Old 10-14-2012, 11:23 PM   #1
1slicktwo4oh
Trader Rating: (45)
1slicktwo4oh is an unknown quantity at this point
Feedback Score: 45 reviews
Exclamation Need some help or good mechanic shop in L.A>> No power to my ignition switch
Need some input or a good mechanic shop around L.A. Here is my problem. Original problem was my fuel pump had stopped working. I bought a new one and it still didn't pump, hooked it up to direct power, it worked...both pumps worked.
I assumed it was the sending unit got another unit, still nothing. While trying to figure out the fuel pump problem my switched died, no more power, changed the battery, nothing.i have a spare ignition switch swapped it out and same thing. NOTHING
Im getting no power to my ignition switch. I turn on switch no dash lights,no fuel pump(even though there is power to the fuel pump plug and the sending unit) my door locks work. There is power to all the cabin fuses and engine bay fuses although i really didnt know which to check i just wanted to see if power was going to the front.
I really dont have much time to work on it anymore so im more willing to take it to a shop to get it running again....looking for someone who has had work done by a certain shop around L.A 323/213/562/310 Area...SR swaps/electrical troubleshooting ++
Specs on car.
1990 S13 HB w/ Redtop E62 ecu
WS S13SR to S13 engine harness
Battery relocated to the trunk
NEED HELP...ZILVIA.
1slicktwo4oh is offline   Reply With Quote
Old 10-15-2012, 09:06 PM   #2
1slicktwo4oh
Trader Rating: (45)
Nobody??....I think i may be on my own then..time to re-evluate......ZILVIA you let me down...
Old 10-16-2012, 12:52 AM   #3
Jonathan Rivera
Jonathan Rivera's Avatar
Jonathan Rivera is an unknown quantity at this point
I sent you a pm I live in the area hit me up I got you..
Jonathan Rivera is offline   Reply With Quote
Old 10-16-2012, 11:49 PM   #4
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
We let you down??? This guy... Gl
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 10-18-2012, 10:29 PM   #5
1slicktwo4oh
Trader Rating: (45)
Obviously you wouldnt be the type of person to help^^^^so it s not directed towards you anyways. Maybe the idea of helping a FELLOW ZILVIAN, 240 owner seems too much for you.
Johnathan R^^^fixed my problem....:-P
Came thru w/ all his electrical testing equipment started going thru the entire car checking every plug, fuse, relay, underdash fuses, ecu, ignition..he found 2shorted relays, 2 shorted high amp fuses 1 in cabin fuse shorted...still working on fuel pump power problem...This guy is good cluster lights up, all gauges have power, engine cranks, all power. except pump...but it in progress..
He was compensated for his work, for those who think I was beign lazy or looking for free help.
Old 10-23-2012, 10:23 PM   #6
SharkMan
SharkMan's Avatar
Trader Rating: (28)
SharkMan is an unknown quantity at this point
Feedback Score: 28 reviews
Any luck with the fuel pump?
Front hugs or from behind hugs?
Originally Posted by nissan240 View Post
The Black Star Ninja is my real father...
SharkMan is offline   Reply With Quote
Old 10-24-2012, 03:11 PM   #7
1slicktwo4oh
Trader Rating: (45)
Havent got any spare cash to call..j.rivera back. I also need to rebuild my starter and get a smaller battery to move it back to the front... from what we found fuel pump isnt getting ground signal to the plug in the back.
Old 10-24-2012, 11:21 PM   #8
Taylor008
Taylor008 is an unknown quantity at this point
ECU switches the ground for your fuel pump.
I bet your ECU isn't getting power.
Taylor008 is offline   Reply With Quote
Old 10-30-2012, 10:31 PM   #9
1slicktwo4oh
Trader Rating: (45)
I have an auto E63...could i switch them out...or should i check the wiring going to the ecu
