Old 12-11-2009, 01:00 PM   #1
rollndubz86
rollndubz86 is an unknown quantity at this point
#4 cylinder sucking in coolant! But from where please help!!!
I have a ka and my problem was i started getting coolant into my cylinders alot in # 4 and when i took everything apart i got the head completely redone. The head was warpped .01 of an inch so the machine shop resurfaced it. I replaced the head gasket and bought new head bolts. When i put the head gasket on i used the 5 step torquing process. It was (1) 22 ft lbs (2) 55 ft lbs (3) break bolts loose (4) 22ft lbs (5) 55 to 62 ft lbs. The final torque i torqued the bolts to 60 ft lbs. I got everything back together all 4 cylinders have great compression all of them are at 160. But when i put everything back together im still having the same problem.
When i pulled the head off i noticed only # 4 was getting wet this time and i looked at the gasket and the was a small knick at the coolant passage. I had the head redone at napa. The one thing that is really confusing me is my intake manifold is filling up with coolant as well. Can some body please help this is the 3rd time ive ripped apart his motor
rollndubz86 is offline   Reply With Quote
Old 12-11-2009, 02:05 PM   #2
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
was ur intake manifold filling up the first time this happened?
fcdrifter20 is offline   Reply With Quote
Old 12-13-2009, 05:19 PM   #3
rollndubz86
yea it was!
Old 12-13-2009, 05:23 PM   #4
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
you sure you didnt route a coolant line to your intake plenum?
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 12-13-2009, 05:33 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
You could likely have a cracked head. If you routed a coolant hose into your intake it would be a MASSIVE amount of coolant. It is possible that the intake mani is cracked into a coolant passage as well, but I am not sure if there is any coolant around the #4 cyl intake runner.
Old 12-13-2009, 05:55 PM   #6
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
cracked block possibly.
godsmack is offline   Reply With Quote
Old 12-13-2009, 08:34 PM   #7
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
iron block arent know to crack to my knowledge
but they could possibe to warp
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
Old 12-13-2009, 09:07 PM   #8
racepar1
racepar1's Avatar
They'll crack if you get them hot enough, but it is not all that common. That's why I suggested the head. A GOOD head shop will pressure check the head. Did NAPA pressure check it???
The bottom line is that either something is cracked (my suspicion), or the guy who put the engine together is a complete dumbass (I hope not). Neither one of those scenarios is a good thing...
