Old 08-06-2010, 02:32 PM   #1
ryandriftingfat
ryandriftingfat is an unknown quantity at this point
S13 - No power to rear wiper
Hi there,
I have an S13 hatchback, rear-wiper equipped, but the rear motor doesn't seem to be working.
Had the car a couple of months and the wipers haven't worked since I bought the car. I was able to fix the front wipers by replacing the fuse, but the fuse didn't fix the rear.
So this is what I've done:
-Replaced wiper motor
-Checked for power at the plug (the plug that goes into the wiper motor), no power
-Checked for power at the plug (next to the LHD passenger B pillar), no power
-Checked for power at the wiper amp, (next to the rear latch), no power
-Checked the switch next to the ignition, no power
I used a test light and verified that I had a good ground each time, so it doesn't seem to be sending power to that amp at all, as the break appears to be before the power switch.
I'm not the best with electrical stuff and I'm having a hard time determining where the lines running toward the Rear Wiper Motor Amp join with the main chassis harness, the schematic kinda 'ends' at plug M122 (the amp) and I can't tell where it re-joins. Also, I don't see a fuse for only the rear motor.
Can anyone help here, what am I missing? Thanks.
ryandriftingfat is offline   Reply With Quote
Old 08-09-2010, 07:13 PM   #2
ryandriftingfat
I figured it out.
The fuse just below the front wiper motor fuse is labelled "R/C MIRROR." I had ruled it out because my car has power mirrors, I assumed that was the fuse for them and didn't check it. Somehow, "R/C MIRROR" equates to rear wiper motor because it works now.
Fucking Nissan.
Old 08-09-2010, 07:21 PM   #3
g6civcx
g6civcx's Avatar
6th fuse down on the left side. Blue/White wire coming out of the back of the 10A fuse.
It says on the same fuse:
R/C MIRROR
RR WIPER
Old 08-09-2010, 08:52 PM   #4
ryandriftingfat
R/C MIRROR
RR WIPER
Negative ghost rider. It is a 10A fuse on the block, 6th down on the left though.
Old 08-09-2010, 09:31 PM   #5
g6civcx
g6civcx's Avatar
That's what I said.
Old 08-10-2010, 10:01 AM   #6
ryandriftingfat
That's what I said.
That's not what you said. There is no "RR WIPER" designation on the fuse box.
Old 08-10-2010, 10:54 AM   #7
g6civcx
g6civcx's Avatar
That's because your fusebox cover is from a base model with no rear wiper. It should say RR WIPER if you have the original fusebox cover that came with the car.
motor, rear, wiper, working
