Old 07-02-2002, 02:16 AM   #1
flipboi13
flipboi13 is an unknown quantity at this point
I finally got around to draining my trany fluid but now I dunno how to put the new fluid in?? My brain is kinda fried this week but I've run out ideas to get it in there... looks easy but i'm having a brain enema...
Hey, sorry guys if this has been answered before but point me in the right direction if it has...
- Phil -
95 240SX SE (w/ 4 lugs&#33<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
flipboi13 is offline   Reply With Quote
Old 07-02-2002, 02:35 AM   #2
rotaryknight
rotaryknight is an unknown quantity at this point
You can fill it from where the shifter goes in.....i think...i'm supposed to try it when I get back from my road trip.
You will need a C-clip removal tool.
Daily Driver- 91 240 SX SE...S13 Blacktop
HKS FMIC, EVC IV, W/G, Racing Suction, DP, Dual Drager, springs/pillow ball mounts
Whiteline sway bars
Tokico blues
Koyo Radiator, Fluidyne fan
J30 VLSD
stock exterior.
Fun Car- 94 FD3S (TO4S). The White HKS FD in FnF......may she rest in pieces.
rotaryknight is offline   Reply With Quote
Old 07-02-2002, 04:29 AM   #3
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
You can fill it through the shifter hole. However there is a drain plug on the side of the transmission. That is the level that you should fill it to. IIRC the FSM shows you putting your finger in the hole to check the level. Over filling the transmission would be a bad thing.
Lurker Supreme!
www.midatlantic240sx.com
  • 91 Coupe
  • 97 KA24DE+T SOLD
uuninja is offline   Reply With Quote
Old 07-02-2002, 07:15 AM   #4
bbp
bbp's Avatar
bbp is an unknown quantity at this point
Go to Home Depot (or whatever) &nbsp;and buy one of those long slender funnels. &nbsp;Then get a 3 foot piece of 5/8 clear vinyl tubing from the plumbing department. &nbsp;
Go home.
Jack up car, put jack stands under car (all 4)
Remove drain plug from bottom of transmission with a 1/2 rachet. &nbsp;Clean any metal shards of magnet on plug. &nbsp;When done draining reinstall bottom drain plug.
Remove the fill plug located on the drivers side of transmission.
From under the hood, slip piece of tubing down near the exhaust manifold/downpipe area. &nbsp;From under car, slip the end of hose into transmission fill hole. &nbsp;Get it in there so it doesn't pop out and dump gear oil all over the place.
From under the hood, put the funnel in the end of the hose and pour in you gear oil. &nbsp;Add gear oil until it begins to pour out of the fill hole. &nbsp;If alot comes out, wait until the flow stops before reinstalling plug. &nbsp;An overfilled transmission will blow the main seals and begin to leak.
I use Mobil1 gear lube. &nbsp;Have had bad results with redline screwing with the sycros.
now get to work!
bbp is offline   Reply With Quote
Old 07-02-2002, 08:45 AM   #5
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
There's a much easier way. &nbsp;Go to any autoparts store and get a fluid pump. &nbsp;Basically a long slender metal tube with handle at one end and a clear hose about a foot long at the other. &nbsp;Basically you put the hose in your trans fluid of choice and pull the handle which draws fluid up into the metal tube. &nbsp;Then put the hose into the filler hole on the trans and depress the handle to pump fluid into the trans case. &nbsp;Be sure to stop just below the hole (use your finger to check). &nbsp;It's not terrible if you fill it till it drains out the hole like I did, but then some of the fluid will end up on your garage floor after you drive it and it vents off the excess fluid.
The pump should cost you about $10 and will be money well spent since you'll need it for your diff too.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 07-02-2002, 09:40 AM   #6
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (bbp @ July 02 2002,08:15)</td></tr><tr><td id="QUOTE">Remove drain plug from bottom of transmission with a 1/2 rachet. Clean any metal shards of magnet on plug. When done draining reinstall bottom drain plug.
Remove the fill plug located on the drivers side of transmission.</td></tr></table><span id='postcolor'>
Which way to those things turn? &nbsp;I've seen some that didn't want to come out, so I'd rather confirm... is it (when facing the plug) clockwise or counter?
HippoSleek is offline   Reply With Quote
Old 07-02-2002, 09:47 AM   #7
bbp
bbp's Avatar
They are both normal thread. &nbsp;Clockwise to tighten, counter to loosen. &nbsp;Sometimes they can be a pain to remove. &nbsp;I have used a breaker bar on them to get them out in the past.
Old 07-02-2002, 11:54 AM   #8
HippoSleek
HippoSleek's Avatar
Thanks. &nbsp;What scares me is that I saw one strip out from using the end of a breaker bar. &nbsp;You just use the 1/2" ratchet head - no special tool?
Old 07-02-2002, 01:45 PM   #9
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
A 1/2in breaker bar works well. &nbsp;Takes some serious straining and effort but she will come out. &nbsp;We used a 3ft breaker bar to get civickilla's out <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'>
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 07-02-2002, 01:55 PM   #10
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
How do you know when to change the transmission oil?
Should it be changed every time you get an oil change?
HKrpS13 is offline   Reply With Quote
Old 07-02-2002, 03:11 PM   #11
flipboi13
Thanks guys for the help. &nbsp;I ended up going with bhp's idea and pouring the fluid into a plastic hose and letting it work its way into the trany.
- Phil -
Old 07-02-2002, 03:55 PM   #12
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
kinda dorky but -- &nbsp;"Righty Tighty, Lefty Loosey" &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
I used a pump and it was a pain b/c Redline come in smaller bottles, and the hose that came with my pump was too short to get the the bottom of the bottle's. &nbsp;I think BBP's way would have been MUCH simpler and much less messy. &nbsp;I got tranny fluid all over the place.
sykikchimp is offline   Reply With Quote
Old 07-02-2002, 09:17 PM   #13
riot
riot's Avatar
riot is an unknown quantity at this point
changing tranny fluid is pretty straight forward...I suggest using the funnel/tubing over the pump, it was way easier. &nbsp;I changed the fluid on a 1990 civic which felt like it had the original fluid that came in that B16 from japan. &nbsp;I used a breaker bar with a 3/8" driver and it came off easier then the oil drain plug came off. &nbsp;I was done in 15 mins...I imagine that a 240 will be similar if not exactly the same.
-ryan
riot is offline   Reply With Quote
