10-25-2011, 07:45 AM | #31 |
on my s14 w/rb25 i run
oem clutch fan mishy rad psm swirl tank oem 300zx tt t/stat. crusing on highway, 170*. stop and go 180*. drifting 180-190. no oem plastics, removed gasket on cowl under the hood. no hood spacers. and i drift with my hood and bumper on. |
10-25-2011, 08:01 AM | #32 |
On my car I've done a couple things.
Never gets more than 190 on track even when its 105degrees out... But it is just an NA KA. Other than the radiator, the best cooling mod I've done has been for the brakes. Removing the dust shields and running 3" ducting to the front rotors has been the best investment I've ever made in my braking system.
'95 240 | @SleepySteve72 |
10-25-2011, 08:41 AM | #33 |
s13 sr20det
I live in Florida and it was hot as hell this summer. Used to have a problem overheating on the highway, so I revamped my cooling system Mishimoto Radiatior/ w Fan Shroud Nismo Thermostat Water Wetter/ Distilled Water Never had a problem since. Although, I am running both of my fans on all the times. I need to get a fan controller |
10-25-2011, 10:09 AM | #35 |
ebay 2.75 radiator
ebay hoses nismo thermostat VW Jetta MK4 Dual Speed Fans Modified Jetta MK4 shroud Custom Cooling Plate 97% Coolant OEM 2011 Shellby GT500 hood vent i've never seen it over 170° in our summer (110°F ) Last edited by Chay G; 10-25-2011 at 04:18 PM.. |
10-25-2011, 03:12 PM | #37 |
It depends. I've read a user claim a decrease of 10 degrees after installing a coolant breather tank and re routing coolant lines in an rb25/s13. I've seen similar numbers in my rb20/s13 by just eliminating any coolant line above the filler point on the radiator. Either way, it's an affordable reassurance, so why not.
10-25-2011, 03:52 PM | #38 |
10-25-2011, 03:59 PM | #39 |
remember CANSSS method, as in cansss stay cool.
C lutch Fan A luminum Radiator N ismo Thermostat S tock shroud S wirl pot to help system stay bled S amco hoses for cool factor |
10-25-2011, 04:11 PM | #40 |
Damn! Some Great Info All!
And Yes...Looks like this has turned into the "Cooling Thread" So, from what I am hearing I am going to say that I should be fine with my current setup....I dont think my thermostat has been replaced in a while, so I will check that and bleed the system...then go the distilled water/water wetter route. No crazy scoops or cutouts needed? |
10-25-2011, 05:29 PM | #41 |
Trader Rating: (22)
Feedback Score: 22 reviews
Koyo Radiator
ISIS Fans And Shroud ISIS Thermostat ISIS Hoses. - Been running these on my car for about a year with about a bunch of trackdays, never once overheated. My car also sounds like a damn hurricane up front from these fans pulling so much air! |
10-25-2011, 06:48 PM | #43 |
oem fan shroud
oem clutch fan water water wetter isis aluminum radiator isis rad hoses no front bumper spaced hood 1 1/2 in. and my car runs at 140f city highest ive ever seen my car get is 175f on the track on a hot ass day like 91f at florida during the summer. |
10-26-2011, 09:45 AM | #45 | |
Running too cold is just as bad as running too hot.
10-26-2011, 10:00 AM | #46 |
My set up on a stock s13 Ka24de:
-CX Racing Radiator -OEM Hoses -OEM t-stat -Sonic Motor Efans w/ no shroud -75% Coolant, 20% water, 10% Wet Wetter average temp: 150-160 hot days:175-185 Cold days: 145-155 Had this set up for about 2 years now. Zero issues, never overheating, tracked twice during the spring. |
10-26-2011, 11:58 AM | #49 |
something wrong with ur setup. my efans dont even work and my shiet is nice and cool driving and freeway, unless im on traffic or at a light. ether u need to bleed shiet or u got a cheap radiator..
R33 |
10-26-2011, 01:04 PM | #51 |
A luminum Radiator
N issan OEM Thermostat A ltima electric fans L ower air duct paneling as in, Need to be ANAL about staying cool.
10-26-2011, 01:06 PM | #52 |
fixed...
my car can run without e-fans all day, unless im in stop and go traffic, with NO airflow across the front of the car... once you hit above 30 mph, the air that is being pushed into your radiator is stronger than the fan pulling air through....
10-26-2011, 01:22 PM | #53 | |
All a swirl tank does is constantly bleed the coolant system. Air in your coolant system dramatically lowers the efficiency of the system (since air carries less thermal energy away than water or coolant) which can lead to over heating or getting weird 'hot spots' from time to time. Most people will notice that their car needs to be bled when the temp gauge will randomly jump by 20*F or more then drop back down once an air bubble has passed the sensor. Just in case anyone didn't know how a swirl tank works. IMO, it's a worth while investment, especially at $60 or whatever an inexpensive one costs these days. |
10-26-2011, 01:29 PM | #54 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
Surprised no one has thrown this up.
10-26-2011, 01:39 PM | #55 |
COPPER RADIATOR...seriously nobody here running one?? Aluminum blows, also a 25 fan and shroud are key
AEM Series 2 ECU 30-6620 and Chase Bays S14 SR20DET engine harness for sale |
10-26-2011, 01:40 PM | #56 |
if your system has been bled, there shouldn't be anyway any air can get back into the system, i don't understand where you guys are getting that info from. If you are low on coolant.... very low, or have a leaking head gasket, i dont see how air can magically form in the radiator system...
swirl pots / surge tanks are intended for fuel systems, to keep a constant amount of fuel availible for the engine... Thats it... unless you like wasting money and time on something that is useless...
10-26-2011, 01:42 PM | #57 |
doesnt copper radiators still run the plastic end tanks? that is the weak spot of the radiator.. plus copper will varnish alot quicker than aluminum will corrode..
10-26-2011, 01:57 PM | #58 |
My 3 core does not have plastic end caps, use 50/50 or distilled mixture and not hose water and you'll have no corrosion issues. Doubt you'd ever own it long enough to see any corrosion If you keep a clean system.
10-26-2011, 02:00 PM | #59 |
Stock copper rads have plastic ends maybe that's what your thinking of?
10-26-2011, 02:08 PM | #60 | |
And yes, you are correct, if a system is perfectly bled, in theory there's no way to get air back into the system, though on the half dozen or so cars that I've had the experience of bleeding the coolant system with, I've never been able to - or seen anyone get 100% of the air out of the system, there's always air in it a few days later. Maybe I and those who I know suck at bleeding coolant systems. Also, on some engines (Not any Nissan Engine I've encountered though) there's no bleeder valve (1JZ's for sure) or any other easy way to bleed coolant other than doing the funnel/upside down bottle to radiator cap method - which I'm not particularly fond of. A breather tank is just extra insurance and makes the bleeding process easier. |
