Old 07-08-2016, 10:59 PM   #1
NismoKnights13
NismoKnights13 is an unknown quantity at this point
RB S13 RB26 swap
Not doing anything crazy with the swap right now just doing the minimum to get my car going
Purchased an R32 front clip
Working on figuring out the oil pan situation my self.
Going to cut and weld the stock down pipes
Feel free to comment with some help and productive criticism.
Taking the guts out of the Diff is pretty straight forward. Take off some bolts pry out and bang some stuff.
My cousin was kind a bough to help me with cutting off the diff peace. Took it to work and chopped it off.
Used this little thing to cut and grind the rest down. Pretty easy. The contents of this oil pan is pretty amazing! I don't think I'd feel safe using anything else.
Had this extra S13 crossmember laying around thought I'd put the McKinney mounts on it and tighten it down and seeing if it clears Lulz. I'm going to put on a new water pump, N1 oil pump and some new belts.. I'll keep you posted.
July 11, 2016
I tapped the axel pipe and it flew out! I was going to leave it in there. My logic was if it kept the oil out of the diff it'll keep the oil from spilling out. I was 100% going to regret it.
I put the pipe back in so shards of aluminum and aluminum dust won't get in there.
These rings came out after cutting a peace off of it.
The ring that's missing a peace ate up my grinder blade
July 14, 2016
I was working on the oil pan and my dad walks up and asked what are you doing now? Told him now it's time to weld this fat hole. My dad's a master machinist he suggests tapping and plugging it..
Here it is. The threader says 11 1/2 and the plugs are 1 inch. JB weld the plugs and used a silicon gasket for the oil pan
NismoKnights13 is offline   Reply With Quote
Old 07-14-2016, 04:27 PM   #2
NismoKnights13
Updated the thread.. Bump?
Old 07-15-2016, 02:59 PM   #3
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
holy shit. I didn't do this, when I did my oil pan it was a cluster fuck!
what did you use to cut that?
post # 246
http://www.240sxforums.com/forums/rb...t-s-rb-10.html
supersayianjim is offline   Reply With Quote
Old 07-16-2016, 07:51 AM   #4
NismoKnights13
post # 246
I actually didn't cut the diff off my self. My cousin took it to work. I guess they have a machine shop and chopt it off. The rest was that little grinder. I'm sure it would've but the diff off but not as well.
I'm not sure what you're trying to show me with that link...
Old 07-16-2016, 08:21 AM   #5
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
Do you have any flap discs? If not, go grab a few 36 or 60 grit ones. So much easier to work with than grinding discs.
lunchmeat is offline   Reply With Quote
