Old 10-10-2011, 07:35 PM   #1
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
replacing SR20DET rocker arms
I have a rebuild going on and I'm thinking of replacing just my rocker arms since the ones on there are showing a bit of wear. I got all my shims numbered etc but I'm wondering if I have to re-shim cause I'm getting new rockers. Thanks for any input and yes I have searched but nothing specific comes up
R@ddy is offline   Reply With Quote
Old 10-10-2011, 07:54 PM   #2
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Dont have to re-shim since all the rockers are the same size.
Luvs2slide is offline   Reply With Quote
Old 10-10-2011, 10:47 PM   #3
R@ddy
Trader Rating: (32)
anyone else have any input on this?
Old 10-11-2011, 06:41 AM   #4
brickerj
brickerj is an unknown quantity at this point
If you're talking about the shims that sit on top of the valve stems, no. Their purpose is to make sure that both valve stems are the same height so that the rocker arm is level which isn't affected by the rocker arms at all. The height of the rocker arm is controlled by the lash adjusters. If you're running solid lash adjusters, yes you should re-shim these while you are in there (really just a 'might-as-well' thing; you should be checking the lash periodically regardless). If you're running the stock hydraulic lash adjusters you don't have to do anything because the height is controlled automatically. That is, as long as you kept them upright the entire time. If they were ever in a position that wasn't standing upright you will have to bleed them before installation.
All of that being said, what exactly did this rebuild include? If you had your valves replaced/relapped/anything that involved removing them from the head, I would certainly re-shim because it is highly unlikely they are at the same height as they were before the rebuild.
brickerj is offline   Reply With Quote
Old 10-11-2011, 07:24 AM   #5
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
define, "showing some wear"
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 10-11-2011, 07:37 AM   #6
Leetfade
Leetfade's Avatar
Leetfade is an unknown quantity at this point
This is very, very simple. I did this as well as I had grooves in my strike plates on my old head. Made a ton of noise (sounded like rod knock almost). I replaced these and it made a world of difference.
If you have the factory HLAs (as mentioned), you do not need to reshim. DO NOT TAKE THE SHIMS OUT. You don't want to mismatch the shims that are currently in there or you could have an issue. I do, however, recommend you take the extra 10 - 20 minutes and bleed the HLAs with clean oil. It will get the old gunk out and help prevent any sticking.
I have a BNIB set of rocker arms for sale if you're interested. Just let me know.
Leetfade is offline   Reply With Quote
Old 10-11-2011, 07:53 AM   #7
Boost_Fiend
Boost_Fiend is an unknown quantity at this point
Yeah like the people about above have said do not take them out. If you absolutely have to you are going to have to remember exactly where they go. I made the mistake of dropping my head during my rebuild and all my shims and guides went everywhere. If it makes you feel any better I said f**k it and just threw them back in there and am about 6000 miles on my motor and no issues at all. My valve train makes as much noise as any other sr.
Another person on here has mentioned that since the sr uses HLA's that it would automatically adjust the height and that is what I thought but I have been told otherwise and you need to reshim. Idk I say just make sure you bleed them correctly and you will be ok
Boost_Fiend is offline   Reply With Quote
Old 10-11-2011, 09:12 AM   #8
R@ddy
Trader Rating: (32)
The shims will be going to they're original spots..no mixing up or anything..just getting new rockers. Thanks guys
Old 10-11-2011, 09:23 AM   #9
s14unimog
s14unimog's Avatar
Trader Rating: (22)
I bleed my lifters every time I have the cams out it's just too easy to do while you're there. Do it.
Old 10-22-2012, 08:39 PM   #10
Matman03
Matman03's Avatar
Matman03 is an unknown quantity at this point
Shim Size
What size are the stock shims? I cannot find that statistic.
Matman03 is offline   Reply With Quote
Old 10-22-2012, 08:52 PM   #11
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
i think i measured them at .096" average... thats totally off the top of my head though. when i rebuilt my sr, i used a set of calipers to make sure that each rocker arm had the exact same size shims on each side. there is a difference in size between them. some were as much as .003-.005 thicker.
AsleepAltima is offline   Reply With Quote
Old 10-26-2012, 01:46 PM   #12
steve shadows
steve shadows's Avatar
If you do re-shim make sure to get a re-shim tool. Bleed the lifters while you're in there, don't mix up the shims or the ninja angels of nissan gods will literally haunt you forever and your car will not right also. But everything else has pretty much been covered in this thread. Swapping lifters is super easy, just pop the cams out of the way and you're in business. Just make sure to tie off the timing chain tight so you don't have to go fishing for it at he bottom of the timing cover. This will make a simple lifter swap a job from hell.
Like Me on FaceBook !
