Old 10-13-2021, 10:58 AM   #1
ZenkiDK
ZenkiDK is an unknown quantity at this point
Start Signal Cranking Voltage
Hello Everyone,
I have an S14 with redtop sr20 that is having a starting issue. Can someone with a similar setup answer the following...
What is your cranking voltage on the following pins?
Pin 34 - orange start signal
Pin 36 - Ignition
Pin 38 - ECU Power
Thank You!
ZenkiDK is offline   Reply With Quote
Old 04-01-2022, 10:34 PM   #2
kennn
kennn is an unknown quantity at this point
Pin 36 - Ignition
Pin 38 - ECU Power
All the same, battery voltage (based on starter's current draw during cranking), unless your ignition switch is severely corroded.
I wish all questions were this easy... but I suspect this won't solve your problem.
kennn is offline   Reply With Quote
