Group Buys Dedicated Forum for Group Buys. |
04-06-2005, 11:56 AM | #1 |
Password:JDM - Radiator Cooling Plates, Magnetic Drain Plugs, Intake Manifold Gaskets
Passwords latest product! The all new aluminum cooling plate for the S13 chassis. This cooling plate is designed for JDM S13 front ends only!
Only $89.99 Click here for more details! The cooling system is a vital component of a vehicles operation. The radiator needs constant airflow, with minimum turbulence, to be as efficient as possible. Unfortunately, gaps in the structure around the radiator allow air to escape, resulting in lost efficiency. We have designed our line of Aluminum Radiator Cooling Plates to eliminate this problem. By preventing air to escape over the top of the radiator, these cooling plates allow a maximum amount of airflow directly to your radiator, resulting in reduced coolant temperatures during aggressive driving. All Password Radiator Cooling Plates are constructed from high quality aluminum, and then finished in a high-density epoxy coating proprietary to Password. This coating provides a long lasting, durable finish that cannot be found anywhere else! Two versions available. One is designed to fit the OEM grilles, and the other to fit aftermarket grilles. We are currently developing Password Radiator Cooling Plates for S13's with pop up headlights, and for S14's. Check back soon! These will be available shortly! S13 Application S15 Application Password Magnetic Oil Drain Plug Only $19.99 Click here for more details! Introducing the all new Password magnetic oil drain plug. This magnetic oil drain plug will extend the life of your engine. It helps to keep the excess metal particles that are created from normal engine wear from floating freely in your engine oil. It is designed to attract and hold metal particles to help prevent them from causing excess wear and reducing engine life. It's easy to install. Simply remove your stock drain plug and install the Password magnetic oil drain plug. At you next oil change, simply wipe the metal particles off of the magnetic drain plug and reinstall it in your engine. Works every time! Reusable! No modifications needed to install. For your viewing pleasure, we have laser etched a Password logo on the head of all of our magnetic oil drain plugs! This version of our magnetic drain plug will fit all Nissan vehicles. Password Thermal Shield Intake Gasket Only $39.99 Click here for more details! Password Thermal Shield Intake Manifold Gaskets are an inexpensive and very effective modification. By using a special material, the intake manifold is better insulated from the hot cylinder head. This insulation lowers intake air temperature which results in more horsepower and protection against detonation. - Reduces HP robbing heat transfer into the intake manifold - Precision CNC machined for superior quality - Dramatically reduces intake air temperature - Increases horsepower Applications available for all SR20 engines! |
04-07-2005, 04:25 PM | #3 | |
this would be the plastic version that reduces the temps. |
04-14-2005, 02:49 PM | #7 |
the gaskets available now are for SR20DET only. we are working on a KA model, give us a little time
thanks for the bump!! the plates are definitely the hotness |
