12-11-2006, 10:00 PM | #1 |
sr20det----higher rpms?
alright, i searched and couldnt find much, but who runs 8500+ on there sr20? and what is needed to do so, i was just looking into it because i wouldnt mind having some longer powerbands for drifting or w/e on tracks here and there
post up your setups and how well would this work w/ a s15 turbo? would the power drop after 7200? also...my other mods are greddy fmic, 550cc injectors, megan man...dp...and greddy exhaust, z32 and apex safcII, pullies, koyo and e-fan |
12-11-2006, 10:27 PM | #3 | |
use the new HKS valvetrain upgrades its specially designed for drifting so you rev higher
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
12-11-2006, 11:29 PM | #4 |
Man w/ CTSV & a Car Seat
Headwork and rom tune. If you dont have headwork, your liable to magically loose parts in your head. Namely valves and rocker arms...and whats this doing in chat, shouldnt this be in tech?
12-11-2006, 11:55 PM | #6 |
the HLA's are good for 7800 if you run good valve springs with under 12.8mm lift. SLA's def rock the socks off em but they need to be checked for lash every 2800-400 miles and its not the best thing for the wallet. an s15 turbo isnt gonna do anything but turn ur tea into piss over 7200RPMs... and stock cams arent gonna help the fact. Chance are - 8500RPMs hitting a rev limiter will flip a rocker off or pop something near it. You'll need to take care of those things before u wanna rev over 7500 normally.
Mainly - the valvetrain is the weakness in these motors - they break Rockers, float valves and guess what - it not a s2000 u dont need to drive these cars like u hate them - my suggestion is to get valve springs and cams - and some rocker arm stoppers in case - and rev it to maybe 7800. My biggest question tho - y do u want to rev that high with a s15 turbo? It's just gonna run outta steam. i can see if u had a GT35R and werent spooling it til late and u wanted more powerband, but u dont the other thing is - u have a stock ECU with that super gay timing. TUNE IT - afc=poop i have teh HKS valvesprings sitting here - they're better than stock - but not extremely strong... perfect id say for 7800rpm on a step2 cam. |
12-12-2006, 12:10 AM | #7 | |
Rocker Arm stoppers are a patch at best, get valvesprings, dual keepers for the rocker and SLAs. Go to Fresh Alloy and wait for MattBack or someone to answer. |
12-12-2006, 01:58 AM | #8 |
LOL - MBV will try to sell you his new lifters (they rock btw - but u'll be adjusting em once a month)
so you know - the HKS valvetrain upgrades are mediocre at best and that statement is ridiculous... MBV (MattBack Vass) is gonna tell you what i told you - springs and ur better, springs and SLA and ur golden. Dont use titanium ret on a street car - and dont have sex with farm animals. I just realized - this guy might not know what all these letters mean (or other people) - HLA = stock - hydraulic lash adjusters AKA Lifters and SLA are solid lash adusters (solid mechanical lifters which u must manually set lash) either way tho - stock cams with s15 turbo with a stock ECU = chokin the chikin P.S. - Rockerarm stoppers really wont do shit in the event of bad things happenin. I'm not even sure why i still have them in my motor. |
12-12-2006, 07:58 PM | #10 |
You guys also realized that MBV has problems shifting at that high of RPMs right? He has like, 15 trannies without teeth on 3rd gears, because the stock SR synchros don't like 9500rpm shifts.
So unless you ALSO have the Benjamins to pony up for an upgraded tranny, along with all the head work, then go right ahead for 9500rpm of goodness. |
12-13-2006, 08:42 AM | #13 |
Well sometimes it is beneficial to have those extra revs to stay in the gear longer.
I mean, if you're coming up to a corner, and you're pegging your rev limiter at 7800rpm in 4th gear, but going up to 5th gear would just take a few tenths off your lap time, what do you do in that situation? You would wish that you had at least up to 9000rpm just so you can stay in 4th gear and not pegging the rev limiter so that you can come to the corner and brake/downshift once or twice without having to worry about going into 5th and losing time and rhythm. |
12-13-2006, 09:54 AM | #14 |
The only point in having a redline that high is for a frickin huge turbo or for great safety. If I sitll had an sr I would definitely do his stuff.
With the tranny issue I have the same problem with my TurboII. They do not like to shift if you ride it out all the way to 8200. I dont have a very large turbo on the car anyway so I shift at 7700ish. The reason his dogs are dead is because it diddnt want to shift but he decided it was going to anyway.
I'm from Florida so I'm probably a bit more strange than you |
12-13-2006, 10:07 AM | #15 |
Ya I know. That's why I said unless you have a thing for broken 3rd gear teeth or unless you also have the money to shell out for a badass tranny along with all that headwork, it won't be worth it.
12-13-2006, 10:32 AM | #16 |
What are the differences between the 300zx and rb25 transmissions? The 300zx tranny is quite beastly as well, I wonder how it likes the high rpms. Good enough for a 9 second KAT I suppose but I have no idea how high they are taking it
12-13-2006, 10:35 AM | #18 |
It's not stupid to have a 9000rpm limiter when you have done everything right to achieve that rev limit, ie. cams, valvesprings, turbo, headwork, tranny, etc.
If you just upped your rev limit to 9000rpm without any supporting mods, that IS stupid. |
12-13-2006, 10:36 AM | #19 |
This may seem like a dumb question, but if you need to readjust every very often why not use thread locker or something on the solid ones? (or am I missing something in the design as the last set of solid lifters I had was a Honda)
05 Chevy Colorado - DD ~108k miles 35w 5k HIDs 85 Mustang - 355 SBC |
12-13-2006, 10:38 AM | #20 |
The adjusting nut does not necessarily slide down but there is vibration and wear. If your solution worked, trust me, it would have been done by now. Me personally, Iam going for a pnumatic valve train.
I think having a rev limiter that high makes complete sense for anyone drifting or road racing. Having the ability to go significantly higher then you will ever need to with a peak power at say 8 for the f of it is great. Safety man.
12-13-2006, 07:30 PM | #23 |
nothing wrong with hitting rev limiter...thats why its there
and as for tranny stuff, if i'm gunna have problems unless i upgrade that, maybe i'll just wait for next year then |
12-13-2006, 08:00 PM | #25 |
Trader Rating: (24)
Feedback Score: 24 reviews
Hey man, I don't care what you're talking about, nothing is safe to whack at 9000rpm's if you know what I mean....
I'm with wootwoot on this one, does anyone know what the 300ZX trannies have been up to and know what they are capable of doing? I was thinking of modding a bell housing off a 300ZX trans to fit my SR (adapters are costing CRAZY cash money!) so I wouldn't have to worry about transmission issues with some power going through it! After that who knows... if I could find out about this rpm ordeal, maybe I will see what I could pull off with my SR. All I know is I pitty the fool shifting at 7,500! |
12-13-2006, 08:33 PM | #26 | |
pshhh...who cares lmao...if i had a s2k..she would be bounsing at 9500 all the time lmao |
12-14-2006, 10:21 AM | #28 | |
12-14-2006, 10:24 AM | #29 | |
12-14-2006, 12:08 PM | #30 |
GT35R = 9000rpm goodness.
