Old 05-22-2007, 02:37 PM   #1
BoosterZ
BoosterZ's Avatar
BoosterZ is making his/her stupidity well-knownBoosterZ is making his/her stupidity well-knownBoosterZ is making his/her stupidity well-knownBoosterZ is making his/her stupidity well-known
Send a message via AIM to BoosterZ
"Brick" headlight setups
Searched "brick light" but didnt find much.
Was wondering what setups you guys were running. Im planning on an 8k HID for the outer bulbs. Can I use the stock headlight harness? Or should i convert to H4 then use an H4 HID kit.
The 8k HID should be enough for hi/low beam applications, so what are you guys using the HC3 inner lights for? Fog lights?
BoosterZ is offline   Reply With Quote
Old 05-22-2007, 02:43 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
You shouldn't be using HID in "brick" headlights at all.
If you want HID, take a set of dual or triple rojector lights and retro-fi HID Projectors in them.
HID lights do not belong in reflector housings.
Old 05-22-2007, 02:47 PM   #3
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
Originally Posted by ThatGuy View Post
...HID lights do not belong in reflector housings.
QFT... retrofit or die.
Z_Spool is offline   Reply With Quote
Old 05-22-2007, 02:50 PM   #4
BoosterZ
BoosterZ's Avatar
I have the "brick" headlights. Correct? If so, guess i got to do the wiring. . . .
Again, sorry for the newbness, just getting to know the S13
Old 05-22-2007, 02:57 PM   #5
ThatGuy
Admin Asshole
ThatGuy's Avatar
Yes those are the reflector housing or "brick" headlights as they are sometimes called. They are not suited for HID lights though. Just put standard bulbs in them and deal with the lack of useable lighting. I am.
If you want HID lighting, then do what I said. Buy yourself some dual or triple projector housings, and retro-fit some HID projectors into them. Check out HID Planet if you are still confused.
Old 05-22-2007, 03:01 PM   #6
BoosterZ
BoosterZ's Avatar
Thanks! Will do for now. . .
Old 05-22-2007, 03:52 PM   #7
chmercer
chmercer's Avatar
put the clear lenses on the housings and put hids in the high and low beams. then aim the high beams as far down as they will go and wire both lights to be on at the same time. id probably use the pink hids.
you wont be able to see very good but itd probably look cool
chmercer is offline   Reply With Quote
Old 05-22-2007, 09:46 PM   #8
projectRDM
projectRDM's Avatar
If you really must do HIDs, do not go above 6000k. Anything above that is so blue you won't see shit anyway, not that would using a HID bulb in a halogen case, but you'll really run over children with your planned setup.
FORMERLY R240NA
Old 05-23-2007, 07:44 AM   #9
axiomatik
axiomatik's Avatar
I think you should sell your bumper to me to fund your lighting plans.
Drop-in HID's in halogen reflectors is a bad idea, especially in headlights with RHD beam patterns. Do what ThatGuy said, get some projector headlights and retrofit some HID projectors.
