04-23-2010, 02:27 PM | #1231 |
That's your toe or camber? What are you asking exactly? Traction rods don't adjust toe or camber. They adjust rear castor or something like that. Something you don't need. Most shops can't even set rear castor.
Here, read this: http://zilvia.net/f/tech-talk/300886...tion-rods.html Basically if you have RUCAs and your car is low, you need toe rods. No one needs traction rods, they just help firm up the rear suspension by eliminating rubber bushings.
04-23-2010, 03:22 PM | #1232 |
is there a difference between s14 a/c compressors? i just got one from a enki for my kouki and the holes on the compressor are slightly too small to bolt the lines into....Ideas?
@UpshiftEngineering |
04-23-2010, 05:35 PM | #1233 |
Yeah I meant to say toe rods. That was my Camber in the rear, i was asking if there is another way of correcting you rear camber instead of buying RUCAS. I read up on Eccentric Bolts and I was wondering how much would they correct. Anyone with some experience with them???
SPENCER DOUGHERTY RIP ME OFF. SEARCH HIS REVIEW THREAD. |
04-23-2010, 08:04 PM | #1236 |
Trader Rating: (24)
Feedback Score: 24 reviews
uh i hella wet sand it and apply gease and wax remover and let it dry.. i painted other stuff too and they came out clean.
f it. ill just put carpet on. |
04-23-2010, 08:13 PM | #1237 | |
I believe (don't quote me on this) that the E and DE bellhousings are different.
SPLparts.com * PoweredByMax.net Quote:
04-24-2010, 08:26 AM | #1240 | |
ive heard people swear it flows so much that the stock fpr cant handle it. the truth is if your stock fpr is getting over flown its simply a bad unit. |
04-24-2010, 01:29 PM | #1244 |
lmao this ain't no pimp my ride!
Something better then stock and clean looking. I don't want any subs...just some aftermarket speakers.
HI HATERS! from the left to the right |
04-24-2010, 01:58 PM | #1246 |
Trader Rating: (42)
Feedback Score: 42 reviews
get a non rusted one.....i repaired all the rust on my car and it was a PITA! and if you don't do it yourself or have the skill it will cost a nice penny.
04-24-2010, 02:29 PM | #1247 |
how many oz/quarts of primer, paint and clear would it take to paint my whole car(s14)? exterior, bay, and interior? and how many coats of what should i do? first time painting by myself
04-24-2010, 03:08 PM | #1249 |
04-24-2010, 03:10 PM | #1250 |
hmm, yesterday i was drifting around in the rain and hit a curb pretty hard. now maybe im just paranoid but it seemed like my suspension was more bouncy than before. i have brand new stance suspension no more than 3 weeks old. you think they can break?
also, my passenger side light kept opening and closing after shutting off the lights, wtf? just the passenger |
04-24-2010, 03:13 PM | #1251 | |||
look towards component speakers. Quote:
passenger side light... check the door sensor. its in the door jamb, next to the door seals. should have a lil rubber cover. usually when the rubber cover wears out, the door sensor gets tripped randomly. actually wait, which light are you talking about. i just confused myself.
04-24-2010, 05:15 PM | #1255 | |
hahaha, sorry i meant the drivers head light on the passenger side but also, could the coil blow even before 1 month of use? it wasnt that hard of a hit, max was like 10mph cause it was raining and the curb isnt too steep if it blew how could i check? just bounce the car? |
04-24-2010, 06:11 PM | #1256 | |
here, super size it bitch!!!!!!!!! |
04-24-2010, 07:34 PM | #1258 |
what are some good coilovers to go with for autoX track and daily driving use?
how are the apexi N1 ENV. I was looking to try these out A'PEXi N1 Damper ExV Coilovers 1989-1994 Nissan 240SX (S13) - P/N: 269AN006 |
04-24-2010, 10:46 PM | #1259 |
here is my dumb question... My gas gauge is messed up. when i fill up it moves to about half tank. then when i am running on fumes it sits way below E. my whole cluster works fine. except this. is there a way i can take it apart move the needle to a predetermined position to get it to be a bit more accurate?
04-24-2010, 10:56 PM | #1260 | |
