02-08-2011, 09:56 PM | #32 | |
02-11-2011, 07:33 PM | #34 |
Im torn between these 2 i was told to get the 18G but it says max is 380 and if im going to be around 380 wouldnt i be better off running the 20G so im not maxing the turbo out?
03-07-2011, 02:50 PM | #39 |
holy crap thats cheap... i bought one used for $600 as up until a few months ago they were non existant with the sr20 flange.
These arent the same as the FP 20g's are they? |
03-07-2011, 05:06 PM | #40 | |
Thanks |
03-10-2011, 11:16 AM | #45 | |
only the 18G are in stock right now, 20g will be here end of April |
03-10-2011, 07:12 PM | #46 | |
Pretty sure there clocked different because when I was mocking my 18g up, i bolted the stock inlet and outlet on and they are clocked different then when on the stock t25. Kinda wondering whats needing to be done to fix this? |
03-11-2011, 12:16 PM | #47 | |
thanks Ken,S |
03-14-2011, 10:10 PM | #49 |
yea def need those clocking adapters for inlet and outlet pipes to work.
so far got mine installed on the motor. jus need clutch, injectors, and ems to get this thing running and see what numbers this bad boy can get .. shooting for 300+ ill snap some pics tomorrow! |
03-15-2011, 06:03 PM | #50 |
!Zar! is a good friend of mine (sitting next to me actually), and he has been running the td05 18g on his s13sr for about ten events now and only has good things to say about it performance wise. He should be getting a dyno run some time soon. If he does, I'll try to post them for him, unless he does so his self once he's unbanned.
03-16-2011, 12:20 PM | #51 | |
03-29-2011, 03:37 PM | #55 |
Ran 18g on my SR, very very easy 300hp, great turbo. had trouble with the drain line, but as long as you know what you're doing you're fine.
This turbo is a no brainer for the money, i drifted the absolute shit out of the car and ran the turbo at 18psi and it was awesome. The only bad thing I have to say about the turbo is the 5 bolt exhaust housing. The bolt holes were off by a little bit, took some drilling of the O2 housing, but I got it to work. I love this turbo. BAM. If you want video, PM me. |
03-30-2011, 06:38 PM | #56 | |
04-18-2011, 12:35 PM | #60 |
TD06 20G are now Available, ready to ship!!!
This is on a Black top S14 with 650cc injector , stock internal and 14.5 psi. TD06 20G Turbo Spec. Bearing system: Journal Bearing Compressor Wheel Diameter: 58.8 / 68mm TURBINE Wheel Diameter: 58.8 / 67.14mm Turbine TRIM: 57 Turbine flange type flange: T25 Downpipe flange type : 240sx 5 bolt type Nozzle Area: 8cm² Cooling type : oil and water cooled. Horsepower rating: 400-450 hp BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR) Actuator set at : 14.5 PSI CFM: 640 No Restrictor need for oil feed line TD05 18G $330 Shipped (Lower 48 State) $362.17 Shipped/Taxed (CA Customer) $310 Pick Up Preferred Cash TD06 20G *** IN STOCK $450 Shipped (Lower 48 State) $493.87 Shipped/Taxed (CA Customer) $430 Pick Up Preferred Cash Please PM for Payment Method. Fatboy Garage Motorsport Inc GODSPEED Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 ask for Chris W:godspeedproject.com Last edited by Fatboy Garage; 01-20-2012 at 10:29 AM.. |
