01-20-2009, 10:03 PM | #2881 |
You wont have to upgrade anything else. I had 4.5 degrees of neg camber to be exact and with 20mm fenders it was pretty flush also a lot of pounding on the inner fender. I have a pretty aggressive stance like you are going for. You should be good with the camber and hammering/wire tuck
http://walk2liv.blogspot.com/ |
01-20-2009, 10:23 PM | #2882 | |
Blow me, bitches. |
01-20-2009, 11:31 PM | #2883 |
For everyone who is confused about the collars on the coilovers, these are what we are talking about (blue lock collars on the coilover)
If your coilovers are set on max low and you want them lower, you can screw the spring collars down to the bottom collar. If its still not low enough, start pulling them out. You really only need 1 to lock the threaded part of the coilover in and the spring will sit on top of it. Be careful, if you start pulling collars, make sure your kit is off before you slam it down or else you will be picking up aero off your garage floor
Battle Idol Works 2015 |
01-20-2009, 11:51 PM | #2884 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
uh...ive always been curious for you guys who start removing your collars to slam your cars...do you actually check your suspension travel after you do this??? cause u know you can actually RUIN your dampers VERY easily if you lower them like you are
01-21-2009, 01:38 AM | #2885 |
No you can't. Unless you buy Ksports or some other piece of shit coilover with spring rates that are less aggressive than stock......Tein included
Besides, you have three choices, low as shit, set up race wise (technically "right"), or buy Part Shot Max coilovers and get both TONS of people in japan who are lower than shit and can drive like a motherfucker have no clue what the suspension setup on their car is and they don't care because the shit works
01-21-2009, 01:41 AM | #2886 |
Trader Rating: (29)
Feedback Score: 29 reviews
don't forget the "flip your bracket" mod for getting even lower... that is if your coilovers allow you to
@adrianfromthecastle |
01-21-2009, 09:01 AM | #2888 |
Trader Rating: (44)
Feedback Score: 44 reviews
Turning the bracket (on the coilover) that bolts to your front spindle "upside down" will allow for more lowness.
www.realize-jp.net |
01-21-2009, 09:30 AM | #2890 |
You probably don't want to hook your brake lines up to the brackets if it's upside down...
01-21-2009, 09:34 AM | #2891 | |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
01-21-2009, 09:55 AM | #2893 |
Yes, and just leave one. It seems to have 3 in the picture. Remove 2 and leave the on that the spring sits on and adjust down. Its not that hard guys come on..lol
01-21-2009, 10:04 AM | #2894 | |
OR Screw down the top two all the way down until they hit the bottom collar (I would try this one first to see if its low enough for you) My car is "setup" right now but with my BN Kit I drag in a straight light if I drop them all the way down
01-21-2009, 10:08 AM | #2895 | |
That's how it's done on a lot of high end shit too. |
01-21-2009, 11:10 AM | #2898 |
Super Moderator
Trader Rating: (73)
O ok, my shit isn't even connected anymore, I guess my bracket clip disappeared.
01-21-2009, 02:23 PM | #2899 | |
Please stop spreading misinformation. 1. dorkidori was talking about dampers (the shocks, not the springs). 2. Yes, you can ruin them, but these Asian coilovers never post a shock dyno and don't list what brand shock, because its probably garbage anyways. 3. Apparently you know TONS of people in Japan. I'm pretty sure anyone who CARES checks their suspension travel. If they don't care its because (like I said) its probably some garbage shock. Not some Ohlins, or Koni, or Bilstein, or any high end shock brand. And I take it its cheaper and easier to come across those coilovers over there so they're easy to replace. HowStuffWorks "How Car Suspensions Work"
01-21-2009, 02:47 PM | #2900 | |
01-21-2009, 02:58 PM | #2901 |
I have never seen Rota Grids in these sizes before...were these special order? If not, I'd love to know where you bought them. Car looks great!
Originally Posted by roksta2s New set of Rota Grids 18x9.5 +15 all around. Tires are 225/40 F, 245/40 R This image has been resized. Click this bar to view the full image. The original image is sized 1024x699 and weights 166KB. Rules:
Signature Infraction! Read the Rules for Signature Sizes.. |
01-21-2009, 03:03 PM | #2902 |
Ask SlideAlliance, he's the one who went into that topic direction. But I felt the subsequent misleading post had to be cleared. Back on topic.
01-21-2009, 03:04 PM | #2903 |
i think i would take out the bottom 2 and leave the top. im sure you know this but the 2 bottom collars are locking collars. VS the one at the top which holds the spring. and the locking collars look to be smaller in diameter compared to the spring collar. i dont know if that would create any problems but yeah i dont know just my 2cents.
rip bobby.. you will be missed.. |
01-21-2009, 03:09 PM | #2904 | |
Then the collar above the lower bracket locks onto the bracket to prevent the bracket from spinning on the shock body (or the shock body spinning after it's on the car). If you take 1 collar off, take the 1 off of the top of the lower bracket, and use it on the bottom of the bracket instead. If you take 2 collars off, leave the collar that the spring sits on, and tighten that all the way up to the lower bracket, and use the 1 collar below the lower bracket to lock everything into place. You can't just let the coilover body free spin on there, or else you're gonna run into problems left and right with the coilovers. |
01-21-2009, 04:29 PM | #2905 | |
i was just saying that if i was going to remove collars and let the spring sit on a collar. i would leave the top one. because its bigger than the locking collars..
01-21-2009, 04:30 PM | #2906 |
Yes you have to leave that one, because that one is designed for the spring to sit on it. The other collars are not.
01-21-2009, 05:14 PM | #2907 | |
anyways heres some random wheel fitment. on my old Z.. 14x7 -42 haha
01-21-2009, 06:36 PM | #2910 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
He might be stacking spacers...
