Old 09-23-2014, 06:01 AM   #61
spools420a
spools420a's Avatar
spools420a is a well-known jackass
Originally Posted by supersayianjim View Post
-did you change your REAR MAIN SEAL?
This one jumped out and bit me right on the boo boo one time because I didnt replace it before a new shorty block install and turned out I had a leaky one when everything was installed,Though a small oil leak what happens is oil will get all over the friction clutch plates and depending on how bad the leak your cluch will be toast, mine lasted about a month with leaky rear main seal.
One thing you gotta consider is these motors mostley come from cars in a junk yard and who knows why that car made it to the yard to begin with.
spools420a is offline   Reply With Quote
Old 04-08-2015, 09:18 PM   #62
70ina30
70ina30's Avatar
70ina30 is an unknown quantity at this point
Wow so its been a while since my last update....
and as always im doing more research and trying to make this a clean build.
70ina30 is offline   Reply With Quote
Old 04-08-2015, 09:33 PM   #63
70ina30
70ina30's Avatar
I have cleaned it up quite a bit.
1. No more boost leaks or vacuum issues
2. Driveshaft installed
3. Gauges wired and working... old pic now removing the retarded air fuel and replacing it with digital temp gauge. Wideband 02 on order
4. Exhaust installed w test pipe. Loud!!
5. Installed new fuel pump relay and rewire to ecu pin 18. Took me forever to realize it was -ground not power lol
Now just got bumper and fenders and waiting on hood to align and install kouki conversion.
Backed it out to work on my pathfinder for a day. Figure I could snap a few pics
[IMG]http://i1286.photobucket.com/albums/a612/blacks_350z/20150408_214643_zps0rvadqas.jpg[/IMG
Old 04-08-2015, 09:57 PM   #64
70ina30
70ina30's Avatar
3 inch downpipe and exhaust.
3 inch straight test pipe welded in
Cut and cleaned up fuel rail. Installed new injector cushion rings into plenum also
Stainless clutch line
Old 04-08-2015, 10:38 PM   #65
JRex
JRex is an unknown quantity at this point
Coming along nicely. Can't wait to start my rb swap
Never Due
JRex is offline   Reply With Quote
Old 04-09-2015, 07:28 AM   #66
70ina30
70ina30's Avatar
thanks!!
the scariest part was turning the key for the first time. Thoughts running thru my head of an explosion lol
Old 04-28-2015, 08:08 PM   #67
70ina30
70ina30's Avatar
little clip of my fresh install
https://youtu.be/eeedoUT4RGQ
Yes I know some of you are not fans of the large tach.... I want an accurate readout of rpms.
just testing the engine revs. Testing out the new cometic gasket for intake. The freddy manifold came with one but it was a thin piece of metal that leaked air.
Testing out real Greddy bov. Need to adjust as its fluttering (too tight)
Testing boost pressure, oil pressure and some sweeet sexy exhaust sound
Old 04-28-2015, 08:19 PM   #68
70ina30
70ina30's Avatar
Old 04-28-2015, 09:58 PM   #69
blasian
blasian is an unknown quantity at this point
Lookin good
blasian is offline   Reply With Quote
Old 04-29-2015, 08:16 AM   #70
JRex
I noticed all your lines from your MC are steel braided. Are those custom or did you buy them as a kit?
Never Due
Old 04-29-2015, 01:34 PM   #71
70ina30
70ina30's Avatar
SS brake line kit from ebay. Works really well for ebay stuff... I needed new lines as I was deleting abs...ill see if I can find my purchase...
CARisma LLC Stainless Steel Engine Bay Brake Line Kit for 89-98 Nissan 240sx $175.00
Old 05-06-2015, 01:44 PM   #72
70ina30
70ina30's Avatar
Today i got a chance to install my power steering cooler and hook it all back up. 29 bux from autozone. Comes with all necessary pieces.
Old 05-12-2015, 09:43 PM   #73
70ina30
70ina30's Avatar
Aero package slowly coming in piece by piece.
got to work on my rear bumper for now. Still waiting on VIS hood from enjuku to go with new fenders and bumper (kouki) conversion
Not aligned yet. Just hung it to get a visual....
Old 05-24-2015, 07:41 AM   #74
70ina30
70ina30's Avatar
Still working on the kit.
Yes its duramax. Yes the fenders are crap fitment. However the front and rear bumper and side skirts arent that bad.
Working slowly on cutting so the fiberglass doesnt split
Lots of prep and sanding needed.
Again not great fitment but nothing I cant handle.
ill post before and after filler
Sides look much better and fit well
Old 06-09-2015, 11:30 PM   #75
70ina30
70ina30's Avatar
Hard to see in this pic, but I trimmed the edges and the corners of the fiberglass so it would sit flush and align for better appearance
Old 06-12-2015, 01:59 AM   #76
Tooley-s15
Tooley-s15's Avatar
Tooley-s15 is an unknown quantity at this point
this is going to be an animal
Tooley-s15 is offline   Reply With Quote
Old 06-23-2015, 08:42 PM   #77
70ina30
70ina30's Avatar
Got some more work done on front.
Used existing front bumper mount bracket and welded into place.
Old 06-24-2015, 02:39 AM   #78
Apex Eight
Apex Eight is an unknown quantity at this point
Nice work man, keep it up
Apex Eight is offline   Reply With Quote
Old 06-24-2015, 10:20 AM   #79
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
can you post pics how you ran hoses to this power steering cooler?
supersayianjim is offline   Reply With Quote
Old 10-05-2015, 09:03 PM   #80
70ina30
70ina30's Avatar
Finally got almost all the body finished up.
WrapPedro the car in Gloss Black. Still need to do the bumpers.
Got her tuned!
Old 10-05-2015, 09:05 PM   #81
70ina30
70ina30's Avatar
Old 10-05-2015, 09:10 PM   #82
70ina30
70ina30's Avatar
https://youtu.be/sMTsfw5wXaU
Video of engine revving.
Have a few others as well mostly testing and tuning.
