Old 07-24-2011, 08:31 AM   #31
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
ur over looking something simple...i can feel it
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 07-24-2011, 08:56 AM   #32
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
Try a different maf. I know it says you have a z32 but you seem to have gone through every other suggestion I had. Timing was my first answer and then fuel pump. So if it's not the maf it could be that the Ecu was tuned for a rev limiter at that rpm.
fullthrottle is offline   Reply With Quote
Old 07-24-2011, 09:44 AM   #33
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
I suffered from a similar issue a while back. Where the cut off seemed consistant to the RPM, but I noticed it was load dependant. The cut off point would be lower in a higher gear, amd the amount of throttle affected it also. For instance, at WOT in 2nd gear it may cut off at 6k rpm, and 3rd gear, it may cut out at 4.5k rpm, but at partial it may not cut out at all. Is yours like this also?
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 07-24-2011, 11:54 AM   #34
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Yes mine is similar to that. If I go half throttle, it will not do it. Sometimes it cuts at 5, sometimes at 5.5, sometimes at 6. Etc.
StryfeS13 is offline   Reply With Quote
Old 07-24-2011, 03:07 PM   #35
Kyle W.
Kyle W. is an unknown quantity at this point
Check your tps. I had the same thing happen to me.
Kyle W. is offline   Reply With Quote
Old 07-24-2011, 03:56 PM   #36
GSXRJJordan
GSXRJJordan's Avatar
Originally Posted by codyace View Post
boost leak
My first thought too.
Originally Posted by StryfeS13 View Post
- I tried retarding and advancing the timing, like 20 different times. Was never any better or worse, it made no difference.
This worries me. Check/set the base timing per the FSM. This was my second thought.
If it's not rev-dependent (it'll rev to redline with less load) then it's load-dependent, and that makes me think fuel or MAF. If it were more or less rev-dependent, I'd think more about timing/CAS/wiring.
What engine management is he using? SAFC or ROM tune?
Old 07-24-2011, 05:07 PM   #37
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Hey Jordan, thanks for stepping in.
- We checked for boost leaks, there are none.
- I set the timing back to FSM spec. It's at 15 BTDC @ 850 rpms.
- That is also what I was thinking. Because I can accelerate at 80 - 90% throttle and it wont do it. But the second i go WOT, it'll do it. The more boost I give it, the earlier it cuts. (for example, 14 PSI cuts at 4.5K) When it cuts, the AFR's don't go all crazy or anything, so I don't think it's fuel...
Maybe it is the MAF.
Old 07-24-2011, 07:12 PM   #38
GSXRJJordan
Load dependent and not going lean = MAF or engine management. You never mentioned what you're using to tune it? I know you're not trying this all on a stock SR ECU...
Old 07-24-2011, 07:19 PM   #39
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Yeah, definitely not stock ECU. It's an EFI Specialist ROM tune. We've talked to Khiem, he said it's all good.
Old 07-24-2011, 08:09 PM   #40
jr_ss
Have good grounds on the chassis/motor/etc? Sounds more like electrical inference causing the issue... I dunno just thinking out loud here...
Old 07-24-2011, 10:07 PM   #41
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Yeah we have good grounds. I'll check them just in case whenever the car is here again though. Probably tomorrow.
Still haven't tried a new maf yet either.
Old 07-25-2011, 02:28 AM   #42
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Tried a different MAF. Nothing.
Old 07-25-2011, 04:14 AM   #43
GSXRJJordan
Grounds are a great thing to start, but they tend to be more rev-dependent than load-dependent symptoms.
I'd start logging actual data, starting with MAF voltage. I'm guessing you're either max'n the MAF voltage or something's not getting enough power (voltage drop on an important component). Also what were your actual TPS readings at close/WOT, referenced to the TPS sensor ground?
Old 07-25-2011, 08:04 AM   #44
fullthrottle
Is it possible that the injectors aren't the size you thought they were and are actually flooding the cylinders at full boost? Did you buy them new or used? It would suck to have to get the flow test but if they are say 740cc instead of 550s or whatever you have it might not be flooding until a certain boost/load. Exhaust smell like fuel at all? Do you have a wideband?
Edit. Just saw that you said your a/f ratio is good.
Old 07-25-2011, 08:11 AM   #45
fullthrottle
Squeeze the intake and see if it's soft. It could be collapsing when the turbo starts to pull hard. Make sure the metal coil inside of it is spread out evenly through the whole intake pipe. If that's good double and triple check your couplers for cuts. Like around where it goes through the body of the car. Turbos build boost a lot faster than a compressor and can expand the couplers causing leaks that aren't apparent when testing for a boost leak. What psi did you bring the system to when doing your boost leak test? Make sure you test it at a lot higher psi than you plan to run. I test at 25psi to run 16psi.
Old 07-25-2011, 08:12 AM   #46
Sileighty_85
Sileighty_85's Avatar
What brand plugs and Heat Range are you running?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-25-2011, 01:40 PM   #47
StryfeS13
It's Always Broken.
StryfeS13's Avatar
The TPS voltage was .045 at closed, and like 4 something at WOT.
I'll try that today.
I tested it at around 20 PSI. I'm sure the car will never see more than 16 lbs.
NGK BKR7EIX gapped at .025. Have also tried .028, .022, .030, .032
I'm trying to convince him to switch to copper plugs.
Old 07-25-2011, 02:04 PM   #48
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Material isn't going to make any difference in this circumstance, just on the longevity of the plugs.
Do you have a way to log the values as you drive through the ECU or your consult port?
Old 07-25-2011, 03:10 PM   #49
StryfeS13
It's Always Broken.
StryfeS13's Avatar
No, unfortunately I don't..
Old 07-25-2011, 07:57 PM   #50
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Figured it out....intake was collapsing.
Thanks for all the help dudes!
Old 07-25-2011, 08:14 PM   #51
ultimateirving
ultimateirving's Avatar
haha, make note of that shit. hard to diagnose for sure! what did u upgrade to, post a pic plz. ima gonna be upping my boost soon and wanna make sure this dont happen to me. (E85 conversion in progress)
Old 07-25-2011, 10:52 PM   #52
codyace
codyace's Avatar
Trader Rating: (58)
Run a proper intkae tube and couplers
Old 07-25-2011, 11:36 PM   #53
StryfeS13
It's Always Broken.
StryfeS13's Avatar
The intake that was on the car actually had NO spring inside of it.
We got a new intake and all problems have been resolved.
Old 07-26-2011, 12:19 AM   #54
GSXRJJordan
Fairly common problem, and I think it was brought up earlier in the thread! Glad you got it figured out
Old 07-26-2011, 06:58 AM   #55
codyace
codyace's Avatar
Trader Rating: (58)
Yea those stock ones collapse so easily!
A friend of mine had an instance of his car actually sucking the plastic cone inside the intake filter into the intake, essentially closing off the the intake...it would do some wacky stuff until he sorted it out.
Old 07-26-2011, 07:37 PM   #56
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
Lol, what?
Can you take a picture of this happening and post it on here? It would bring this thread full-circle...
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 07-26-2011, 10:56 PM   #57
codyace
codyace's Avatar
Trader Rating: (58)
Originally Posted by bc. View Post
Lol, what?
Imagine the intake tube to the turbo sucking the rubber accordian junk (or crappy coupler) shut....
Old 07-28-2011, 02:15 PM   #58
91s13shawn
91s13shawn's Avatar
91s13shawn is an unknown quantity at this point
no i dont have one
91s13shawn is offline   Reply With Quote
Old 07-28-2011, 02:21 PM   #59
Tearlessj
Tearlessj's Avatar
I was just about to come in here and post that.
Funny story, I was a instructor at one of the events and everytime I drove this guys car it would do that. When he drove it didn't do it. We figured out it was his intake and I was flooring his car all the way and he wasnt. Go figure.
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 07-29-2011, 06:47 AM   #60
fullthrottle
What do I win for figuring it out?
