Old 03-31-2008, 08:34 PM   #1
flclsteve
flclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant future
coilover spring gets caught (pix)
So the top part of the spring gets caught i just pulled the spring out a bit and it popped back in place. I wanna know what to do to prevent this from happening was not driving it too hard maby due to a bumpy surface tho.
flclsteve is offline   Reply With Quote
Old 03-31-2008, 08:47 PM   #2
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
is it popping out when its sitting or just when you lift it up?
@adrianfromthecastle
Old 03-31-2008, 08:48 PM   #3
usdm180sx
usdm180sx's Avatar
try tightening up the preload adjustment. if it doesn't have preload adjustment then you'll have to raise the car?
-Norm!
Old 03-31-2008, 08:49 PM   #4
benjim
benjim is on a distinguished road
You are either going to need to give the spring more pre-load or purchase helper/asist springs to provide the pre-load when the suspenion unloads.
benjim is offline   Reply With Quote
Old 04-01-2008, 01:17 PM   #5
ScarredOne
ScarredOne's Avatar
ScarredOne will become famous soon enoughScarredOne will become famous soon enoughScarredOne will become famous soon enough
Yeah, you need something like this:
http://more-japan.com/product.php?pr...6&cat=0&page=1
when your suspension unloads, helper springs will keep your coilover springs seated in the upper spring perches, yet will compress under the weight of the car when it's level. You should get another perch to fit in between the helper and main spring though.
ScarredOne is offline   Reply With Quote
Old 04-01-2008, 01:21 PM   #6
Silvia_S13
Silvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymore
do what everyone else suggested, or buy legit suspension.
sddrift.com - smirkis - poweredbymax.net
Silvia_S13 is offline   Reply With Quote
Old 04-01-2008, 02:20 PM   #7
flclsteve
very cool thanks alot im glad helper springs are not too expensive but ill be sure to get some next pay check.
Old 04-01-2008, 05:47 PM   #8
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
dont bother with the helper spring...your springs preload is off
jack your car up...take the wheel off...tighten your dampers lower perches up til the spring is FIRMLY against the top mount...tighten your BOTTOM PERCH (not the one directly below the spring) using a screw driver and hammer...tap it into place until snug...put the wheel back on and you should be good to go
Old 04-01-2008, 09:10 PM   #9
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
what are the name of those coilovers?
Jung918 is offline   Reply With Quote
Old 04-01-2008, 09:17 PM   #10
aznpoopy
aznpoopy's Avatar
either of the suggested solutions will fix your issue.
however, by raising the bottom collar until the spring is captive you will be raising the car.
if you don't want to do that and your coilovers are single height adjustable, you must use helper springs.
if they are dual you can reset height with the adjustable shock body.
whatever you do, don't forget to get an alignment afterwards.
aznpoopy is offline   Reply With Quote
Old 04-01-2008, 11:17 PM   #11
flclsteve
There actually JIC's some of there older ones
