Old 01-13-2012, 04:05 PM   #1
$14s1lvi@
$14s1lvi@ is an unknown quantity at this point
SR need help RATTLING TAPPING NOISE
I got s14 SR with built block CP pistons Eagle rods
ACL main / rod bearings bored block .20 over with apexi
head gasket, ARP rod bolts Arp headstuds and now car is making a rattling
knocking noise. I looked at the rocker arms and shims
and they are in place but don't know wat caused the problem
or wat is the problem so any info will be appreciated
Thanks for reading, hope someone knows the result
or has any experience on a problem like this
$14s1lvi@ is offline   Reply With Quote
Old 01-13-2012, 05:20 PM   #2
$14s1lvi@
Any one bump
Old 01-13-2012, 05:32 PM   #3
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
Hopefully it's just the VTC Solenoid or Chain Tensioner. If not those, I sure hope the crank are properly measured or even machined to rock those ACL bearings. I've seen plenty of builds using aftermarket bearings on virgin crankshaft fails "spun bearing" even before 1k miles of break in period. GL!
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 01-13-2012, 05:33 PM   #4
Killa_D
Killa_D's Avatar
Trader Rating: (39)
Killa_D can only hope to improve
Feedback Score: 39 reviews
i say vtc also its common problem...
Killa_D is offline   Reply With Quote
Old 01-13-2012, 05:51 PM   #5
Davidna2fi
Trader Rating: (18)
Davidna2fi is an unknown quantity at this point
Feedback Score: 18 reviews
Can you push down on the rocker arms and they move? If so, the hydraulic lash adjusters were not bled and need to be rebled...which means removing cams and resetting timing. Easy test to see if it is an oiling problem is the just spin engine over without CAS plugged up and look inside oil cap area to see if oil is coming from the oiling rods over the cams. Check oil to head first, then rule out lash adjusters, then last thing would be VTC, if chain is tight.
Davidna2fi is offline   Reply With Quote
