Group Buys Dedicated Forum for Group Buys. |
07-20-2009, 12:17 PM | #1 |
Godspeed Cooling GB Page!!Intercooler, Radiator , Rad hose and MORE!!!
Godspeed Coolant Parts
EVERYTHING IN STOCK !!! READY TO SHIP AND PICK UP!!! KEEP YOUR MOTOR COOL!!! Nissan 180SX CA18DET Front Mount Intercooler Kit 4 X polish aluminum pipe 6 x polyester reinforced High temperature silicone hose(Blue Color) 12 x T-Bolt Clamp 1 x GODSPEED SPEC V intercooler (bracket included) Nissan 89-94 240SX S13 (SR20DET only) Front Mount Intercooler Kit 4 X pieces aluminum pipe 4 x polyester reinforced High temperature silicone hose 8 x T-Bolt Clamp 1 X VACUUM LINE 1 x GODSPEED SPEC V intercooler ( bracket included ) Nissan 95-98 240SX (KA24DE Only) Front Mount Intercooler Kit 6X pieces of polish aluminum pipe set up 8x polyester reinforced High temperature silicone hose 16x T-Bolt Clamp 1x GODSPEED SPEC V intercooler ( bracket included ) Nissan 95-98 S14 (SR20DET Only) Front Mount Intercooler Kit 4X pieces of polish aluminum pipe set up 5x polyester reinforced High temperature silicone hose 10x T-Bolt Clamp 1x GODSPEED SPEC V intercooler ( bracket included) Intercooler Spec. (Godspeed Spec-V) core length: 24" core height: 12" core thickness: 3" inlet / outlet size: 3" end to end length: 30 1/2" Nissan Skyline RB25 Intercooler (Also fit KA24 and SR20) core length: 24" core height: 12" core thickness: 3" inlet / outlet size: 2.5" end to end length: 29.5" Nissan 89-94 240SX S13 (SR20DET only) Radiator Hose 5mm thickness 4 ply reinforced High temperature silicone hose. Temperature Rating: -65F to 350F Pressure Rating:128 PSI Nissan 240SX S13 (SR20DET Only) Aluminum Radiator - Manual Only Radiator Spec. Core size- 360 x 645 x 53 mm (core size) INLET / OUTLET: 1 .25" Nissan 95-98 240SX S14 S15 (sR20DETT Only) Aluminum Radiator - Manual Only Radiator Spec. core size- 400 X 648 X 53 mm (core size) INLET / OUTLET: 1 3/8" Nissan 89-94 95-98 240SX S13 & S14 (KA24DE Only) Aluminum Radiator - Manual Only ~Will Fit Duel and Single Cam~ Radiator Spec. core size- 355 x 635 x 53mm " INLET / OUTLET: 1 .25" For The Best Price, Please PM or Call US !! (when you call make sure you say you are from Zilvia.net for the best discount!! We are S13/S14 Specialist, if you cant find what you need check out our website GodSpeed Project - Intercooler, Turbo Kits, Turbo Manifold, Body Kit or give us a call if you have any question!! We also have other GB on the forum, so please check them out!!! Ken @ Fatboy Garage Motorsport 2518 Continental Ave El Monte CA 91733 626-442-3988 Last edited by Fatboy Garage; 12-21-2009 at 05:27 PM.. |
07-26-2009, 03:15 PM | #4 |
How much for
Nissan 89-94 95-98 240SX S13 & S14 (KA24DE Only) Aluminum Radiator shipped to 94580? Also what's the big deal about manual vs. automatic? " - Manual Only" Just wondering. -Aaron '91 240sx coupe |
07-31-2009, 01:45 AM | #6 |
well....just a point
i have one of this FMIC kit,for CA18DET,and the siliconne hoses are not in a good size to mount the piping i had to buy a reducer between the throttle body(70mm) and the outlet side of the IC(76mm) another point,you have to buy another reducer for the other side of the IC,turbo side IC inlet(76mm) to the piping(55mm) so,it's not bolt on,and you have to buy these before mounting it. oh yeah,i bought also a radiator,and the side where is the bottom outlet,the radiator is higer than stock one,because the outlet is exceeding,about an inch,so you cannot close the hood. |
07-31-2009, 03:29 PM | #7 | |
did you install it correctly? Thanks Ken,S |
08-01-2009, 12:05 PM | #8 |
well,yeah it's not my first CA18DET uograde,with different sort of FMIC,and these problems appears after i put the engine in the engine bay inlet/outlet,i had to buy reducers(one 76mm to 70mm,for the throttle body,and one 76mm to 55mm for turbo side,and one 55 to 50 for the compressor outlet),brackets,etc....it's not bolt-on anyway all hoses are the same size,how can you put a 3" piping in a 2.5" hose.......not possible,sorry believe me,my client is a little bit hungry about this point.....he wanted to go with the car on hollyday,and he can't because of this. i'll take some pictures to show you. |
09-24-2009, 02:50 AM | #19 |
Trader Rating: (46)
Feedback Score: 46 reviews
i know this sounds stupid but...do you have a copy of instructions for installing the ka24de fmic kit? no hot pipe on this kit? and i picked this up in person and didn't get any brackets.
10-12-2009, 10:49 AM | #25 |
hey man the s13/rb25 fmic kit you sent me is missing some parts. im missing mounting brackets. and those long black things you have in the picture, idk what they are.
all it came with are these the slits are small to even fit the bolt. I sent you a pm man...... Last edited by Yum-Yum; 10-12-2009 at 11:27 AM.. |
10-19-2009, 04:07 AM | #29 |
You get what you pay for people. The ones having issues with mounting your fmic.. well its because the kit is so damn cheap that all you get is flat metal brackets. You need to mount it yourself.. fabricate your own basically. Only thing I have ever got knock off is a intercooler core and a radiator. I would never purchase a kit... they never fit right.
10-19-2009, 02:46 PM | #30 | |
and you said you got the intercooler and radiator, do they work or where did you buy it from? cause we have 3 years warranty for our radiator and intercooler, so if you have problem with them and is godpseed product , you probably still under warranty. Thanks Ken,S |
