Old 03-08-2008, 10:08 PM   #1
SlideWaysSilvia
Banned from the Marketplace
SlideWaysSilvia is making his/her stupidity well-knownSlideWaysSilvia is making his/her stupidity well-knownSlideWaysSilvia is making his/her stupidity well-knownSlideWaysSilvia is making his/her stupidity well-knownSlideWaysSilvia is making his/her stupidity well-known
Send a message via Yahoo to SlideWaysSilvia
having problems
my car wont start i have recharger the batter changed the termanals replaced the starter and the ignition coil and when i try to start the car it starts to crank over but never actually starts
please if you know what the problem might be so i can fix it myself befor take it to a shop and spend money i dont need to
it is a 97 S14
SlideWaysSilvia is offline   Reply With Quote
Old 03-12-2008, 12:50 AM   #2
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
it is a 97 S14
if there are no funny starting sounds. take the alternator out & go get it checked 4 free @ yah local kragens. sounds like you checked EVERYTHING!. .. .except the alternator.
diagnose ALL electrical elements B4 going into another system.
Best Regards.
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
Old 03-12-2008, 01:08 AM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
are you getting fuel? take a spark plug out and crank the engine over and smell for fuel or see if fuel is spitting out. next check for spark. even if the alternator is bad and the battery is good the car should turn over or even start if the battery is fully charged. so the car turns over..as you said. i think it might be a fuel problem. you should take a sparkplug out and check the tip, if wet then you should let the cylinders dry up. you've flooded the engine. next, check to see if you're getting spark to the the plugs. though you did replace the coil there may be no power getting to the coils as "Ni YON Zenki" said above, check wiring. but it think its a fuel problem.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
