02-01-2009, 05:11 PM | #1 |
Car doesnt crank
i just replaced the starter and it still dosent turn on or crank
Before it would take a long time to start so i thought it was the starter and now it just doesnt start at all, maybe it wasnt the starter or something but all my lights on dash are on and radio etc when i turn i get nothing, no clicking no nothing Ka24e btw |
02-01-2009, 06:33 PM | #2 | |
02-01-2009, 06:51 PM | #3 |
check the battery and your grounds
www.illgarage.com |
02-01-2009, 09:50 PM | #7 | |
meanwhile, the smart people are talking loose or dirty battery cables. |
02-01-2009, 11:03 PM | #8 |
Bypass the starter relay. Take one more item out of the equation.
02-02-2009, 12:18 AM | #10 |
Im with projectJDM, bypass the starter relay. I had similair problem you had earlier. Would not crank at all, but knew starter and altenator works so tried "jumping" the starter, + on battery terminal to starter and it starts fine. My problem, it was the clutch relay. Hope you find out what it is.
02-02-2009, 12:46 AM | #11 |
(ノಠ益ಠ)ノ彡
when I had this problem first it was a bad ground - attached to the frame in the passenger side rear quarter panel. we later re-attached it to the intake side of the block.
then my body harness had a short. I couldn't trace it, so I got one from a junk car and switched it in. It fired up every time since. good luck |
02-02-2009, 01:01 AM | #13 | |
02-02-2009, 09:36 AM | #15 |
It's called the starter relay, but it's enabled by the clutch switch. And they regularly go bad.
