Old 12-04-2012, 04:35 AM   #1
-oliveR
-oliveR's Avatar
-oliveR is an unknown quantity at this point
300kw CA Powered 180sx Drift Car
Hey dudes i'm Oliver, new to Zilvia but have been browsing on here for a while. I'm from Aus, love drifting and building cars. I have a few cars but thought I might as well throw up a build thread for my 180sx. Might make one for my S13 later on.
I bought the car in june 2010 as a mild street car with a slightly modified CA. Ended up destroying the motor so ripped it out and had a think about what to do next. I wanted to do something a little different so built a 2.1L CA and attached a GTX3071. Works really well so far and doesn't have an insane amount of lag.
It made 291.8kw without any issues. Drove it for the first time a couple weeks ago and had a sick time.
Also went to a drift matsuri a at the end of last month and had a crazy good weekend. Went through loads of tyres, got lots of videos and overall had the best time in the car.
Still have loads to do with my suspension setup and some aero so quite a fair way to go until I'm finished.
Here's a rundown of everything in the car.
Engine
CA18DET Stroked to 2.1L
Block bored, decked and honed
ARP main studs
ARP head studs
JE forged pistons – 20thou
JE piston rings
Spool forged 2L Crank
Spool forged Rods
ACL race bearings
Ross harmonic balancer
Siemens 1000cc Injectors
Splitfire coilpacks
CPC Custom plenum with RB25 throttle body
6Boost Custom high mount manifold
Garrett GTX3071r .64 rear housing
Turbosmart 45mm EX gate with screamer
EARL’s braided turbo lines
Tomei valve springs
Tomei 260° poncams
Tomei cam gears
Ported + polished head
1.2mm Cometic head gasket
3’’ Straight through exhaust
Exedy heavy duty clutch
Bosch 040 fuel pump
Cooling Pro 52mm radiator
19 Row MSCN Oil cooler
Suspension
HSD coilovers
Kazama toe arms
Kazama camber arms
Hey Man knuckles
Tien tie rods
Cusco strut braces front + rear
5 stud conversion with S15 LCA
Interior
Rewire from scratch
Link G4 Storm ECU
Defi BF – (oil pressure, oil temp, water temp, tacho and boost gauge + control unit)
Sparco 320mm suede steering wheel
Nismo shift knob
ERG 4-point harness
Sparco sprint bucket seats
6 point full cage
Custom switch panel and gauge plate
Battery relocate to back seat
Exterior
CA front bar with lip
Aero skirts
Type X taillights
Wheels: R33 GTR
Front – 17×9+5 (25mm spacer)
Rear – 17×9+30
Tyres: Federal 595ss
Front – 215/45/17
Rear – 225/45/17
I'll be keeping this updated as much as possible with everything I do so if you want some CA love keep an eye on it.
I have a blog if you want to see more info on the 180 or any of the others - Oliver's Import Heaven
Also have a page if you want more frequent updates - https://www.facebook.com/pages/Olive...91048287609971
Comments welcome
-oliveR is offline   Reply With Quote
Old 12-16-2012, 05:45 AM   #2
PG BOOSTED
PG BOOSTED is an unknown quantity at this point
I like that you stroked the motor. Does the power feel more responsive and is the lag not as strong?
PG BOOSTED is offline   Reply With Quote
Old 12-18-2012, 05:20 PM   #3
-oliveR
-oliveR's Avatar
Way more responsive than the original CA, has a lot more low end torque. The lag isn't bad at all, it's barely noticeable, boost comes on really quick and really hard too, bit hard to handle at times.
Bit of update on the car, I put on some pods and a type x wing that I'd been waiting to throw on for a while now. Finally had them painted during the week and came out looking like this -
I fitted up the wing quickly, came up looking pretty good. Not sure if Im a fan or not, might grow on me
Got back to a mates place and fitted up the pods. They look awesome
On monday I went drifting with some friends and had a blast, love driving so much
Then in my last session this happened..
Which resulted in this
So brand new freshly painted pods that I fitted on sunday were done. The other side is ok, but passenger side is completely destroyed. I've gotta go over the car before christmas, also need to save some money towards the next Winton Matsuri in february.
Also I finished my video recap from winton, check it out here if you want - Winton Matsuri 2012 - Oliver's CA Powered 180sx on Vimeo
Old 12-18-2012, 07:22 PM   #4
sex14
sex14 is an unknown quantity at this point
not a fan of bright colored cars but this orange looks good.
sex14 is offline   Reply With Quote
Old 12-30-2012, 07:26 PM   #5
-oliveR
-oliveR's Avatar
Sorry for no updates, bit stupid seeing how I said I would update it haha
I got the chance to get some new Powered by Max coilovers and fit them up.
I went drifting yesterday at a wet pan with a few friends. We had tandems and trains all day long, no crashed but pretty close. Some of the best fun I've ever had on a skid pan.
And I refitted my destroyed pod (helped by some really strong tape) and also decided to fit my once smashed passenger side skirt. Havent had a pair of skirts on the car since October 2010 when I originally smashed it into 50 pieces.
Hopefully someone puts up some photos of everyone driving.. So much fun
Old 01-18-2013, 04:46 AM   #6
-oliveR
-oliveR's Avatar
So not much has happened since my last skid day in the 180sx. I've played around with alignment a little bit, pulled out some camber, checked over everything mechanical and made sure it's all sweet.
Decided I'm going to work on my steering setup. I currently have Hey Man knuckles, I am looking to get some knuckles, have some LCA's extended and going to run either PBM tie rods or ikeya tie rods. Both are pretty similar priced and readily available, just have to decide on one.
I'm going to Winton matsuri again in 5 weeks so have to get a few things done beforehand. New cage to meet their rules, loads of tyres, some more wheels, gotta fix my quarter window and if I have some spare time I may get some front tubs which is a bit doubtful. Here's an updated shot of the bay, I need to polish it at some point.
Old 01-18-2013, 03:44 PM   #7
Oakville
Oakville's Avatar
Oakville is an unknown quantity at this point
Nice!
howd you get Illinois plates?
BNR32 connoisseur // 1990 GT-R
Oakville is offline   Reply With Quote
Old 01-18-2013, 06:07 PM   #8
PG BOOSTED
Loving this car man.
Old 01-19-2013, 03:23 AM   #9
-oliveR
-oliveR's Avatar
Originally Posted by Oakville View Post
Nice!
Just grabbed them from a friend in the states and had them sent over.. Got a matching pair for my s15 as well haha
Old 01-25-2013, 11:31 PM   #10
-oliveR
-oliveR's Avatar
Made a little vid from my wet pan day last month (sorry for lateness)
Epic tandems with a few friends, soooo much fun.
Check it out - https://vimeo.com/58140778
Old 01-26-2013, 02:25 PM   #11
Oakville
Oakville's Avatar
Nice! I'm digging the CA too...I'd love a big CA turbo
Old 01-31-2013, 03:09 AM   #12
-oliveR
-oliveR's Avatar
I entered Winton Matsuri again which is coming up in the next 3 weeks, had to get a new cage for the car that I fitted yesterday, also hoping to get my new knuckles in before I go down.
Had to get a new Optima dry cell battery because the cage took the place of the battery. I'll get a few photos up over the weekend of the new interior setup.
Got a drift day on this weekend, might get some more good tandems, can't wait
Old 02-11-2013, 02:55 AM   #13
-oliveR
-oliveR's Avatar
So wet pan skids last weekend was epic, made another video, check it out here -
https://vimeo.com/59361081
Also the cage went sweet! Looks better, feels better and hopefully will make the car more rigid than before. And also bought another set of 33 GTR Wheels so I'm all set in the wheel category.
Pic from wet pan last weekend -
SUCH EPIC FUN
Old 02-11-2013, 11:50 AM   #14
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
that is sick!!!
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 03-02-2013, 03:39 PM   #15
-oliveR
-oliveR's Avatar
Sorry haven't updated in a while, been busy as shit with work!
I've had some new bits for the car over the past few weeks.. New S15 LCA extended 25mm, Ikeya formula tie rods and some riverside (Kuroi) knuckles. Then went to Winton for the summer drift matsuri. Here's a few pics of everything.
My new knuckle setup -
Then it turned the car into this - (Super camber)
Then I went to Winton again for matsuri, got some pretty awesome shots
Also did a write up of my first day of matsuri, check it out here - Winton Summer Matsuri 2013 – Day 1 | Oliver's Import Heaven
I should have a video done soon and part 2 done this week with some more epic shots!
Old 03-23-2013, 07:33 PM   #16
-oliveR
-oliveR's Avatar
so haven't really done much to the car lately, after breaking the box at Winton I've been saving $$ and waiting for the new bits to arrive. I'm going with a Z32 box and using the mazworx adaptor plate. Hopefully this will last a bit better than stock CA boxes and also hope it's not a bitch to put it in the car.
Here's that video I made from winton - https://vimeo.com/61578541
And the day 2 writeup - Winton Summer Matsuri 2013 – Day 2 | Oliver's Import Heaven
and another awesome photo.
