....
I have a regular, run of the mill SR20DET swapped into my '89 240sx. I recently swapped in a larger aluminum radiator with dual electric fans and shroud. I also removed the OEM clutch fan. I have noticed that even at freeway speeds (60-70mph) the water temp is creeping higher than it used to with the OEM SR20 radiator and clutch fan...I have actually had to turn my fans on while driving on the freeway in low 60's weather. I'm sure my aftermarket FMIC is blocking alot of the flow to the radiator... What have yall done to your S13's to improve airflow to the radiator and lower running temps? Would an air diversion panel really do anything noticeable? Short o cutting holes on my front bumper....... |
10-24-2011, 12:06 PM | #2 |
More often than not, the OEM clutch fan with shroud will cool better than e-fans.
Make sure your coolant system is properly bled, and if you have issues with air in the coolant, look into a swirl tank to constantly bleed the system. You can also play with ducting, you ensure that you're getting the maximum amount of clean air (Air that hasn't been through another heat exchanger already) is crossing the radiator. |
10-24-2011, 12:14 PM | #3 |
Yeah, I am going to bleed the cooling system next time I get a chance...just to make sure.
What have people done as far as ducting to get fresh air to the radiator? Are there any scoops or vents that can make the hole a bit "prettier" if I decide to cut some vents in my front bumper? |
10-24-2011, 12:30 PM | #4 |
I'm running water wetter and distilled water along with the oem clutch fan, shroud, and that radiator shroud thing.
Anything that helps direct air through the radiator will help with cooling.
10-24-2011, 12:34 PM | #5 |
I had temp problems at the track with Altima fans. Then I put a clutch fan in, problems solved.
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
10-24-2011, 12:36 PM | #6 |
water wetter always seems to work if you need it too
but i doubt thats your issue...like ^^ said, bleeding coolant properly is a start, has the water pump/thermostat ever being replaced? |
10-24-2011, 12:45 PM | #8 |
Only Chicago is allowed to do that.
10-24-2011, 01:39 PM | #10 |
the only time my car temp creeps is when it needs to be bled. I am running the dual e-fans with a large koyo race radiator, stock thermostat and no oil cooler. I am planning on running a good oil cooler with a Canton thermostat...someday.
10-24-2011, 02:15 PM | #11 |
my best coolng mod was replacing all my hoses. I had one leak under the intake mani so I changed them all. Not making it any cooler, but more reliable.
10-24-2011, 02:28 PM | #12 |
A thermostat that opens up sooner will make it cool better. I need to get one myself
My Twin Scroll Gt30r Sr22det Build |
10-24-2011, 05:51 PM | #14 |
flush and run one of those anti-rust treatment things in the radiator
flush the shit out of it to unclog passages, with high pressure water 90% pure distilled water + 10% anti-freeze + water wetter. Get a new cap for the radiator clutch fan + stock shroud owns like a beast |
10-24-2011, 06:44 PM | #16 |
Trader Rating: (31)
Feedback Score: 31 reviews
I've heard the Same. (RB fan on SR) - Drift Tengoku shows thats what Yashio likes. More Blades on the RB Fan that Bolts up to the SR Clutch Looked into getting one but RHDjapan needs a part number and I found one but not sure its Correct or not. Someone needs to Get This part avail at the Shops in the US.
z-tERty-2 |
10-24-2011, 06:51 PM | #17 |
I got mine from Raw Brokerage - Your #1 source for RB20 / RB25 / RB26 parts!
Its the single best thing I did for my sr's cooling. I used stick on foam (from lowes) to seal the shroud to the radiator. I can literally hold a piece of paper a couple feet in front of the car and it will suck it to the radiator... at idle. lol Just send them an email and see if they have any. |
10-24-2011, 07:21 PM | #19 |
I just used a C&R radiator with single spal fan, lower temp thermostat, can't remember what kind, the only time I saw temps over half way was at an auto-x at 100+ degree temps. I just used plain green prestone mixed 60/40. I would start with checking for air on the system, then maybe try experimenting with the stock radiator and the e-fans. I'll probably get flamed but I would avoid the clutch fan if possible, I definitely noticed a difference in quickness of revs when I went to the e-fan.
10-24-2011, 07:24 PM | #20 | |
10-24-2011, 08:31 PM | #22 |
Using an RB25 clutch fan on my KA.
Not sure how much difference it made, but it looks cool/menacing. As Mr. !Zar! said, on an SR you can also use a KA clutch fan for a cooling upgrade. |
10-24-2011, 10:02 PM | #25 |
Trader Rating: (58)
Feedback Score: 58 reviews
The key to god cooling is a proper system. Whether E fans or Clutch Fan is the heart, if you don't have the lower panels, nor a bled system, it won't work.
Don't fall to much into the trap of lower thermostats, as that just overcools a car, and never lets it get to proper operating (180*) temperature; in fact a Nismo thermo is NOT needed under any circumstance. Good flow, good radiator, good fans, proper ducting...that's all that you need. My personal car Stock Thermostat Altima E fans Derale Fan controller for second fan OEM lower plastic pieces Aftermarket upper cooling panel 180* CONSTANT since day one now, 200-210ish on track when beating the snot out of it. Never an issue
10-24-2011, 11:52 PM | #29 | |
ive had my cx racing radiator with nismo thermostat and single electric fan with temp switch for 3 years now. through 3 brutal alabama summers, no overheating ever
