Old 11-29-2011, 07:25 PM   #8701
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Originally Posted by Jm1hawk View Post
+50 in the front!!! that seems huge!!!!
I'm running 17x9j+22 with no spacers right now and -2* camber in the front. Still have a little more room.
After doing the math that's 3.62" of the wheel are on the outside and 5.38" on the inside. (From the face that meets the rotor).
I want to add a 25mm spacer. Making it 9j-3. Which would be 4.38" inside and 4.62" outside. Which I believe would still fit with just a roll. (S14)
With 17x7j+38 with 50mm spacer making it 7j-12. That would mean 3.02" on the inside and 3.98" on the outside. (Again, from face that meets rotor).
Really depends on what you want to do to the fenders, or how much camber you wanna run.
Unless my math is completely off............ If it's right, then to figure all this out it's simple.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 11-30-2011, 08:42 AM   #8702
ryandriftingfat
ryandriftingfat is an unknown quantity at this point
Any issues making the radiator support removable?
My car is track-only and it seems like it would be useful to be able to remove that piece. I currently have my engine bay down to just the metal and I have a spot weld removal bit.
The metal up front is all pretty thin, any issues with chassis strength?
ryandriftingfat is offline   Reply With Quote
Old 11-30-2011, 02:55 PM   #8703
killer skittle
killer skittle is an unknown quantity at this point
What would benefit from a removable radiator support?
killer skittle is offline   Reply With Quote
Old 11-30-2011, 03:15 PM   #8704
theriver43
theriver43 is an unknown quantity at this point
I've been having problems with my KA-T fluctuating boost when past about 75% on throttle, like so http://www.youtube.com/watch?v=mwgSBTsKp3Q. My EGR was leaking, so i blocked that off and as far as I can tell it is no longer leaking. My Z32 MAF (blow through) has started leaking again after I've used plastic epoxy to seal it back up. Now after another leak test I've found http://i.imgur.com/U3je7.jpg to be leaking. It's right below my EGR block off. What is it?
theriver43 is offline   Reply With Quote
Old 11-30-2011, 05:35 PM   #8705
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
None at all. Obviously some of the mounting pieces will need to be addressed but nothing major. I'd personally keep the lower rad support...but the next time I take out my motor I'm cutting the top piece and making it removable for sure.
On track, anything to make stuff easier to work on is a benefit, especially with time constraint.
Originally Posted by Irresistible View Post
Also, what's this black box thing in front of the front left wheel? Does it have to do with the intake?
Throw it out, just an intake resonator box
It seems like a huge vacuum leak causing the BOV to vent, or even the wastegate to act goofy. Hard to say without driving in it. You're running this off factory wastegate though? What if you stay in it for a bit does it keep doing the same thing? If so I'd venture to say it's a vacuum issue, or a bad vacuum source.
Old 11-30-2011, 07:27 PM   #8706
Irresistible
What is its purpose?
Old 11-30-2011, 07:49 PM   #8707
theriver43
Its a tial 38mm 7 lb wastegate. It does it from 1st through 4th. In 5th, it creeps to 15 psi. My source for bov is a distribution block off the brake booster. Wastegate is sourced from compressor housing on my precison sc50
Old 12-01-2011, 01:32 AM   #8708
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
nevermind, i got it!
killer240 is offline   Reply With Quote
Old 12-01-2011, 08:13 AM   #8709
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
it quiets the intake some... like an exhaust resonator will quiet your exhaust system.
Similar thing happened to me on my high boost. The old clamps I was using wouldn't hold the pressure during boost. Eventually they pop off. Went with tbolts and everythings good. So yea, like stated above, sounds like you have a leak. Atleast under heavy load. Though I have no idea what that pic is of.
VNG704 is offline   Reply With Quote
Old 12-01-2011, 10:15 AM   #8710
Irresistible
Lame... Thanks guys.
Old 12-01-2011, 06:46 PM   #8711
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
I'm wondering if its possible to widen a wheel that isn't 3 piece, and not have any structural issues to worry about?
GL Chrillz is offline   Reply With Quote
Old 12-01-2011, 08:18 PM   #8712
killer240
killer240's Avatar
Trader Rating: (24)
im planning to run 2 12" subs in the future and 4 speakers. is 200 amp circuit breaker good enough?
Old 12-01-2011, 08:30 PM   #8713
MeGusta
MeGusta's Avatar
MeGusta is an unknown quantity at this point
how much do you guys think i can get for a 5lug set up?
s14 spindles w/ s14 5lug , rear 5lug w/ uprights, Flca, s14 wheels with ok tires??
MeGusta is offline   Reply With Quote
Old 12-01-2011, 09:02 PM   #8714
killer240
killer240's Avatar
Trader Rating: (24)
^^ theres other 5 lug swap setups thats cheaper..
like J30 front hubs and press in your old bearings if their still good, Z32 rear n/a hubs or S14
Old 12-01-2011, 10:17 PM   #8715
andrew600
ill tongue punch her fart box
andrew600's Avatar
andrew600 is an unknown quantity at this point
where can i get a cheap intake pipe for sr with recirc fitting?
andrew600 is offline   Reply With Quote
Old 12-01-2011, 10:21 PM   #8716
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Anybody know anywhere I can buy replica BN type 2 kit for a s13 hatchback?
da_crew10 is offline   Reply With Quote
Old 12-01-2011, 11:05 PM   #8717
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
twin cam motor mated with a sohc transmission. Which year throw out bearing should I go with? an 89-90 or a 91-93?
ZenkiKid is offline   Reply With Quote
Old 12-02-2011, 04:20 AM   #8718
lflkajfj12123
Can anyone point me to some pictures of someone replacing the rear quarter panel on an s14? I believe I saw a guy cut out a quarter panel of a shell and weld it onto his car... thanks
Old 12-02-2011, 05:43 AM   #8719
doke! ドリフト
doke! ドリフト's Avatar
doke! ドリフト is an unknown quantity at this point
Maybe chaser aero? Or maybe they only have s13 bn aero..
Soap i can get you pics of a friends s15 qp getting replaced if that might help?
I'm gonna repost my entry from a few days ago since nobody responded..
I'm 5' 10" 155lbs I'm looking for a snug fitting bucket seat. Outta these seats has anyone owned or felt how they feel? Obviously the Zeta is ballin but whats the best for the price?
Order from lowest to highest priced..
About $210 ¡ÚUP GARAGE¾¦ÉʾðÊó¡ÛÃæ¸ÅÉÊ¡¡ŽÌŽÙŽ? ?ŽÞŽ¹Ž¯ŽÄŽ¼Ž°ŽÄ(¤½¤Î¾)¡¡CHARGESPEE D ¥Õ¥ë¥Ð¥±¥Ã¥È¥·¡¼¥È
$390 ¡ÚUP GARAGE¾¦ÉʾðÊó¡ÛÃæ¸ÅÉÊ¡¡ŽÌŽÙŽ? ?ŽÞŽ¹Ž¯ŽÄŽ¼Ž°ŽÄ(¤½¤Î¾)¡¡East Bear Sports SIGMA
$520 ¡ÚUP GARAGE¾¦ÉʾðÊó¡ÛÃæ¸ÅÉÊ¡¡ŽÌŽÙŽ? ?ŽÞŽ¹Ž¯ŽÄŽ¼Ž°ŽÄ(ŽÌŽÞŽØŽ¯ŽÄŽÞ)¡¡BRID E ZETA*¶ ¥Õ¥ë¥Ð¥±¥Ã¥È¥·¡¼¥È
AEM Series 2 ECU 30-6620 and Chase Bays S14 SR20DET engine harness for sale
doke! ドリフト is offline   Reply With Quote
Old 12-02-2011, 12:43 PM   #8720
wanabedrftr
wanabedrftr's Avatar
wanabedrftr is an unknown quantity at this point
Would a leaky front main seal cause oil pressure to be low?
fifteen52 <3 wheels sales rep HMU
wanabedrftr is offline   Reply With Quote
Old 12-02-2011, 01:26 PM   #8721
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
this ones an S13, haven't seen an S14 one yet.
http://zilvia.net/f/s-chassis/388007...placement.html
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 12-02-2011, 03:18 PM   #8722
Johnniesworld101
Johnniesworld101 is an unknown quantity at this point
Anyone happen to know if they motor mount off a single cam will work on a twin cam engine?
Johnniesworld101 is offline   Reply With Quote
Old 12-02-2011, 04:17 PM   #8723
David48
David48's Avatar
David48 is an unknown quantity at this point
Send a message via AIM to David48
Yes it will.
David48 is offline   Reply With Quote
Old 12-02-2011, 05:32 PM   #8724
fckillerbee
fckillerbee's Avatar
I remember seeing it in the max tire thread.
Old 12-02-2011, 08:10 PM   #8725
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
*flame suit*
was looking at aftermarket fuel rails, and they all seem to be top feed only, and right now I'm still running stock 270s. Can I use the sohc injectors in the aftermarket rail on my duel cam motor? With the use of an aftermarket rail, will i run into rich conditions?
Thx guys
nismoracingsx is offline   Reply With Quote
Old 12-02-2011, 08:58 PM   #8726
TougeLove
TougeLove's Avatar
TougeLove is an unknown quantity at this point
Can I use the bracket for sti brembos for a Rotora kit made for sti/wrx. im assuming yes but curious if anyone knows
Originally Posted by simmode1 View Post
Make a thread about it so we can sit in judgement of them too. Zilvia is an equal opportunity finger pointing forum.
TougeLove is offline   Reply With Quote
Old 12-02-2011, 09:03 PM   #8727
Irresistible
If the Rotora kit is made to simply bolt onto the STI/WRX then yes, it should work.
Old 12-02-2011, 09:12 PM   #8728
240Shwag
240Shwag is an unknown quantity at this point
Unless of course the rotora kit includes their own brackets, you would need to use both brackets and that would look silly or probably not even work.
240Shwag is offline   Reply With Quote
Old 12-02-2011, 09:23 PM   #8729
Irresistible
It would work, unless clearance issues arise. But I don't know about the safeness of using 2 adapter brackets.
Old 12-03-2011, 12:00 AM   #8730
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
Would Black RTV Silicone work to seal the taillights in a hatch rather than butyl rubber?
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
