Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Group Buys
Group Buys Dedicated Forum for Group Buys.
Old 04-30-2003, 11:01 AM   #1
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
REDLINE OIL. @ its LOWEST!!
this is more a special I am having than a group buy.
HERE IT IS!!
***While supplies last***
WaterWetter® Supercoolant is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30°F. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass, and bronze systems.
$7.95 ea
NOW $5.95 ea. (savings of $2.00 a bottle)
While Red Line Synthetic Engine Oils are derived from our Race Oils and are used by many racers, they were formulated specifically for street use in all kinds of passenger cars and light, medium and heavy trucks. Red Line Engine Oils outperform all petroleum-based oils and all other synthetics on the market today.
Our Engine Oils are designed to provide highest performance, best durability, ultimate protection and outstanding cleanliness along with lowest friction to your automotive, motorcycle, marine or stationary engine running on gasoline, diesel, alcohol or natural gas fuel.
At Red Line, we use the most stable synthetic lubricant base stocks available and formulate our products for wear protection and friction reduction across a wide range of engine operating conditions. Red Line lubricants are unique because they contain polyester base stocks, the only lubricant base stock type that withstands the incredible heat present in the hot sections of jet engines.
This high-temperature stability makes Red Line Engine Oils a necessity for proper lubrication of high-performance engines, turbo-charged engines, heavily loaded truck engines or any engine that runs high engine oil temperature. Red Line is not just for high-performance and racing. Ordinary cars and trucks that see "daily driver" duty benefit greatly when their engines are lubricated with Red Line engine oils. More performance, better fuel economy and increased durability come with use of our oils in daily drivers.
Because of the robust polyester base stock and high-performance anticorrosive additive package in Red Line oils, they are ideal for use in street-driven vehicles at extended drain intervals. Red Line recommends oil changes for engines that are in good condition and do not see frequent starts without warm-ups or short-trips at between 10,000 and 18,000 miles for gasoline engines, 10,000 and 12,000 miles for diesel engines, or every 12 months, whichever is shorter.
Red Line 10W30: Best all-weather viscosity grade for gasoline engines in cars and light trucks that are driven on the street on a daily basis. Reduces turbo lag and provides more power and economy while providing thicker bearing oil films at operating temperature than a petroleum 10W-40. Best all-round, synthetic oil for stock or slightly modified engines in high- performance cars that are street-driven. Best choice to replace a 5W-30 or 10W-30, petroleum-based or other-brand synthetic oil if maximum durability is preferred. Acceptable for engines that are occasionally operated in extreme cold weather.
Red Line 10W40: Best choice for engines that typically run high oil temperature. Best choice for engines in daily drivers operated in very hot weather on a regular basis. Best choice for medium and heavy duty gasoline engines in trucks. Best choice for high-performance engines that see street as well as frequent racetrack duty. Thicker oil film at operating temperature than a petro-based 20W-50.
10w-30 or 10w-40
$8.95 ea
NOW $6.95 ea. (savings of $2.00 a bottle)
75W90 Gear Oil - the preferred product in nearly all car and light truck differentials, both conventional and limited-slip. 75W90 is preferred for most racing applications. It contains friction modifier which is recommended for limited-slip units. 75W90 Gear Oil can be used in many transmissions and transaxles; however, other Red Line lubricants have better frictional properties for rapid synchronization. Exceeds API GL-5.
MTL - Manual Transmission/Transaxle Lubricant. A 70W80 GL-4 gear oil which is designed for manual transmissions which require 70W - 80W GL-4 gear oils, motor oils, or ATFs. It provides low temperature shiftability equal to an ATF, yet will not thin out or shear at high temperatures and provides the substantial gear protection of a GL-4 gear oil. The higher synchronizer coefficient of friction allows faster upshifting and downshifting and the lubricant is non-corrosive to synchros and bushings.
MTL or 75w-90 Gear Oil
$9.95 ea
NOW $7.95 ea. (savings of $2.00 a bottle)
Call to place order or paypal me at [email protected] (make sure you email me first for shipping charges)
thank you
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline
Old 04-30-2003, 02:34 PM   #2
boosteds14
boosteds14's Avatar
SOLD OUT of the 10w30
geez i didnt think this stuff would go this quick
I still got 4 cases of 10w40 left
3 cases of mtl
2 1/2 cases of 75w-90
thanks guys
240SXONE
Old 04-30-2003, 02:36 PM   #3
boosteds14
boosteds14's Avatar
o ya, i forgot
1 last case of water wetter.
240SXONE
Old 05-27-2003, 10:44 PM   #4
boosteds14
boosteds14's Avatar
UPDATE:
this is what is left
1 case of 10w40
5 bottles of Water Wetter
7 bottles of MTL
7 bottles of 75w90
240SXONE
Old 05-28-2003, 03:02 AM   #5
Maxtype 240
Maxtype 240's Avatar
Maxtype 240 is an unknown quantity at this point
Can't wait to get mine! The Water Wetter with the Greddy Alum Rad & FAL Dual fans should keep me cool... I'll look more into the 10w40. My car's been sitting for 3 months without me, it'll need some good lubing...
Jesse
'95 Nissan S14: KA24DET Daily Driver
Maxtype 240 is offline
Old 06-12-2003, 03:07 PM   #6
boosteds14
boosteds14's Avatar
UPDATE:
No more water wetter
case 10w40
2 bottles of 75w90
2 bottles of MTL
240SXONE
