Old 07-09-2012, 11:19 AM   #1
doitsidewayz
doitsidewayz's Avatar
doitsidewayz is an unknown quantity at this point
j3 axle...problem
got an j30 axle but the seal on the passenger side came out...and 2 balls and some grease...will it still work if i just slap them back on?! lol
doitsidewayz is offline   Reply With Quote
Old 07-09-2012, 11:22 AM   #2
Edwin562
Edwin562's Avatar
you can go replace for like around 40-60 bucks at a local auto store. you dont want to lose those balls again.
Old 07-09-2012, 11:45 AM   #3
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
like he said, because no one ever wants to lose their balls......
JFoxx is offline   Reply With Quote
Old 07-09-2012, 12:02 PM   #4
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
definitively doesn't sound like a good idea.
dude, I just took my j30 axles to O'reilly's for a rebuild, and they we're able to get them back to me within the day (took them in the morning, they called for me to pick up in the afternoon). they even spray painted all the surface rust black. Costed me about $55-60 per axle.
@adrianfromthecastle
Old 07-09-2012, 12:54 PM   #5
doitsidewayz
thanks guys. i picked up the axle's from the pull apart today. i have a z32 vlsd going in soon and i need them. i also have the z32 axle's and one of them looks about the same size..what do yall think!?!
Old 07-09-2012, 12:56 PM   #6
doitsidewayz
mite try this if the z32 one i have does not work.
Old 07-09-2012, 12:57 PM   #7
doitsidewayz
yeah deff. good thing they landed close to my face when i was pulling the axle off the j30.....lmao
Old 07-09-2012, 03:49 PM   #8
adrians_s13
Trader Rating: (29)
if i recall correctly, the z32's are actually a different size. I think they're a bit longer by an inch or so... which makes a huge difference. good luck with that one
Old 07-09-2012, 04:49 PM   #9
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Yup Z32 NA is longer hence why people source the J30 axles or JDM s13/s14 ones.
eek is offline   Reply With Quote
Old 07-09-2012, 04:52 PM   #10
Edwin562
Edwin562's Avatar
so balls fell on your face when you were yanking out the axle shaft.... Definitely not homo
Old 07-10-2012, 09:03 AM   #11
doitsidewayz
I called autozone, oreilleys, advance etc. they dont rebuild them, they dont have them, they cant get to them...
Old 07-10-2012, 09:32 AM   #12
doitsidewayz
Having both z32 axles and j30 axles look about the same size...
I had a friend told me he had his z32 diff and axles on his s13.
Old 07-10-2012, 03:25 PM   #13
doitsidewayz
Any one?!?
Old 07-10-2012, 07:33 PM   #14
eek
Trader Rating: (29)
Why don't you look in the phone book and call around and see if there are some local shops that can rebuild your j30 axle for you. I'm sure there are more than 1 in your area you just need to find one. I've always ran j30 axles when getting the Z32 NA VLSD never had any issues and this was on 5 different s-chassis. As far as the z32 NA axles go, I remember them being a tad longer, you can try them out if it makes you happy.
Old 07-10-2012, 08:35 PM   #15
doitsidewayz
I'll post a pic when I get home. I have them side by side and te z32 one looks like maybe 1/4 of an inch shorter
Old 07-11-2012, 12:46 AM   #16
doitsidewayz
Pic of passenger side axle (z32 left) (j30 right) side by side ImageUploadedByTapatalk1341989196.441125.jpg
ImageUploadedByTapatalk1341989212.891512.jpg pic of the seal that popped off...
Old 07-11-2012, 10:20 AM   #17
doitsidewayz
No luck on finding some one
Old 07-11-2012, 10:30 AM   #18
ixfxi
ixfxi's Avatar
ixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfection
that happened with my j30 axles back when i ran them, its no big deal. slap them back together with grease and its FINE. i never had a problems.
ixfxi is offline   Reply With Quote
Old 07-11-2012, 10:56 AM   #19
doitsidewayz
What type of grease did you use?
Cv joint grease?!
Old 07-11-2012, 04:34 PM   #20
ixfxi
ixfxi's Avatar
i scooped the grease up off the floor (since my floor is relatively clean) and called it a day
find a grease that is the same type, or go to a shop that works on drivetrain and ask them
i would imagine you are right tho, cv grease seems like it should work
Old 07-11-2012, 05:01 PM   #21
Edwin562
Edwin562's Avatar
Mike, did the balls fall on your face as well?
Old 07-11-2012, 05:12 PM   #22
doitsidewayz
Balls are back on the shaft. Lol And got fluid. I guess Im going to slap the diff in sometime this week
Old 07-12-2012, 08:41 AM   #23
ixfxi
ixfxi's Avatar
correction
my balls landed on the axle when i was attempting to ram it into the hub
i used too much force and all of a sudden, the grease landed everywhere
