Old 09-08-2014, 06:32 PM   #1
madman's240
madman's240's Avatar
madman's240 is an unknown quantity at this point
madman's sc400 pro-am build
Well this build happened off an impulse buy. I've always liked the way the sc300/400 chassis looked but they were always stupid expensive and out of my price range. Then one day I made a rant on fb about the price of these cars even with blown up motors or crazy body damage. Turns out a friend of mine knew a guy selling one cheap and put us in touch a few text messages later I sent my dad money to pay for the car and fuels and lunch for him and my uncle to go pick it up since I just started my new job in the oilfield at the time and didn't know when I was gonna have a day off and didn't want this deal to slip through my hands.
$400 later this is sitting at our house waiting for me to decide what I was gonna do with it (march 2013)
well after a few months of planning and and getting my financial situation stable I starting ordering parts to get the ball rolling. (September 2013)
after a few emails back and fourth I hooked up with Neo-motorsports for my suspension and braking needs
then I decided I was gonna drop a 1jz into it since it bolts right in. well I found a cheap auto swap in corpus picked it up dropped it off at our shop. Then I was on the hunt for a r154 well during my searchs I came across a decently priced soarer front clip with an r154. so I sold my other motorset to a friend. and purchased the front clip (oct 2013)
Then after talking to bigsticks about ecu's I purchased a pro efi pro 48 ecu and all the sensors I needed from the guys at D3 performance (nov 2013)
Then came the turbo side with so many options. I decided to go with the driftmotion billet 6262 turbo kit. mainly because it came with every thing I needed to go single turbo and wasn't crazy expensive and had a lot of good reviews. (dec. 2013)
then my niece decided that she wanted to model with it
Onto the fuel system. I purchased a fuel injector clinic fuel rail and 1050cc injectors. Turns out the injectors were discontinued so they upgraded me to 1120's since they were the same price.
(jan. 2014)
During this whole time frame I was purchasing all the little stuff I could for the motor todo maintenance and small upgrades. I bought all brand new oem timing belt tensioner, idler pulley, front and rear main seals, water pump, oil pump (just to be safe), greddy timing belt, thermal intake manifold gaskets, nst pulleys, fluidamper
finally the front clip arrived from japan and we get to work getting the motor ready to go in the car (jan. 2014)
madman's240 is offline   Reply With Quote
Old 09-10-2014, 07:25 PM   #2
madman's240
As far as the chassis goes went sent the car to silhouette garage to get a fd legal cage, gussets and all that good stuff (oct. 2013)
Started trimming down the wiring harness to the bare min.
Deleted the abs system,cleaned and painted the engine bay
Finally my sparco evo 3 arrived so we could build a steering column to get rid of the broken and heavy factory column. Then we installed the coilovers (jan. 2014)
Finally we got the motor as close as we could to being ready to drop in. sent it to my friend ken (aka the jz guru of Houston) had him do some minor things to the motor. Had him clean up my stock harness aswell as rewire it to work on the pro efi. Went ahead and had him install the motor and trans since I had very few days off from work todo it myself (oilfield life) (feb. - march 2014)
got every thing back then we started to build up the fuel system since we plan on going e85
Then we decide to change from a front mount setup to a mid-mount intercooler to try to hide the intercooler from cones and objects that may end up on course
Old 09-10-2014, 07:26 PM   #3
madman's240
now that the engine bay is as far as we can go until I order more parts. We moved on to finishing the chassis harness and installing and wiring up the gauges.
My dad made the metal dash inserts to cover the old ac vents etc..
then we painted the dash to match the rest of the interior
Cant have a racecar without switch panels and a radio
Then we repurposed the stock gauge cluster to hold the new gauges
Testing the new gauges
Old 09-10-2014, 07:28 PM   #4
madman's240
Then we teamed up with battle version for all my suspension needs. glad to have them onboard with all there amazing products
there will be more updates as we take my spare subframe strip it down and clean it up and install all theses bushing and arms
Started working on the trunk setup. still got a few things to work out before we start running fuel lines and mounting the surge tank and secondary fuel pump and filter. nitrous bottle was just for pics but were considering doing a intercooler spray bar depending on intake air temps.
Here's how the engine bay currently sits .
And for anyone wondering were the color scheme is coming from. I'm kinda coping my dad and uncles old drag car. I always loved the paint job. I'm currently working on getting a friend to vinyl wrap the car to match there old paintjob.
Old 09-17-2014, 01:12 PM   #5
madman's240
Well after starting to loose motivation in this build. I decided to goto fd tx this past weekend hoping it would respark my motivation to get the car finished. Well it worked i got home Sunday and started tearing out the stock fuel lines and getting the an lines ran as usual we ran into a couple of small issues with having a couple wrong fittings.
Pics to come once we get everything strapped up
Old 09-17-2014, 02:30 PM   #6
izzy-
izzy-'s Avatar
izzy- is an unknown quantity at this point
$400 is a great deal. I never see anything cool get posted in Illinois for cheap.
izzy- is offline   Reply With Quote
Old 09-17-2014, 05:48 PM   #7
madman's240
Actually I got the car for $250 & $150 for gas and food togo pick it up
Old 09-17-2014, 09:14 PM   #8
Apex Eight
Apex Eight is an unknown quantity at this point
Sweet build. Subbed
Apex Eight is offline   Reply With Quote
Old 09-22-2014, 02:07 AM   #9
madman's240
well we finally got most of the fuel lines plumbed and bolted in place
then this awesome piece of carbon showed up my dad got excited and put it together and placed it on the trunk for some rough pic got a wingless trunk that this will be going on
Old 09-22-2014, 03:12 PM   #10
Mannykiller
Mannykiller's Avatar
Mannykiller is an unknown quantity at this point
Sweet!!!! Looks good!
IG:@AAPARKAH #ThisIsTheWolf
Mannykiller is offline   Reply With Quote
Old 09-22-2014, 08:58 PM   #11
Maximo018
Maximo018's Avatar
Maximo018 is an unknown quantity at this point
Dude we gotta chat. Where in Houston are u? I firmly agree with the 1st 2 sentences of ur first post bcuz I've always and still to this day want that car since middle school. Wanna build a 1j 5spd 700whp. How ur friend put u down with one for $150-200 here baffles me? All the ones I find are $5-8k.
Maximo018 is offline   Reply With Quote
Old 09-22-2014, 09:01 PM   #12
Maximo018
Maximo018's Avatar
Great build btw. I gotta finish my RB Z31 1st.
Old 09-22-2014, 09:49 PM   #13
madman's240
North side tomball/magnolia area . Im over building the car should be able to put down close to 550+ but Im only shooting for 450-475whp reliably. Yeah I was complaining about $2500 cars with blown head gaskets or body damage. When he said he knew a guy with one that had blown hg and a bad transmission for $250 I jumped cause I knew I wanted togo jz.
Old 09-28-2014, 04:40 AM   #14
madman's240
well we finally got the fuel lines in the engine bay finished just gotta run a vacuum line to the fpr
now onto the trunk to get everything mocked up so we can cut the excess line. now we just gotta finish welded in the fuel cell mounts in since all we had was a cheap flux core welder to get everything tacked up. once the bars are welded its time to paint the trunk then final assembly gets started
Then instead of just using basic rubber line and hose clamps for the power steering system I decided to go overboard and make everything an braided line and fittings
Old 10-22-2014, 02:29 AM   #15
madman's240
So I've been slacking on the car lately cause I paid off my daily/ former pro am car.
That way I can start saving to buy a new tow rig since my old one deid in 2013.
But I did take my daily out to a practice event since its been over a yr since ive been behind the wheel.
Old 10-22-2014, 09:45 AM   #16
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
Very nice.. Can't wait to see another sick build in TX..
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 10-22-2014, 11:10 AM   #17
madman's240
Thanks man I cant wait till both our cars are out at events and driving.
Old 10-22-2014, 11:37 AM   #18
Royal_T
Royal_T's Avatar
AMEN!!! To that
Old 10-28-2014, 12:24 PM   #19
madman's240
Not a crazy update but we got my power steering cooler in. Gotta figure out how were gonna mount it so I can get the correct an fittings to run the lines.
Finally got my wheels put on now I just have to adjust the rideheight the rears coming down 1.5 in the fronts going up about .5- .75 in
Well I was about to order my drive shaft and a bunch of lil stuff I need but my friend made me an offer I couldn't refuse on his 350z shell. So this past weekend I loaded up and headed to baton rouge Louisiana to pick it up. its gonna be a future build but for now its just gonna get cleaned up and covered till im ready
Old 10-28-2014, 03:21 PM   #20
Royal_T
Royal_T's Avatar
what you get the Z shell for? Just wondering..
Old 10-28-2014, 06:18 PM   #21
madman's240
Probably gonna do a texas speed 408 lq9 & built 4l80 to take to tx2k style events
Old 10-28-2014, 06:48 PM   #22
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
I think he was asking price
Old 10-28-2014, 06:54 PM   #23
madman's240
Oh I picked it up for $1000 with a clean title
Old 10-28-2014, 06:59 PM   #24
future
future's Avatar
Trader Rating: (42)
That was a steal!
what didn't you like about the 350? Seeing how you wanted a SC instead.
couldn't have been much if you got another Z33 lol
Old 10-28-2014, 07:16 PM   #25
madman's240
Well the z is my daily and I just got it payed off. Didn't wanna keep trashing it too much.
But the main reason for building the sc over the z is the cost to make power out of the vq since its my daily I cant have it down for long periods of time.
Old 10-28-2014, 07:32 PM   #26
future
future's Avatar
Trader Rating: (42)
But thought the FC was the daily?
Old 10-28-2014, 07:44 PM   #27
madman's240
No the white z is my daily and old pro am car for 2 years. I picked the sc up about a year and a half and started building it I have yet gotten to drive the sc.
Old 10-29-2014, 10:08 AM   #28
Royal_T
Royal_T's Avatar
Fuck me!!!, damn I need to find deals like that.. lol
Old 10-29-2014, 11:22 AM   #29
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
how much does your pro-efi costs?? i also has a 1jz sc(400)
supersayianjim is offline   Reply With Quote
Old 10-29-2014, 11:25 AM   #30
supersayianjim
http://www.clublexus.com/forums/buil...ct-soarer.html
