Old 07-09-2013, 08:16 AM   #1
Radioadix
Radioadix is an unknown quantity at this point
1993 300zx TT stuborn missfire
A friend and I recently picked up a 93 twinturbo. This is a current list of what has been done to the car thus far:
Battery
Spark Plugs
UIM Gasket
Injectors
PTU Ignition
Fuel Filter
Clutch Slave Cyl
Clutch Cables
Clutch Master Cyl
Compression test confirmed 170+ each cylinder.
Grounding kit
At this time, Cylinder 5 will not fire. We have used a test plug and confirmed that there is spark. We have checked the voltage to each line. the plug is wet with gas when removed, we have swapped the coil pack with a cylinder that is for sure firing. The next step we are about to take is to replace the entire wiring harness just to eliminate that as a possibility but wanted to check on here to see if anyone else has experienced anything like this and what possible fixes you guys can offer. Any help is appreciated. Thanks in advance.
Radioadix is offline   Reply With Quote
Old 07-09-2013, 08:44 AM   #2
typhoonslippery
typhoonslippery's Avatar
typhoonslippery will become famous soon enoughtyphoonslippery will become famous soon enoughtyphoonslippery will become famous soon enoughtyphoonslippery will become famous soon enough
did you try replacing the vg30 ? I hear they are usually the issue
injector stuck open ?
CA18 is the only way to go!
typhoonslippery is offline   Reply With Quote
Old 07-09-2013, 08:51 AM   #3
Radioadix
I guess your a 240 guy.. lol
The injectors are all brand new.
Old 07-09-2013, 08:54 AM   #4
typhoonslippery
sorta
I remember working on a few of them and the coil pack harnesses were always brittle and had cracks as well as the coil packs themselves were always needing to be replaced like in a ca18det engine.
New injectors don't always mean 100% ... they can be stuck
Old 07-09-2013, 08:56 AM   #5
Radioadix
We swamped the coil pack for cylinder 1 which is 100% for sure working. and still got nothing although with a test plug running off of cylinder 5's coil pack and - we got spark. We also replaced the plug in that cylinder yesterday and its still not firing.
Old 07-09-2013, 08:57 AM   #6
Radioadix
We have also checked the voltage on each line at the clip for the coil pack
Old 07-09-2013, 09:18 AM   #7
double_R
double_R's Avatar
double_R is an unknown quantity at this point
Where did you get the injectors from? I had to replace my injectors before even if I got em brand new.
double_R is offline   Reply With Quote
Old 07-09-2013, 09:21 AM   #8
PoorMans180SX
PoorMans180SX's Avatar
Check compression on that cylinder. I had a problem exactly like this. Turned out compression was 90psi on that cylinder. Bye bye VG30, hello 1JZ...
Old 07-09-2013, 09:26 AM   #9
Radioadix
Injectors are from advance auto parts - and the compression check has been done - 170+ on each cylinder.
Hopefully we do not have to replace the injectors - that was not a fun job removing the intake.
Old 07-09-2013, 09:34 AM   #10
double_R
double_R's Avatar
Swap your injector with another working one and see what happens. Could be the harness and hopefully its fixed when you replace it.
Old 07-09-2013, 10:03 AM   #11
double_R
double_R's Avatar
Ohm test the injector also.
Old 07-09-2013, 11:30 AM   #12
jr_ss
Why don't you put a noid light on the injector clip to see if it's even getting signal?
Old 07-09-2013, 08:54 PM   #13
JeeBus
JeeBus's Avatar
JeeBus is an unknown quantity at this point
injector stuck open or pinched seal.
Both will flood that cylinder and keep it from firing, hence why the plug on that cylinder is wet.
JeeBus is offline   Reply With Quote
