05-11-2010, 02:10 AM | #1471 |
the kakimoto is 3 inch straight pipping with a 5 inch tip, it sounds bad ass but i,m not trying to bring so much attention to myself. its the only reason i want to change the muffler out.
05-11-2010, 11:07 AM | #1473 |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
can someone confirm this for me...
Flywheel bolts specs SR M10x1.25 CA M10x1.0
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
05-11-2010, 11:51 AM | #1474 |
Alright, I did a little searching before I wanted to ask here and couldn't find much except for info for an s14. I'm curious if an aftermarket delete option was made for the s13 hatchback/fastbacks. Wuoldn't even have to be carbon fiber, just something that would make it nice and flush with a factory look. If anyone knows of anything, thanks in advance once again for letting me know.
05-11-2010, 11:54 AM | #1475 |
not giving a fuck
are you talking about the actual hatchback section...yeah bro, its called an s13 coupe...
05-11-2010, 12:06 PM | #1476 | |
Anyone have any idea?
91 S13 Ka-t |
05-11-2010, 01:10 PM | #1477 |
Sorry Dalaz_86, I had a retard moment right there. I meant to ask if there was a delete option for the sunroof on the hatchback models. I can see where what I said wouldn't make any sense.
05-11-2010, 02:24 PM | #1478 |
is there anyway to remove the mines daughter board on a "mines tuned" ecu and have the ecu act like stock again. I got a mines ecu and have no clue what tune is on it so I hate to find out the hard way that it wasn't set up for a stock sr.
05-11-2010, 03:01 PM | #1480 | |
Trader Rating: (26)
Feedback Score: 26 reviews
doens't necessarily delete it, but it covers the glass. i've also seen someone get sheet metal, cut it to shape, and rivet it over the opening. |
05-11-2010, 03:02 PM | #1481 | |
Banned from the Marketplace
As long as you dont drive it like a dickhead you'll be fine. |
05-11-2010, 03:04 PM | #1482 |
Trader Rating: (26)
If the mines ECU is from japan and tuned in japan... you probably wont want to use it; unless you can get high octane in your area.
I believe (dont quote me) you can change the jumper on the ecu and it wont read from the daughter board. i forgot what jumpers you change. |
05-11-2010, 03:08 PM | #1484 |
Use that heat sticker stuff, I literally cannot remember what its called, but its essentially sticker wrap that is heat resistant, usually its gold in color but I think they have black and silver now.
05-11-2010, 03:10 PM | #1485 | |
05-11-2010, 03:24 PM | #1486 | |
Japan uses a different Octane rating system. 93 octane on JDM tunes is fine. If you really want to learn, google RON Octane Rating vs. AKI vs. MON vs. what we use (RON+MON/2). Better yet, here. http://en.wikipedia.org/wiki/Octane_rating
05-11-2010, 03:44 PM | #1487 |
Is it okay to jack up the front or rear lower control arms? I'll be needing to raise the hub area to mount coilovers that are re-adjusted for a lower ride height setting, but the FSM says not to use a jack on the lower control arm.
05-11-2010, 03:52 PM | #1489 | |
Trader Rating: (26)
I'll definitely look into that. Thanks |
05-11-2010, 04:14 PM | #1490 |
Question: one of my spark plugs has got threaded in wrong by the previous owner. What can i do to fix this so it threads in correctly. also i have some black drops that come out of my exhaust, very small amount. but it bothers me. could this spark plug be causing this?
05-11-2010, 04:31 PM | #1493 | |
They make tools to "straighten out" messed up threads. It's a last ditch effort but it might save you from having to get a new head. Go to any generic auto shop and ask for a thread chaser (I believe that is the correct name). You will just need to know the thread pitch of your spark plugs. |
05-11-2010, 04:46 PM | #1494 |
Calm down Susie,
He wasnt rude at all and actually gave you a lot of pertinent information in regards to your question. Just sell your mines ecu to someone that know what they are doing and get stock ecu, or trade someone with a stock ecu and have the throw cash on top. Or figure out a way to contact Mines and find out the what the daughter is tuned for. All mines ecus have a Mines number on them. Im sure its just a "step up" like most of the ecus that end up over here. Need me to explain what that is too?
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
05-11-2010, 05:14 PM | #1495 |
do we have a thread comparing seats?
im interested in the sparco chrono road but wanted to see if anyone else had this seat and how high/low it sits
05-11-2010, 10:20 PM | #1497 |
They are meshed together. The emissions and vacuum lines keep the engine running properly. The engine efficiency decreases with the removal of the EGR system. If it's your daily, you shouldn't mess with it.
05-11-2010, 10:51 PM | #1498 |
^Ahh alright. well its gunna be mostly a track slut, and im not really worried about smog. Half the EGR stuff is already out, and most of the vaccum lines arnt hooked to anything. Im just trying to figure out whatn i need to keep, and whatn i can ditch. lol
05-12-2010, 12:10 AM | #1499 |
Okay, i'm tired of searching around... What exactly do I need to run powersteering on my 89 coupe with a SR redtop. All it has now is one belt turning the water pump and alternator, and a looped rack. I've heard theres different pumps you can use too. So i'm basically looking for a full list of what i'll need. Thanks.
05-12-2010, 10:11 AM | #1500 |
I dont think this belongs in the "identify this" thread BUT
Who's car is this? I spoke to him at VIR last year but I would like to know more about the car. Any build threads?
http://buildmakecreate.tumblr.com/ |
