03-30-2013, 08:33 AM | #31 |
Trader Rating: (58)
Feedback Score: 58 reviews
Sounds like you're not assembling the mechanical side of it right at all.
- Set engine to TDC. THis is second mark from the left, or 0* with the first cylinder being up all the way too. - Make sure first cam lobes are facing completly opposite of each other (9 and 3) - Take out the tensioner -Locate the cam dowel pins. You want them at 10 and 12ish - Look at the little dots on the gears. This gives you the starting point/tooth 1 on both cams - Looking at the exhaust side, count the number of teeth on the gear between it and the head flange for valve cover. Between 8 and 9 teeth -Do the same on the intake. You're looking at between 4.5 to 5.5 teeth -Count the pins on the timing chain between both of the dots I mention above. 20 pins exactly. -Put tensioner back in, and crank engine over with a wratchet. Do this a few times and then bring back to TDC and reconfirm the alignment. Hope that helps. Install the CAS then after you sort the above.
03-30-2013, 08:35 AM | #32 |
Trader Rating: (58)
I tried doing a quick google search for pictures if you're visual
http://jimwolftechnology.com/wolfpdf...NSTFORSR20.PDF Installing Tomei Poncams on S13 SR20DET SR20 Setup Tips
03-30-2013, 11:01 AM | #34 |
Still something off...I got it to stumble finally like its firing on 1 cyl or something...still timing? Nothing could have possibly gone wrong electronic wise during the week of my head off. Everything is exactly like ^. Best I can get is one contant "Chug"? It feels like its still out of timing. Anything else I should try? Maybe moving teeth one way or the other with the cams?
03-30-2013, 12:24 PM | #35 |
Trader Rating: (58)
Loosen the distributor and crank it all the way in one direction (and try starting) and then the other way (and try starting it). You could be off a tooth for sure still, it's got to be precise
With that said, your plugs aren't potentially fouled are they?
03-30-2013, 12:50 PM | #36 |
If the cam timing was off what are the chances of bent valves? I didnt hear anything crazy but the exhaust cam was off by one tooth. It should still start up though right?
03-30-2013, 01:17 PM | #37 |
Well its got a cas but yeah i have tried that. They are brand new plugs. I just cranks and i will be like *wee wee wee blub wee wee blub blub* It will keep trying to kinda fire on one cyl if I keep cranking it. If I let off the ignition it sometimes chokes at like 100 rpm then dies. Not sure what else to do other than hand it over to a shop.
03-30-2013, 05:25 PM | #38 |
Trader Rating: (58)
Is the injector/maf correct for the ECU? Are both wired up properly too?
I'd start looking into troubleshooting other sensors now.
03-30-2013, 06:19 PM | #40 |
the maf was good before when it was running and I have no ecu codes. its gotta be timing still but I know its good. Ill post another video tomorrow of the timing components, grounds, cranking, and spark plugs
03-31-2013, 01:18 PM | #43 |
04-01-2013, 08:54 AM | #47 | |
do a compression test also just to check for any irregularities. that first video sounded SUPER weird
BustedS13: anything you can hide on your person is free. junkyard law. |
04-01-2013, 01:06 PM | #48 |
There I set it to public. Yeah it is weird sounding but all of my timing matches up. That first one might have sounded weird due to an 11 volt battery so it was kind of weak
04-01-2013, 01:28 PM | #49 |
cody is spot on a lot of people think you use the dimples but its the dowels , on the cams. 10 and 12 with the dowels. tdc on piston 1
My Twin Scroll Gt30r Sr22det Build |
04-01-2013, 03:00 PM | #51 |
what does a new compression test yield? also, idk if its just me, but is it cranking super slow?
04-01-2013, 06:16 PM | #53 |
Its at compression stroke TDC. The ecu was fried so i'm gonna get another one and see what happens. This is the 3rd ECU that fried lol. The first 2 came to me fried.
04-01-2013, 07:17 PM | #55 | |
Also,
04-01-2013, 07:25 PM | #56 | |
Banned from the Marketplace
So, I have no idea what's your P/N for the MAF, but it needs to be compatible with the ECU...... Lastly, it's not good at all that the ECU has been fried very often......The ECU lasts forever has long as nothing is wrong on the system....Once the problem has been solved and the ECU still got fried, an in-depth troubleshooting/analysis may be needed..... Hope the problem solved very soon Last edited by Kriskouki; 04-01-2013 at 10:13 PM.. |
04-01-2013, 08:56 PM | #57 | |
Trader Rating: (58)
With that said, you're got no fuel on 3 cylinders. I'd look into the ECU's you are using as for them not to fire 3 of 4, you've probably got some injector drivers fried out. They are rebuildable/repairable (through the right person) so don't fret.
04-02-2013, 04:09 AM | #58 |
Well I guess a mod should sticky a link to that video then. Anyway, I do in fact have fuel on all 4 cylinders I know cuz when i pulled the plugs out they were wet. I left them out so I dont wash out piston rings, thats how my KA went out. Im going to try a new 62 ecu and a new eccs relay. I was thinking about an AEM or Tomei or something like that you know? I was hoping to maybe find something more....sturdy (like a lobster). But once again I cant afford to break the bank so oem used looks like my main option.
04-08-2013, 04:29 PM | #60 |
So...did a compression test today. Found out cylinder 4 (one closest to the firewall?) was the only one with compression at about 100. The other cylinders had 0. Not sure whats going on. Cosworth Metal headgasket, Arp headstuds torqued to 90, copper tack spray on both sides of the HG. I dont know what else to do or if I should do a tear down and put new piston rings in...This is my DD and its already been down for like a month between waiting on parts and BS. Thanks
