Old 03-13-2013, 11:34 PM   #91
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
I want to really see how that turns out
jdm2191 is offline   Reply With Quote
Old 04-10-2013, 12:48 AM   #92
MC.Understeer
MC.Understeer is an unknown quantity at this point
Been really slacking on working on the car the last month but this week ive been busting ass because I have back to back events coming up in a week and a half so I need to get it running and ready to go. As of today this is where im at with the car and im very close to starting her up.
Picked up a new seat since my old ones had expired FIA tags
picked up some new front brakes for a really good deal
S13 rotor compared to the new 15" rotor
Tons of clearance in a 18" wheel
Brackets to make them fit
MC.Understeer is offline   Reply With Quote
Old 04-12-2013, 09:32 AM   #93
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
What brakes are they I've never seen them?
collegekid is offline   Reply With Quote
Old 04-12-2013, 12:29 PM   #94
E's factory mx83
E's factory mx83 is an unknown quantity at this point
Look like corvette's bbk
E's factory mx83 is offline   Reply With Quote
Old 04-12-2013, 12:42 PM   #95
taeisbeast
taeisbeast's Avatar
taeisbeast is an unknown quantity at this point
This an awesome freaking build man.
Keep it up.
taeisbeast is offline   Reply With Quote
Old 04-12-2013, 12:57 PM   #96
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
I'm assuming the S/C pic was just for shits and giggles?
Is that just an ebay Greddy Intake manifold Repica? If so how is the fitment by the brake booster?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 04-12-2013, 01:22 PM   #97
jk26
Trader Rating: (31)
jk26 is an unknown quantity at this point
Feedback Score: 31 reviews
CTS-V im pretty sure
jk26 is offline   Reply With Quote
Old 04-14-2013, 09:22 PM   #98
MC.Understeer
Supercharger is not for shits and giggles. I have it ready to go minus the charge pipe situation. Im going to break in the motor on low boost with just the turbo and do some testing with it and then deal with the supercharger project on its own. Right now I have 30 different things to deal with the swap but I think she'll be ready to fire up for the first time tomorrow after the ecu gets all setup and the firmware up to date.
Brakes are 2012 CTS-V 6 pistons from the newer awd models.
Old 04-25-2013, 09:43 AM   #99
MC.Understeer
Finally got her running. Having crank signal errors not allowing me to rev past 5300 but im sure its due to the weak quick crank sensor bracket I made. Going to redo the bracket to reduce and movement or bad harmonics.
http://i49.photobucket.com/albums/f2...ps309ffb0a.jpg
2jz pink beast #2 - YouTube
Old 05-14-2013, 10:58 PM   #100
MC.Understeer
Little Dyno video. Still working out some bugs, crank sensors keep failing so finally im going with an Oem sensor instead of an aftermarket oem replacement. Im 99% positive its why im getting high rpm miss along with my ID1000's and fuel pump maxing out at 550whp/600wtq 22psi. I'm pretty happy since im running wasted spark (3 oem aristo Is300 style coilpacks) VVT-i is also not hooked up yet either.
Jeff Woodruff - 2JZ DYNO - GCMedia - YouTube
Old 05-14-2013, 11:42 PM   #101
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
Nice! you going to be at open drift this weekend??
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 05-14-2013, 11:45 PM   #102
MC.Understeer
Maybe. I'll be at the grassroots event Sunday I hope.
Old 07-12-2013, 10:39 PM   #103
MC.Understeer
Thought I'd update my build thread a little now that I'm close to getting twards the end of finishing everything including repainting the front end.
In action...sorta.
Jeff Woodruff 2jzgte EVD 100 Evergreen drift S13.5 - YouTube
Old 07-13-2013, 12:24 AM   #104
driftlife.son
driftlife.son is an unknown quantity at this point
can i pay you to reproduce those brackets to fit the cts-v brakes
driftlife.son is offline   Reply With Quote
Old 07-13-2013, 01:00 AM   #105
MC.Understeer
for the 4 or 6 piston?
Old 07-13-2013, 01:02 AM   #106
driftlife.son
preferably the 6 piston but i dont mind the 4 either. and what rotor did you use as well
Old 07-13-2013, 01:21 AM   #107
MC.Understeer
They already make a 4 piston caliper bracket you can get through chase bays. These ones have to have tubular LCA's or the calipers will hit the stock control arm even with roll center correction ball joints. I'm using the infinity FX50 front rotors.
Old 07-15-2013, 11:37 PM   #108
MC.Understeer
Some action from this weekends event
Jeff Woodruff 2jz Evergreen drift EVD 102 - YouTube
Jeff Woodruff Evergreen drift EVD 101 2jz s13.5 - YouTube
Old 07-16-2013, 07:41 AM   #109
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
glad to to see you out there man, i my self finally finish mine and went to my second event this past weekend, motor feels great with the twins.
is it still cutting out at 5,300 rpms?
JohanM is offline   Reply With Quote
Old 07-17-2013, 12:30 AM   #110
MC.Understeer
No its fine now, I had to mess with resistors in line of the crank position sensor. Was getting too much noise in the signal.
